Old 05-02-2019, 11:38 AM   #29
demariners
demariners
Drives: 2015 Blue Subaru BRZ
Not sure if this picture works but here is the picture of the 2017 Wheel installed on my 2015 BRZ.
https://www.dropbox.com/s/sstilpupyl...968_n.jpg?dl=0
demariners is offline   Reply With Quote
Old 07-30-2019, 08:25 PM   #30
Dobe2049
Dobe2049's Avatar
Drives: 2015 Subaru BRZ
So I have a 2015 BRZ. I purchased a 2017 wheel and clock spring.
The only issue is one port that the connector will not fit.
Dobe2049 is offline   Reply With Quote
Old 07-30-2019, 08:36 PM   #31
demariners
demariners
I did not use a 2017 clockspring. I used the existing clockspring from my 2015 and re pinned it.
Old 07-30-2019, 09:43 PM   #32
Dobe2049
Dobe2049's Avatar
I understand I'm going the route of making the 2017 clock spring work.
Old 07-30-2019, 10:00 PM   #33
demariners
demariners
Your best bet is to do what I did then. Get a 2017 wiring harness. I got one luckily on Ebay for $50. Then pin-out or splice what you need into it from the old harness. For my car it was only 4 wires (I think one is the horn and the other is the cruise control)
Old 07-31-2019, 12:20 AM   #34
Dobe2049
Dobe2049's Avatar
Where did you find wiring diagrams?
Old 07-31-2019, 12:21 AM   #35
demariners
demariners
I didn’t. I pinned them out using a meter.
Old 07-31-2019, 12:21 AM   #36
Dobe2049
Dobe2049's Avatar
Sent from my Pixel 3 XL using Tapatalk
Old 08-08-2019, 09:30 PM   #37
Dobe2049
Dobe2049's Avatar
This correct?
Old 08-20-2019, 07:01 PM   #38
MachineHead
Drives: BRZ Limited
i hope this diagram helps
disregard DP, DP2 and EAU
it would be a lot easier if you can find a new clockspring but make sure it comes with the harness (at the very least the connector with cut wires)
new clockspring connector
if you’re using the old clockspring, you won’t need a new harness. you’ll have to transfer the wires from the steering wheel control harness connector to the old steering wheel harness connector and add wires to the existing clockspring harness connector.
old clockspring connector
MachineHead is offline   Reply With Quote
Old 02-04-2020, 10:51 AM   #39
asneakybanana
Drives: 2015 Soon to be turbo BRZ
Question for you on this. I am currently looking at retro fitting a 2017+ cluster and would like to make the buttons for controlling that as well as the audio controls work. I was planning on using a 2013-2016 Roll Connector, problem is, the connector on the steering wheel only has 10 pins and I need 11 for this. One thought I had was running the extra pin or more than 1 pin through the 4 pin connector for the paddles for automatic cars. Do know think this would be doable? Any reason in particular I wouldn't be able to use those pins?
asneakybanana is offline   Reply With Quote
Old 02-13-2020, 09:32 AM   #40
asneakybanana
An update,
decided to just go with the 17+ roll connector and grab a cheap 17+ limited dash harness. Will hopefully be getting them installed next weekend. Working on pulling the necessary wires from the 17+ harness now. Need AU Gnd, AU1, AU2, DP1, DP2, EAU, Ill+, and Ill-. Will then pull the wires back to the head unit or dash cluster connector and start adding them into my car.
Old 02-26-2020, 07:03 PM   #41
asneakybanana
Originally Posted by asneakybanana View Post
An update,
So, an update. Got it installed this past weekend, had to get the mileage on the odometer changed but other than that worked like a charm. Have the stock 2015 head unit so can control the songs and source but volume control isn't working. However all controls for the gauge cluster work perfectly. For ILL+ and ILL- they are just spliced together on the 2017 car so I ended up splicing them into the ILL+ and ILL- wires on the clock connector and it works perfectly.
Only other thing is I messed up the steering angle sensor when removing the old wheel so just bought a techstream cable to do a recalibration and hopefully that will fix it.
Old 03-19-2020, 12:51 AM   #42
alibaig99@gmail.com
Drives: Toyota 86 GTS 2013
Hey mate, I am doing exactly same in my car. do you have any photos of work you did?
alibaig99@gmail.com is offline   Reply With Quote
2013-2016 vs 2017 front pipe Var Engine, Exhaust, Transmission 2 10-09-2018 03:19 PM
2016 BRZ vs 2017 BRZ CBR600RR FR-S / BRZ vs.... 175 11-16-2016 02:47 PM
Trading in 2016 BRZ for 2017 BRZ? acethebrz BRZ First-Gen (2012+) — General Topics 27 10-13-2016 10:02 PM
2017 Tails on 2013-2016? djsyndrome Cosmetic Modification (Interior/Exterior/Lighting) 2 09-04-2016 05:51 PM
Replacing steering wheel and seats mclevin AUSTRALIA 11 06-23-2012 07:53 PM
