Old 07-17-2019, 10:57 PM   #1
Silverz
Drives: Black frs
Fixing a dent under the door
So I parked the at the airport parking lot for a week and got back to a dent underneath one of the doors.
Tried the heat gun and compressed air. Then the glue stick and puller and neither Had enough ooomp to get the dent out.
I pulled the upper trim piece at the door seal and notice some staples holding the carpet on. Didn’t take the staples off to investigate if there was any openings there to get access to push out the dent. Has anyone looked underneath this carpet and if so is there any access to the area under the door?
Silverz is offline   Reply With Quote
Old 07-18-2019, 12:06 AM   #2
Welcome to our forum -
Too bad your car got dinged -
No I haven't tried that.
A picture would help us visualize your problem.
I would suggest you have a PDR person push/pull out the dent.
Old 07-18-2019, 09:47 AM   #3
If you are talking the rocker panel at the bottom of the car then there is no access point. Any dent will have to be pulled from the outside. These panels are also much heavier than the skin of the rest of the car so it isn't easy.
Old 07-18-2019, 09:53 AM   #4
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
That seems like a really random place to get dinged. Any idea how it happened?
Nevermore is offline   Reply With Quote
Old 07-18-2019, 10:24 AM   #5
max20s14
Drives: 14' Raven M/T - 02' is300
You most likely have to solder a bolt to it an pull it out then bondo if its the rocker panel
max20s14 is offline   Reply With Quote
Old 07-18-2019, 10:36 AM   #6
The PDR guys can probably do it with the temporary epoxy and not even scratch the paint. They have some almost magical methods.
humfrz (07-19-2019), soundman98 (07-18-2019)
Old 07-18-2019, 11:26 AM   #7
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
I was amazed at just how effective this was when I saw a similar technique applied on a wrecked car while watching a youtube rebuild series. A completely crumbled rear corner was brought to shape almost perfectly with very little effort.
Old 07-18-2019, 12:09 PM   #8
Silverz
Drives: Black frs
Yeah. Rocker panel under the door. It’s some thick metal and wouldn’t budge with the stick glue pull.
I’m thinking now that it may be from a piece of blown out truck tire on the road. I remember running over it a week before now that I think back. Door is fine but it’s right below the door.
Old 07-18-2019, 12:18 PM   #9
Take it to a PDR guy. Without seeing it I would still guess under $100.
Old 07-18-2019, 03:40 PM   #10
Silverz
Drives: Black frs
Think i’ll Get an estimate from pdr guy this evening. Guy said they would have to pull it out because of no access to rocker panel.
Anyone know how the rocker panel is fastened to the car? Is it by welds or clips?
Old 07-18-2019, 04:01 PM   #11
Welds. It is part of the frame structure not a separate piece.
DENT ON THE DRIVER'S DOOR Xx-Ness-xX Great Lakes 16 07-05-2017 09:29 PM
Fixing paint chip + dent imovertheinternet Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 08-12-2016 12:44 PM
How would I go about fixing this dent? Shims Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 13 11-17-2015 12:31 PM
Fixing minor dent/scracked paint? xjohnx Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 04-29-2014 01:39 PM
Dent in door jarviz Scion FR-S / Toyota 86 GT86 General Forum 3 08-11-2012 08:04 PM
