Old 07-30-2019, 09:57 PM   #603
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by ZDan View Post
And in what car with what manual trans have you done that?!
A short-lived one.
A long time ago a friend, who was a passenger in a local government car, decided to play a bit of a "prank" on the driver. (They were good friends.)
He (the passenger) put the auto car into reverse doing about 70 km/h. The car had to be towed away.
Old 07-30-2019, 10:55 PM   #604
ermax
ermax's Avatar
Originally Posted by Atmo View Post
I use special wide shoes with tabs on the outside edges and a lateral rocking motion around a vertical axis with my right foot to heel-toe. It's worked well on any M/T car I've driven, but I'm so accustomed to left foot braking that I'm certain to be consistently quicker in a DCT on a road course and not just for <100ms shifts.
I understand what you're saying, but visualizing it makes it seem like an unnecessarily complex method that needs narrow shoes. I don't recall any YouTubes showing racers doing that but whatever works for you.
No question an auto would be quicker. I’m not debating that at all. I just find a manual and all the extra steps to be challenging and therefor more fun.
The Following User Says Thank You to ermax For This Useful Post:
Tokay444 (07-31-2019)
Old 07-31-2019, 01:33 AM   #605
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
[ame]https://www.youtube.com/watch?v=U-JiQZPiIXU[/ame]
Old 07-31-2019, 02:03 AM   #606
maslin
Benz Tech
Drives: 2017 BRZ Premium
The 5 speed Mercedes transmission used for the last 25 or so years has a governor at the tail shaft that allows line pressure to pop a slider out and block the shift shaft from reverse and park.
Had a girl whose governor was stuck many years ago, you could only put the car in park after you turned it off. No money, college kid, blah blah blah. We cut the post off the shift shaft. That poor Mercedes would go to reverse at any speed you wanted
Never saw it again. So it either ended in a spectacular fashion, or is still on the road today.
It would be interesting to see a DCT apply both clutches at once. I’m sure it has happened and will happen again, not one I’ve seen though.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
WolfpackS2k (07-31-2019)
Old 07-31-2019, 02:14 AM   #607
Captain Snooze
Drives: Red Herring
Is that a Transformer face? Mmmm, was that deliberate? I'm guessing reflections would have been analyzed in development.
There is no other explanation: this is a conspiracy!
The Following 4 Users Say Thank You to Captain Snooze For This Useful Post:
Dadhawk (07-31-2019), gymratter (07-31-2019), HachiRokuX (07-31-2019), Tcoat (07-31-2019)
Old 07-31-2019, 09:28 AM   #608
Tokay444
I never missed a shift on my FR-S on road or track either, but it was a challenge to consistently heel-toe rev match downshift especially at the end of a long straight into a chicane.
The Verus Engineering throttle pedal spacer helped IMMENSELY.
The current trend of putting the throttle pedal behind the brake pedal is not conducive to heel-toe downshifting.
The Following 2 Users Say Thank You to Tokay444 For This Useful Post:
Atmo (07-31-2019), Yoshoobaroo (07-31-2019)
Old 07-31-2019, 01:29 PM   #609
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Wink
That guy is a spazz and frequently states incorrect facts. Let's not help his popularity please.
The Following User Says Thank You to WolfpackS2k For This Useful Post:
Tcoat (07-31-2019)
Old 07-31-2019, 01:42 PM   #610
Irace86.2.0
I like him. Plus the video has a lot of details.
Old 07-31-2019, 02:52 PM   #611
gtpvette
Drives: 2015 FRS - FFR GTM
Originally Posted by ermax View Post
LFB until you need to downshift and then point your toes together and transfer from LFB to RFB so your foot is free for the clutch. When I first started to heel toe I used my heel on the brake and toe on the throttle but then when I started learning to LFB I quickly discovered why you should use your toe on the brake. Putting your toes together is much more natural than pointing your toes to your heel.
Do a video,,, love to see it. No frickin way I'm getting two feet on the brake pedal LOL.
I will say selectable auto rev matching on downshifts in the C7 make the pedal dance easier.
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
The Following User Says Thank You to gtpvette For This Useful Post:
Tcoat (07-31-2019)
Old 07-31-2019, 04:13 PM   #612
I've heard similar stories and wonder if modern automatic transmissions are still vulnerable to that.
Old 07-31-2019, 04:28 PM   #613
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
I thought most cars have a "reverse lockout" that prevents that.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-31-2019, 04:33 PM   #614
I would love to know why you would need to left foot brake if doing heel and toe braking with the right foot? Maybe try right foot clutching for a real challenge.
Old 07-31-2019, 04:37 PM   #615
maslin
Benz Tech
Anything with a push button or knob can just tell you "no".
The Mercedes shifter shows a little diagram in the cluster,
R
N P
D
Depending on what you're doing and the state of the car, little arrows appear for all possible shifts.
In park, no foot on the brake, you can't do anything. Foot on the brake, they all light up. Stopped in neutral, brake on or off you can go anywhere.
It's a little tiny arrow most people probably never notice.
In park, no brake pedal.
In park, with brake pedal.
In drive, at standstill.
In drive, at speed.
Ultramaroon (08-01-2019)
Old 08-01-2019, 12:57 AM   #616
serialk11r
Drives: '06 AM V8V Coupe
You know since the 718 and 991.2, PDKs have been doing this right? They slip both clutches in higher gears to allow you to roll along with the engine at idle speed, presumably to prevent the clutch from heating up as quickly. Previously, there would only be one clutch slipping in 1st gear while you roll at 3mph, but I think it can now roll several times faster than that. The idea being it's more efficient to slip the clutch a little than to increase the revs from 700 to 1200 if you only need to maintain a slow speed. I haven't actually seen it in action, I imagine it only works up to whatever comes out to 3rd gear and 1200rpm with little throttle input.
I also believe there's gotta be some car out there using both clutches initially on a launch to reduce shock. The efficiency is still 0 when the car is stopped, but you get that extra kick of torque at the wheels with 2nd gear also transmitting torque, then you can disengage and rely on 1st gear alone once the tire is starting to slip.
Chevy Camaro Mid-Engine anybody? Impureclient Other Vehicles & General Automotive Discussions 42 03-14-2020 09:19 PM
Chevy Bolt? What do you think? EAGLE5 Other Vehicles & General Automotive Discussions 41 09-02-2016 04:38 PM
Mid-Engine C8 Corvette Mule Spotted Sideways&Smiling FR-S / BRZ vs.... 16 01-09-2015 10:30 PM
BRZ vs Chevy SS Razz FR-S / BRZ vs.... 109 03-07-2013 09:09 PM
