Old 06-24-2019, 03:58 PM   #43
Dake
Dake's Avatar
I've always been paranoid about actually mucking with the fuel lines; we've seen pics of a few fires on this site as a result of a bad install. Meanwhile, reflashing is so simple it barely qualifies as a nuisance on those rare occasions it may be necessary - maybe takes you five extra minutes after a fill up.
Dake is offline   Reply With Quote
Old 06-24-2019, 06:36 PM   #44
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Yea flashing takes 2 minutes 30secs for mine.
Old 06-24-2019, 06:42 PM   #45
ermax
ermax's Avatar
What's the real skinny with E85?
I don’t travel in my car but if I was going to travel I would switch to 93 before the trip. I am lucky to have E85 literally everywhere in my town so it’s not an issue. If that wasn’t the case I would get a flex sensor.
The Following User Says Thank You to ermax For This Useful Post:
why? (06-25-2019)
Old 06-25-2019, 02:39 AM   #46
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by extrashaky View Post
So you guys who run E85, if you're on a trip and can't find it, or you show up at your favorite station and they're out of it, or you're just on the wrong end of town where they don't have it when you need to fuel up and have to use E10 instead, do you reflash your car back to E10 right there in the gas station?
Originally Posted by Qwimby1 View Post
I'm interested in responses you'll get to your question. Instructions I got with my OFT says it shouldn't be left in a hot car. If that's a hard and fast rule, it could be a real problem. Especially for a black car in Florida.
I flash my tune over to 93 octane, also if I'm going on a trip I pre-emptively flash over to 93 anyway and just plan ahead.
If you had a flexfuel kit that'd be a non-issue the tune adjusts based on the fuel input.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
MCTeeJ (06-25-2019), why? (06-25-2019)
Old 06-25-2019, 08:25 AM   #47
MCTeeJ
MCTeeJ's Avatar
Drives: 2014 Scion FR-S
Originally Posted by Nevermore View Post
This is much more appealing. If I go E85 it'll definitely be flex. I'm too lazy to reflash. And then I can just use 93 in the winter and ignore the cold start issues.
To add to that; If you have a good tuner you won't even have cold start issues in winter because the cold cranking tables will be adjusted accordingly. Granted there are temps that the car just won't start at, but most pro tuners these days can get e85 to start below freezing temps. Can't confirm negative temps however.
MCTeeJ is offline   Reply With Quote
Old 07-07-2019, 02:42 AM   #48
Bluefire98
Drives: 2015 Scion FRS
Been running e85 with uel headers for a couple days now. After a small trip by the Oregon coast today, I can definitely notice how much easier it is to pass people and power out of corners. I think it's pretty awesome how easily these cars can run alternative fuels and get some real gains. The aftermarket really has become a serious selling point for this platform on the used market especially considering how relatively new the twins are.
Bluefire98 is offline   Reply With Quote
The Following User Says Thank You to Bluefire98 For This Useful Post:
Feistyfrog (08-19-2019)
Old 07-07-2019, 10:39 AM   #49
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Mine gets right at 20 highway mileage. Like others here, I'll switch to 93 before any potential trip. I'm eager to get a header now.
The only E85 station that I know of in my area is a Citco, which raises a concern (maybe unwarranted) about geopolitics. I read of disputes over Citgo ownership in Venezuela and hope the stuff at this station keeps flowing.
Qwimby1 is offline   Reply With Quote
Old 07-07-2019, 09:21 PM   #50
Dake
Dake's Avatar
Fourth tank and the fuel economy is finally matching others' numbers - 22 mpg average.
Old 08-19-2019, 06:20 PM   #51
Qwimby1
Blackstone told me today that they have no evidence you need to change oil more often with E85. I got a grade-A report from them after a longer interval between changes than I had planned. With 40,000 miles total and after 5400 miles on the oil, most of the metals were a shade lower than averages. No coolant or fuel contamination. About 2,000 of those miles were With E85. I'm planning oil changes at 4,000 henceforth, but not because of E85. That motor is reliable enough, I guess, but the oiling system could be better, and it sees 7 grand routinely.
Oh...and the TOB growled at me for the first time today.
Skinny tires for NASA PTE? dstrout Tracking / Autocross / HPDE / Drifting 5 02-02-2018 10:56 AM
Is this real? grass138 Off-Topic Lounge [WARNING: NO POLITICS] 15 05-05-2015 04:25 AM
WTB: OEM 16" wheels/tires or similar 16" skinny alloy wheels (USA, CA) smmmurf Wheels and Tires 0 04-05-2013 12:42 PM
Low grip skinny tires RaceR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-07-2012 06:21 AM
Real or not JFC Scion FR-S / Toyota 86 GT86 General Forum 4 11-27-2011 05:18 AM
