Old 07-04-2019, 03:20 PM   #1
WRITEX
Drives: 2012 Toyota GT86
Creaking noise while turning
I'm at 55k miles and issues are popping up one after another.
The most recent problem is this constant creaking sound whenever I turn the steering wheel, and I can't pinpoint exactly where it's coming from. It's not from the steering wheel itself as far as I can tell.
Here's a video of me turning the steering wheel. You can hear the noise very well.
[ame]https://www.youtube.com/watch?v=YK9s7c5rmG4[/ame]
Any idea what this could be? Been told either bad top hat or something to do with the electric power steering by some people. (They haven't seen the video though.)
WRITEX is offline   Reply With Quote
Old 07-04-2019, 03:30 PM   #2
I hear a spring ringing in there. I would first look for a failed bearing under one of the top hats. Not the end of the world. Shit happens.
Impureclient (07-04-2019)
Old 07-04-2019, 04:40 PM   #3
WRITEX
Yup, the sound seems to be coming from the spring... o.O
I don't know how to tell if it's actually the spring or an underlying problem like the bearing. Would you be able to tell by this video?
[ame]https://www.youtube.com/watch?v=fgo596eF70I[/ame]
Please excuse my dirty mess of a car. It's been raining for weeks so I haven't bothered washing the car, let alone the wheel wells.
Old 07-04-2019, 05:09 PM   #4
The only thing that can go wrong with the spring is that it breaks. Also, now we know that you have aftermarket dampers. That's essential information. Your OP and complaining about low-mileage issues leads us to believe that you are discussing a stock system. The problem is up top for sure.
Old 07-04-2019, 08:11 PM   #5
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
WD40, spray liberally on places..
Worked wonders on my shitty D2's
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
Old 07-06-2019, 01:27 AM   #6
norcalpb
norcalpb's Avatar
Pirate ship steering wheel sound is usually top hats.
The Following User Says Thank You to norcalpb For This Useful Post:
mswbrz (01-10-2020)
Old 07-07-2019, 08:01 AM   #7
chipmunk
Drives: _
Isn't there a TSB for this? I was told that struts fall under powertrain 60k warranty, so you might be OK as long as your dealership is cool with aftermarket parts.
chipmunk is offline   Reply With Quote
Old 10-02-2019, 02:27 AM   #8
DaveFTW
DaveFTW's Avatar
Drives: 2013 86
were you able to figure out the problem?
I'd change the world if I could change my mind
DaveFTW is offline   Reply With Quote
Old 10-10-2019, 02:08 PM   #9
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
I've already had the upper strut bearings replaced under warranty once, not long after I got my '13, and now they're starting to creak/pop/groan again at just over 60K miles... Time to see if the dealer will try to deny warranty coverage because I have aftermarket swaybars now...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 10-10-2019, 02:23 PM   #10
chipmunk
Drives: _
Does it happen at certain speeds only? While steering turned or while turning? While moving forward, or while backing?
Sent from a potato
Old 10-10-2019, 02:30 PM   #11
chipmunk
Drives: _
Confirmed by dealership that it was top hats. Changed under warranty. 2 years later, same noises. Updated design didn't fix it.
Is it a durability concern? I'm thinking of putting some heavy duty grease if it is not a concern for longevity/wear/durability.
Sent from a potato
Old 10-10-2019, 08:52 PM   #12
norcalpb
norcalpb's Avatar
Sent from a potato
Yeah that’s really strange that even the updated part # become damaged after just 2 years.
Do you keep the dust covers attached to the top hat?
Dry steering (steering while not moving) could put stress on those bearings as well as your steering rack.
The top hat bearing is not only responsible for allowing the strut to spin but it also absorbs bumps hardcore that don’t get absorbed by the rubber.
Old 10-11-2019, 11:00 AM   #13
Scoob
Scoob's Avatar
Drives: 2013 FR-S Asphalt
FYI, I had a very similar issue recently and tried to chase it down. Eventually, I figured it was my coil overs needing some attention so I swapped the OEM setup back on and the creaking is still there. So I really started focusing on the steering setup instead. I sprayed WD-40 on the steering knuckle joint and like magic, the creaking went away (almost 100%).
2013 FR-S Asphalt Grey
HKS Hipermax IV GT
Sparco Assetto Gara MGC 17x7.5
Invidia N1 exhaust
Scoob is offline   Reply With Quote
Old 10-15-2019, 04:12 PM   #14
venturaII
venturaII's Avatar
Sent from a potato
I'm not really looking for a diagnosis - (I've replaced a few dozen of these over the past 35 years..lol) - just complaining that I have to do it in the first place. I think I'll wait until after winter though..
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 01:50 PM
Creaking noise from overpipe sydious Engine, Exhaust, Transmission 4 06-27-2018 03:13 AM
Creaking from front end when turning steering wheel finch1750 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 12-05-2015 04:21 AM
Creaking during turning after coilovers? Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2015 01:51 PM
creaking noise front end of suspension gtzany Scion FR-S / Toyota 86 GT86 General Forum 5 12-10-2014 02:36 PM
