Old 07-19-2012, 03:10 AM   #869
slow_frs
Drives: turbo scion tc
Bye bye tq dip, looks like it was an issue of VE huh? Also quite disappointed in the Honda style torque but that's fine I'm about top end not so much putt putt, looks like with two more lbs you'll get about 230whp with the same timing and fuel adjustments you have been going with
slow_frs is offline   Reply With Quote
Old 07-19-2012, 03:12 AM   #870
sw20kosh
Drives: 2013 Black FR-S
Congratulations! Quite the accomplishment!
I particularly enjoy the 150-155 ft-lbs at redline. Something about a flat torque curve out to redline really makes me smile.
Although, does this point towards boost creeping up past the set point of 4 psi in the higher revs? I used to have this problem back in the day when the wastegate was insufficent and wasn't relieving enough exhaust causing boost creep in the upper revs.
Either way, I am fine with a small boost creep if it means flat torque!!! Now we need to raise the rev limiter.... :happy0180:
Old 07-19-2012, 03:26 AM   #871
sierra
Drives: Skoda Yeti DSG diesel 4x4
Originally Posted by Don@Accelerated View Post
Dyno Graph Comparison.
Bone Stock Baseline vs 4 Psi Turbo Kit (Under development)
Was just out cruising around its a very noticeable difference part throttle. Haven't gotten on it hard yet. Its 2am and I'm tired. Not trying to get pulled over.
That's a beautiful progressive power line and right up to 7,500rpm instead of falling off just before 7,000rpm.
The torque is almost constant across the range with a slight build and holding well at the top end.
That should result in a sweet power delivery on the road with a flexible engine that responds and rewards as the revs climb but doesn't need to be rung out to keep up as some VTECs do.
I make that about 241Nm at the flywheel which is well within the manual trans spec.
sierra is offline   Reply With Quote
Old 07-19-2012, 03:36 AM   #872
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
oh man. This makes me not want the SC anymore lol. This is what I wanted, nothing insane with the power, just a nice flat tq line. Good Job!
mechaghost is offline   Reply With Quote
Old 07-19-2012, 03:54 AM   #873
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
Gonna have to wait until my warranty expires, lol
|-Goku-| is offline   Reply With Quote
Old 07-19-2012, 03:58 AM   #874
inz
Drives: GTi-R
Been enjoying this thread, can't wait to see the boost pushed a little higher
Originally Posted by inz View Post
My guess is around 160WKW
Not a bad guess :P
inz is offline   Reply With Quote
Old 07-19-2012, 04:10 AM   #875
mechaghost
mechaghost's Avatar
reminds me of salt-n-pepa
[ame="http://www.youtube.com/watch?v=vCadcBR95oU"]Salt-N-Pepa - Push It - YouTube[/ame]
Old 07-19-2012, 04:16 AM   #876
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Mega! Where do you drain the oil from the turbo?
MSTiFK8R is offline   Reply With Quote
Old 07-19-2012, 04:19 AM   #877
Don@Accelerated
Don@Accelerated's Avatar
I just drove the Turbo Brz home for the night. Drives great. Very noticeable to say the least.
Don@Accelerated is offline   Reply With Quote
The Following 4 Users Say Thank You to Don@Accelerated For This Useful Post:
Apex Chase (07-19-2012), cobrabyte (07-19-2012), HotLeopardMama (07-19-2012), Sall (07-19-2012)
Old 07-19-2012, 04:20 AM   #878
Visconti
Drives: 05 STi
It's fast now lol
With more boost it'll be a lot to handle
Visconti is offline   Reply With Quote
The Following 5 Users Say Thank You to Visconti For This Useful Post:
cobrabyte (07-19-2012), HotLeopardMama (07-19-2012), MSTiFK8R (07-19-2012), SVTSHC (07-19-2012), Wix (07-19-2012)
Old 07-19-2012, 04:25 AM   #879
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Excited to read that!
So you still on the stock engine, gaskets, and injectors ?
And stock ECU is capable of learning such a far galaxies?
wow then!
Old 07-19-2012, 04:51 AM   #880
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
Step 1: Buy my BRZ
Step 2: Buy this awesome turbo kit
Step 3: Aww yeah!
This is coming along very nicely, dyno with 4 psi of boost is looking real good.
00NissanNinja is offline   Reply With Quote
Old 07-19-2012, 05:08 AM   #881
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Don, have you guys played around too much with the variable cams and their effect on output? I'm positive there are more gains to be had, but I am really curious how the variable cams will impact the tuneability and output.
I am sure you can get to 220whp on 4psi. Even at 6psi the disco is begging for more. I have never experienced a turbo that works as well as the disco for a daily driven and responsive setup. It's a great unit.
Coheed is offline   Reply With Quote
Old 07-19-2012, 05:21 AM   #882
MSTiFK8R
MSTiFK8R's Avatar
Drives: BRZ WRB
Sorry, what's that DISCO stands for?
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
