Old 07-14-2019, 04:43 PM   #1
mitama
Is it better to replace shocks/springs/wheels at the same time?
Hi guys!
Im looking to install lowering springs/koni shcos/new wheels to my BRZ, but at the moment i can only replace springs since i just lost 9000 dollars at casino, sorry for too much info and f*** bacarrat!
Now, should i wait til i am afford to replace all at once at the same time or it doesnt really matter?
I can install lowering springs right away, and wheels after 2 weeks and shocks after like 3 months.
Please advise
mitama is offline   Reply With Quote
Old 07-14-2019, 04:53 PM   #2
NARFALICIOUS
NARFALICIOUS's Avatar
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Do Springs & Shocks together. Why spend extra money doing the same labor twice?
Although what's a couple extra hundred dollars considering you throw around 9K at the Casino and 13K on accident repairs lol
NARFALICIOUS
Noob Poster
1988 | 2016
NARFALICIOUS is offline   Reply With Quote
Old 07-14-2019, 04:53 PM   #3
spagti
Drives: Broken Blue BRZ
Depending on how much you’re lowering it, it could wear out the shocks faster and affect the ride. It’s not an absolute must but you’ll also be doing the same work twice. If it’s gonna be a while, I’d go ahead and do the springs but if it’s gonna be soon, I’d just wait to save yourself the trouble of removing everything again.
spagti is offline   Reply With Quote
Old 07-14-2019, 05:48 PM   #4
mitama
Im actually going be using my stock PP sachs damper for a while. I said 3 months but i might use my stock damper until it wears our. I am getting eibach pro kit for loweing springs. Do you know how long the stock damper will last with the pro kit?
Old 07-14-2019, 06:55 PM   #5
Feistyfrog
Drives: Toyota 86 2019
The pro kit is actually the exact same thing as the TRD springs from Toyota. I got mine delivered with my 86, new from the dealership and with full warranty. So even if they make the shocks operate "lower" with less damping distance, it doesn't seem to bother Toyota for premature wear.
I suppose your dampers have different specs than mine, but the Pro Kit gives a reasonnable drop without being too harsh (no more than the stock setup).
You might be able to keep those Sachs longer than you think.
Feistyfrog is offline   Reply With Quote
Old 07-15-2019, 01:24 AM   #6
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by mitama View Post
Hi guys!
For future reference, casino's are considered businesses, and businesses operate by taking in more money than they dole out. A place of business that doles out everything they take in is considered a charity.
I would recommend doing it all at once.
wparsons (07-15-2019)
Old 07-15-2019, 02:14 AM   #7
norcalpb
norcalpb's Avatar
Springs and shocks at the same time.
You don't need an alignment for new wheels so you can get them later.
There is also a mentality that you shouldn't rush into too many mods at once. It may be a good idea to get those Eibach springs, pair them with your PP struts, and buy new wheels. You'll need to get a 2nd alignment when your PP struts blow/upgrade to Koni, but that'll be 10k's of miles down the road.
Old 07-15-2019, 08:33 AM   #8
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
Wow, had an uncle that was that bad into gambling, at one point he owed almost every casino in Vegas money.
You can do it one at a time or together. People say lowering springs will blow the stock shocks but then people have been running on just lowering springs since 2013 without issues.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
Old 07-15-2019, 10:37 AM   #9
5 years on RSR Superdowns spring and stock everything else. All still good. If you don't beat the crap out of it the combination is fine. If you do beat the crap out of even the best of the coil overs can still fail.
They used some very good stock suspension in these cars so they can take things that many others could not. A lot of the concerns with lowering springs is when they are used on econobox sedans and such where the shocks can barely withstand normal use much less being lowered. We do not have those shocks as stock.
why? (07-16-2019)
Old 07-15-2019, 02:07 PM   #10
mitama
then I CAN NOT replace springd and shocks at the same time if I were to use PP struts for 10k miles?
Old 07-15-2019, 02:10 PM   #11
You can replace either/or any time you wish. Zero reason not to.
why? (07-16-2019), wparsons (07-15-2019)
Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks EGOBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 02-15-2018 09:21 PM
On lowering springs for and stock shocks, time for new shocks... Basket Case Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 11-16-2015 09:31 AM
Anybody tried 19 wheels on BRZ with factory springs/shocks? Matt Covert Tracking / Autocross / HPDE / Drifting 5 10-05-2015 08:25 PM
NEW EIBACH LOWERING SPORTLINE SPRINGS & OEM SHOCKS - SAVE TIME & MONEY - $450 SHIPPED STS-V Brakes, Suspension, Chassis 5 08-31-2014 10:59 AM
OEM Clutch Replace time JRollar Engine, Exhaust, Transmission 18 06-19-2013 01:25 AM
