#169 |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: |
#170 |
Quite update.
Fresh motor on car is good. Been getting some street tuning done, but is slow because Ecutek flashes rather slowly, and this is being done organically. More dyno time coming soon. |
#171 |
The Fail Boat
Drives: CWP S.B.
#172 | |
Good Job Subaru!
Drives: '24 CX-50 Meridian
Glad to hear everything is going well. Patiently looking forward to updates!
#173 |
Drives: brz 2017 hksv2
where is it located the map sensor with this itb? or is it maf based? or alpha N?
#174 |
Wayward Member
Drives: Hot Lava 86
So... Down time at work has me researching car parts (again) and I just discovered that CSG has a power package option. Dangerous stuff, especially since the ITBs cost as much by themselves as a full exhaust would. That being said... It is tempting. I can't help but wonder how much power you would get out of a full exhaust with ITBs and tuned for E85.
#175 | |
It won't be anywhere near as much as FI, but none of the complexity, and you'll never heat soak. |
#176 | |
Rice King
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
| The Following User Says Thank You to Jordanwolf For This Useful Post: | Nevermore (07-18-2019) |
#177 | |
Wayward Member
Drives: Hot Lava 86
It sucks haha
#178 |
ITB's are not about hp/dollar gains, but the change in response and attitude of the engine. If hp/dollar is your objective, a bolt-on supercharger (Jackson, Edelbrock) with E85 will cost less, and double your engine output.
#179 |
Wayward Member
Drives: Hot Lava 86
Oh, no doubt, but I want to stay NA if possible, and like I said, big numbers really aren't my goal. I guess I'm just trying to justify the extra cost since the ITBs cost more than the entire exhaust setup combined. I'm a cheap person by nature so my mind won't allow the splurge without justification. Response time improvement is a tempting factor since I do think the revs need to climb faster.
#180 | |
ITBs dramatically change throttle response. Try giving your throttle pedal a large momentary blip, and observe the delay between stepping on the throttle, and the revs climbing. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#181 | |
Wayward Member
Drives: Hot Lava 86
But I know the lag you're talking about. Getting rid of that is tempting, but I'm not sure if it's worth $3500. I'll keep it tentative for now and definitely will keep following this for more info. The more info I can get the better.
#182 | |
Drives: 2019 Series Gray BRZ
If it doesn't have good throttle response, might as well slap an automatic on it and let the damn transmission sort it out. Fingers crossed that this doesn't require a full ecu swap; I don't like having to dodge vehicle inspections 'cause the diagnostic port is a road to nowhere. |
| The Following User Says Thank You to Quasimofo For This Useful Post: | why? (07-20-2019) |
| In for the long haul Ultimate NA build thread. | celek | Engine, Exhaust, Transmission | 683 | 06-07-2020 07:26 PM |
| TOG ULTIMATE TOYOTA 86 GT86 FT86 SUBARU BRZ FA20 STAINLESS STEEL EXHAUST HEADERTOG UL | Andrew666 | AUSTRALIA | 8 | 11-19-2018 05:24 AM |
| RallySport Direct's Ultimate Drivetrain Thread! ***New Website*** | RallySport Direct | Transmission and Driveline | 92 | 09-01-2015 01:17 PM |
| RallySport Direct's Ultimate Interior Thread! | RallySport Direct | Interior Parts (Incl. Lighting) | 45 | 03-25-2015 02:12 PM |
| Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! | THMotorsports.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 12-11-2013 06:25 PM |
