#71 |
Drives: 2013 BRZ Sport-Tech
Talked with the dealership and XIII yesterday after work.
Dealership: car does have a recall notice for the valve springs which has not been performed; however it's unlikely that the issue was caused by a completely failed valve spring so it's unlikely to be covered by Subaru. Subaru Mississauga is also so backed up with recall/service work that they are actually turning people away at this point and I would have to take the car back to the original dealership (Whitby). XIII: pushed the car into the shop, up on the lift, and drained the oil; spun bearing appears to be the likely culprit. Definitely not covered under recall. Used engine ordered and should be installed in a couple of days. Comes with a 1 yr warranty including labour. |
| The Following User Says Thank You to CrowsFeast For This Useful Post: | wparsons (07-16-2019) |
#72 | |
Get an oil cooler ASAP too! These cars like to heat up the oil fast on track, spun bearings aren't uncommon without thicker oil and/or good oil coolers.
#73 | |
Drives: 2015 Scion frz
#74 |
Rice King
Oil cooler on stock car?
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. |
#75 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
| The Following User Says Thank You to Frost For This Useful Post: | wparsons (07-18-2019) |
#76 |
Rice King
I'm interested. Is there a recommended oil cooler that could be daily driven?
Edit: Reading and seeing this "Forester solution"...
Glorious Honda.
Know my 5x120 GREATNESS PEASANTS. Last edited by Jordanwolf; 07-17-2019 at 11:16 AM. |
#77 | |
Forester solution isn't good for track use, can't keep up with the heat generated. I've got a mishimoto with thermostatic plate, it's been on the car for ~5 year now (well, replaced the core last year because it was leaking). Any of the quality ones with a thermostatic plate will be fine to daily drive (my car has ~185k kms on it). IIRC there was a Perrin one for sale in the GTA (either here or on FB, can't remember). That's a good option if it's still available.
#78 | |
Drives: 14 FRS Whiteout
| The Following User Says Thank You to v1beeee For This Useful Post: | Jordanwolf (07-18-2019) |
#79 |
Yep. I run my front plate lower than the factory mount so it mostly blocks the core daily, and pull the plate at any track days leaving the airflow wide open to it.
| The Following User Says Thank You to wparsons For This Useful Post: | v1beeee (07-18-2019) |
#80 | |
Rice King
No issues starting at like -25 and lower? Because my car is basically a literal daily car, driven almost every single day since purchase lol.
Glorious Honda.
#81 | |
How would it make starting any more difficult in cold temperatures? It doesn't change oil temperature at all when not moving, so cold starting won't be any different. It will take slightly longer for the oil to get up to temperature if you get on the highway right away after starting it up, but with low airflow situations it's not really different at all. If your commute is super short the oil wouldn't be getting up to temperature without it either.
| The Following User Says Thank You to wparsons For This Useful Post: | Jordanwolf (07-18-2019) |
#82 | |
Rice King
Surely there are negatives? Because right now it mostly seems too good to be true, besides the price, unless that is the main negative.
Glorious Honda.
#83 | |
The concerns are about oil ever getting hot enough in the winter to burn off any moisture in the oil, not about how it affects the car starting in really cold temperatures. Depending on how long your drives are it might not be getting hot enough even without any sort of oil cooler. You need oil temperatures to hit at least 100C to burn off any moisture. If you're really concerned about that part, I'd suggest logging it stock to see how hot the oil is getting on your daily usage to see if it's actually going to make any difference or not. Even the liquid to liquid setups like the OEM forester one won't get the oil up above 100C since the coolant is ideally never that hot. I can tell you this much, a 15 minute drive through town in the middle of the winter didn't get the oil hot enough even without the cooler. Mine would need a good spirited drive to get the oil that hot in the winter, even bone stock. Some other negatives... Potential huge failure point if something punctures the core. If you were to have a big hole put it in at WOT it wouldn't take long at all for pressure to drop low enough to be catastrophic to the engine. I was lucky that when my core developed a leak it was small enough that I noticed the puddle long before it was bad enough to ruin the engine. You can't drain the oil out, so there's always some old oil left. If that really bugs you then you can drain, fill, run for a couple minutes, drain, refill and it'll do a better job of flushing the old oil. Like I said, I've had it on my car for ~5 years now and it's daily driven all year. 185k kms, original engine, easily 50 track days on it. YMMV, but I have zero regrets putting one on.
#84 | |
Rice King
Either way I'll end up getting one, just not sure when. Researching continues.
Glorious Honda.
| 2018 Ontario Time Attack | Frost | CANADA | 23 | 09-28-2018 04:53 PM |
| Ontario Time Attack | Frost | CANADA | 12 | 08-21-2017 05:08 PM |
| Ontario Time Attack (OTA) Schedule and info | wparsons | CANADA | 18 | 07-08-2015 07:20 AM |
| [Ontario] - 2013 Time Attack Schedule | Flyer | CANADA | 1 | 05-12-2013 08:11 AM |
| Ontario Time Attack - TMP July 7th | 7thgear | CANADA | 8 | 07-07-2012 06:14 PM |
