Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
06-12-2018, 04:01 AM | #1 |
86Drive Challenge
Drives: 2017 BRZ PP
Brembo Torque Specifications
What’s the specified torque for caliper mounting bolts on the Performance Package Brembo calipers, and are the caliper bolts reusable?
Unofficial answer: 59lb-ft/80Nm with anti-seize has been working great; numerous track days with no issue, and taking the calipers off a year later everything looked great. Last edited by mkodama; 05-12-2019 at 01:01 AM. |
06-12-2018, 06:56 PM | #2 |
Brembo’s use German torque. Gutentight, I beleive is the setting.
06-12-2018, 07:15 PM | #3 |
Drives: Car
Yes, they're reusable. Are these the fronts? If so, 60 ft-lbs and call it a day.
The Following User Says Thank You to FirstWinter For This Useful Post: | mkodama (06-13-2018) |
06-13-2018, 01:01 AM | #4 |
86Drive Challenge
Drives: 2017 BRZ PP
lulz
This is what I ended up going with. Dry, it is impossible to properly torque these bolts with less than 120Nm as they want to seize. With some copper anti-seize, all 4 front bolts tightened to their original position(clocked with a pen mark) at 60ft-lb/80Nm. |
The Following User Says Thank You to mkodama For This Useful Post: | Tristor (06-15-2018) |
06-28-2018, 10:43 PM | #5 |
Drives: 2017 BRZ Limited, Perf Package
I looked in my service info, I don't have any specs listed for either. Should just be able to snug em both up and be fine, add a little extra oomph to the banjo bolts.
07-31-2019, 06:46 AM | #6 |
Drives: 2022 GR86
Stumbled upon this thread, as well as a similar thread on an STI forum.
https://forums.nasioc.com/forums/sho....php?t=2894993 Looks like the answer is ~80–88 lb-ft which with anti-seize translates to about 60 lb-ft indeed. |
08-01-2019, 05:22 PM | #7 |
Drives: 2015 BRZ Limited
3 ugga duggas should do it!
The Following User Says Thank You to JeremyR For This Useful Post: | soundman98 (08-01-2019) |
10-03-2019, 03:41 PM | #8 |
Drives: 2022 GR86
Front caliper bolts: 88.5 ft·lb or 120 Nm
Rear caliper bolts: 53.8 ft·lb or 73 Nm Bleeder valves: 14.8 ft·lb or 20 N·m Source: Subaru BRZ, 2020 Service Manual Last edited by timurrrr; 03-06-2021 at 01:44 AM. |
The Following User Says Thank You to timurrrr For This Useful Post: | Tristor (10-10-2019) |
Similar Threads | ||||
Compression Test Values - Factory Specifications? | kharn83 | Engine, Exhaust, Transmission | 14 | 11-13-2017 02:21 AM |
Requesting OEM Clutch Line Specifications | RJasonKlein | Engine, Exhaust, Transmission | 6 | 05-21-2015 12:06 AM |
TRD GT86/AERO Specifications | 1904 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 11-06-2014 02:03 AM |
front and rear fender well specifications | PineappleFriedRice | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 07-22-2013 06:06 PM |
