Drives: 2017 subaru brz red, 93 FD RX7
ECUTEK bluetooth set up
I'm looking to do a flex fuel set up in the near future and wanted to see if anyone has any experience with ECUTEK's bluetooth set up? I plan on going with Delicious Tunings kit and CounterSpace Garage for the tune.
#2 |
Works perfectly. Your getting the eca gauge? I use my ecutek Bluetooth everyday to monitor temps, AFR, fuel trims etc... As I use my phone with Android auto for my head unit? Do you have any questions?
2013 Series 10 FRS #553
#3 | |
https://www.delicioustuning.com/node/819 https://www.delicioustuning.com/node/691 Also would there be a bluetooth Headunit that could display the ECUTEK outputs? |
#4 |
I got the Moto east kit. Any Android based headunit could do that not to be mistaken by Android auto based headunit.
#5 | |
Pick your tune from the drop-down menus. The Flex Fuel kit itself is all you need from DT. https://www.delicioustuning.com/flexfuel |
#6 | |
#7 |
#8 |
Drives: BRZ Yellow, Ranger, Evora, WCM S2K
There is still a bug in the new ECUtec software that affects some 2017.I am not sure how many there are but mine is one of them. ECUTec has sucked at fixing it! Ask Zach we have fought this on my car since the new software came out(back in his DT days). The ECU will shut down just before red line and you will have a hard cut. I have given up for now and switched back to my old tune prior to the new update. I have been talking with ECUtec also and supposedly they have purchased a car with this issue and it is a "priority" to get this fixed. However I am not holding my breath.
#9 |
#10 | |
Drives: WRB BRZ
#11 | |
Only a handful of vehicles have encountered the full shutdown! |
#12 |
| Delicious Tuning Q & A - FlexFuel BlueTooth Kits for EcuTeK ProECU RaceROM | DeliciousTuning | Software Tuning | 331 | 06-17-2025 02:36 PM |
| Ecutek Bluetooth Interface Kit / ECU Connect | Luftwaffel | Software Tuning | 161 | 11-26-2020 07:01 PM |
| EcuTek Bluetooth shows generic under ‘Ecu name’ | kev0 | Software Tuning | 1 | 07-20-2019 11:37 AM |
| Ecutek cable, dongle, and bluetooth interface | coxxoc | Engine, Exhaust, Bolt-Ons | 2 | 01-25-2019 09:09 PM |
| FS: Ecutek ECU Connect Bluetooth | byun | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-21-2017 04:18 PM |
