Old 07-02-2019, 09:25 PM   #1
xkenx1995
Drives: 2013 Subaru BRZ
CVT issue?
I have a little above 82k miles on my transmission and was wondering if this is a normal sound. It sounds like its coming from under the vehicle, and it resonates back towards the cabin as you drive by cars / walls.
https://streamable.com/ojcki
xkenx1995 is offline   Reply With Quote
Old 07-02-2019, 09:32 PM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Are you in the right forum? 86's don't have CVTs.
The Following 2 Users Say Thank You to N1rve For This Useful Post:
pinoy_dorifto (07-03-2019), why? (07-16-2019)
Old 07-02-2019, 09:43 PM   #3
xkenx1995
Lol apologies not the best in terminology. But you get the idea. I posted a link so any help would be great. Thanks!
Old 07-02-2019, 10:20 PM   #4
When was the last transmission fluid change?
Old 07-02-2019, 10:22 PM   #5
xkenx1995
It has never been changed, but I suspect that it could be causing the issue.
Old 07-02-2019, 10:51 PM   #6
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
A recording from the engine bay may be more useful, but what you posted doesn’t sound like an auto transmission sound. If the fluid has never been changed, then it won’t hurt to have it changed anyway and it would eliminate that as the possible source of the noise.
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
humfrz (07-02-2019)
Old 07-02-2019, 11:04 PM   #7
xkenx1995
Here you go. Hmm it actually does sound like its coming from the engine bay.
Old 07-02-2019, 11:44 PM   #8
Well, whether or not the sound is coming from the transmission or not, your car's transmission is overdue for a fluid change.
That sound may be coming from a bearing (idler, alternator, compressor). Can you isolate it with a stethoscope type rig?
Old 07-02-2019, 11:47 PM   #9
xkenx1995
CVT issue?
Ill try and see if I can. I’ll pickup a stethoscope and update. If it makes a difference, the noise picks up as I step on the pedal.
The Following User Says Thank You to xkenx1995 For This Useful Post:
humfrz (07-03-2019)
Old 07-03-2019, 12:44 AM   #10
xkenx1995
I got the stethoscope and I got some noise out of these 2 pulleys. I just pulled this image from google as it is too dark for me to take a decent picture. Any good after market recommendations I can look into? A pulley kit has been on my list for a while so I might as well pull the trigger on this.
humfrz (07-03-2019)
Old 07-03-2019, 01:18 AM   #11
Well, all pulleys will make some sound when they are running, however, they shouldn't "howl" or "grind" or "wobble". Do you have access to another like car that you can compare to what you are hearing?
You may consider taking the belt off and turning each pulley to see if it feels lose or spins rough.
If the bearing in one of the pulleys is bad, just changing the "wheel" part of the pulley isn't going to help.
Old 07-03-2019, 01:22 AM   #12
xkenx1995
I’ll remove the belt and find out
humfrz (07-03-2019)
Old 07-03-2019, 07:46 AM   #13
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
If you do suspect pulleys, after you take the belt off, start the engine and listen for the noise again. If you still hear it, don't bother spinning pulleys cause that's not it. If the noise does go away with belt removed then yep, start spinnin.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
Old 07-03-2019, 09:21 AM   #14
xkenx1995
Thanks for the tip. I’ll keep that in mind.
Automatic Transmission issue- dealer is not recognizing the issue, please help! Arrex Issues | Warranty | Recalls / TSB 36 06-03-2019 04:15 AM
Paid $800+ for wheel speed sensor issue, but the issue came back. What should I do? darkbluemn Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-05-2018 08:49 PM
HELP! CEL + TC issue!!! JC0830 Issues | Warranty | Recalls / TSB 45 01-28-2017 04:33 PM
BRZ Nav MP3 issue TheRipler Electronics | Audio | NAV | Infotainment 5 09-06-2013 02:21 PM
Cel issue Z06tofrs Issues | Warranty | Recalls / TSB 2 08-27-2012 10:13 AM
