69gtojeff, CT86, gravitylover
Old 07-12-2019, 11:29 AM   #309
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by xjohnx View Post
I'm >< close to taking SOA to small claims. Apparently the chances of them actually sending someone to appear for a small claims case are rather slim, so a judgement by default is the usual outcome.
Yup, then the only issues becomes successfully collecting on the judgment, which is usually a bigger problem with random individuals and not so much large entities.
Old 07-12-2019, 05:12 PM   #310
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by zeroomega View Post
I just finished my first oil change after the recall and sent the used oil for analysis. The report(attached) looks good. The car current is currently 3400 miles after the recall work was done. So I think my engine is OK after the recall. The car went through 3 track days without any issues. And the burning smell disappeared 3 months after last repair. I don't know why it takes so long but finally it disappeared.
This is extremely helpful. Thank you!
Old 07-24-2019, 01:55 PM   #311
ndsleep612
Drives: Thee Argento Cricket
I have a massive oil leak post-recall work done. I've been in contact with the service writer who helped me. He mentioned it could be the timing cover.
Shouldn't that be covered since the mechanic needed to disassemble the motor to get to the valve springs?
ndsleep612 is offline   Reply With Quote
Old 07-24-2019, 02:44 PM   #312
maslin
Benz Tech
Drives: 2017 BRZ Premium
Yes. Unless you have a cold air intake. Then they're going to throw you under the bus.
maslin is offline   Reply With Quote
Old 07-24-2019, 04:01 PM   #313
kri$han
Drives: 2012 Scion FR-S
Originally Posted by kri$han View Post
Yes, the service manager at the dealership thats fixing my car says that Toyota Canada has sent them a template with very careful instructions of how to apply RTV sealant to the timing cover, which is clogging up all the oil passages in our cars and starving the main bearings of oil (and/or leaking out of the timing cover itself).
I just hope they take their time and do it carefully... AND apply the RTV when the motor is cool, and give it plenty of time to cure before testing it...
Damn, this was back in MAY, FFS.... It's now July 24th, and I'm still driving the bright blue Corolla Hatchback the dealership loaned me when I brought my car in for service on APRIL 16th!
Honestly, fuck this car, I don't even want it back. Next time he calls me, I'm just gonna ask him if i can keep the Corolla as a straight trade for my FR-S :p
kri$han is offline   Reply With Quote
Old 07-24-2019, 04:07 PM   #314
used2likeit
Drives: 2013 FR-S, 6MT, Daily Driver
Friendly reminder to all Canadians who had their engine blow up after the recall to lodge a complaint with Transport Canada: https://wwwapps.tc.gc.ca/Saf-Sec-Sur....aspx?lang=eng
used2likeit is offline   Reply With Quote
The Following User Says Thank You to used2likeit For This Useful Post:
SPEEDGOD (07-30-2019)
Old 07-26-2019, 03:26 PM   #315
NickCarmer
NickCarmer's Avatar
I've been driving a bright orange outback or whatever it is they gave me for the past two months! Finally got the call that the engine is back in my car and they're road-testing it today.
NickCarmer is offline   Reply With Quote
The Following User Says Thank You to NickCarmer For This Useful Post:
humfrz (07-26-2019)
Old 07-30-2019, 11:20 AM   #316
Little Mt. Fuji
Little Mt. Fuji's Avatar
Drives: 2013 Ultramarine Scion FR-S
Vehicle Mileage:~87,000
Vehicle Make: FRS
Mileage After Recall Performed: ~85,000
Symptom(s): Rod Knock, Power loss
Failure: TBD, most likely spun rod bearing
State: In dealer with engine being striped, new short block just came in
Is Dealership Offering Repair: Yes, no hassle or arguing, brand new short block, unsure if reusing cams.
Little Mt. Fuji is offline   Reply With Quote
The Following User Says Thank You to Little Mt. Fuji For This Useful Post:
gravitylover (07-31-2019)
Old 07-30-2019, 03:58 PM   #317
SPEEDGOD
I don't lie.
SPEEDGOD's Avatar
Drives: AE86 Successor
Transport Canada called, they have 4 cases so far, please contact them guys, we need to build this case! Thank you!
I'll get a Mustang for way less if I wanted more power.
SPEEDGOD is offline   Reply With Quote
Old 07-31-2019, 03:01 AM   #318
daftpunk
daftpunk's Avatar
Drives: 2013 Scion FRS
Well it finally happened, funny thing is I only got the recall because a friend of mine had it done earlier and put on tons of kilometres without issues. I swear the day my car was ready to be picked up after the recall, he spins a rod bearing.
When I went to pick up my car today, there were three cars sitting in the lot with dead engines.
Vehicle Mileage: 119000 km
Vehicle Make: 2013 FRS
Mileage After Recall Performed: 2000km
Symptom(s): loud knocking, started at around 5k rpm and car shut off shortly after
Failure: tbd
State: Ontario, Canada
Is Dealership Offering Repair: No, because car was out of warranty, dealership wanted to charge labour to start any diagnosis. Service tech said it would be a waste of time/money because I obviously needed a new engine and sent me straight to Toyota Canada to try to start a claim.
2013 Firestorm Scion FRS
2005 Civic SI Sedan- Sold
2004 Impreza WRX - Sold
1992 Civic Hatchback - Parted, RIP
daftpunk is offline   Reply With Quote
Old 07-31-2019, 08:23 AM   #319
The car may be out of warranty but the repair shouldn't be... It had a 12 month limited mile warranty, at least in the US.
Old 07-31-2019, 09:25 AM   #320
What do you hope they will do?
Old 07-31-2019, 11:48 AM   #321
maslin
Benz Tech
The repair they performed has a 12 mo warranty. If the rod exited the block and they claim it has nothing to do with the work they performed you get nothing.
We know it was due to the recall, but if the dealership doesn't want to back it up you will have to fight it.
If you remove a door panel and replace a window motor the window motor has a 12 mo warranty. The door panel does not inherit any of that warranty.
If the tech breaks the door panel taking it off and glues it back together, which later falls off when you slam the door... that's on the dealer.
It's just like that. But $10k.
The Following 3 Users Say Thank You to maslin For This Useful Post:
Dadhawk (07-31-2019), marco1ca (07-31-2019), Tcoat (07-31-2019)
Old 07-31-2019, 12:38 PM   #322
Yea, I get that. Didn't read your message that way though, you just said because the car wasn't under warranty they wouldn't do anything to check it. Since the repair is under warranty they "should" evaluate if the repair caused the problem.
Of course, that is expecting good faith on the part of the dealer I realize...
maslin (07-31-2019), Tcoat (07-31-2019)
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-19-2019 12:24 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 07:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 08:23 PM
