Old 06-21-2019, 02:00 PM   #15
p1l0t
p1l0t's Avatar
Originally Posted by extrashaky View Post
You don't need a tune for a cat back.
Says the guy with no MPGs
Old 06-21-2019, 02:08 PM   #16
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
air conditioning will hurt gas mileage. 5 minutes of idling every day will destroy gas mileage. If they change the fuel blend that can hurt gas mileage. Transmission fluid not being changed can hurt gas mileage. So can oil and differential fluid being old.
There are a ton of little things that can affect it. Just make sure your car is actually running right first, and control what you can.
why? is offline   Reply With Quote
The Following User Says Thank You to why? For This Useful Post:
p1l0t (06-21-2019)
Old 06-21-2019, 02:43 PM   #17
I'll join in with the "get a tune/re-flash" camp.
Since you bought the car used, it's hard telling what the former owner did to it.
20 mpg is just too low for average driving, unless you drive like @PetrolioBenzina -
humfrz is online now   Reply With Quote
Adam_L (06-21-2019), p1l0t (06-21-2019)
Old 06-21-2019, 02:47 PM   #18
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Here's a good reset.
• Unplug the negative battery terminal
• Let the car sit for 20 minutes.
• Replug the negative battery terminal
• Turn the engine on WITHOUT pressing the gas pedal
• Allow engine to idle for 2 minutes
• Turn off engine
This will reset the ECU's learning curve, allowing you to teach it your driving habits. I had to do this after my last tune-up at the dealers. When I got the car back, the idle was way high. After the reset it was back to normal.
Good luck!
MJones_RB is offline   Reply With Quote
The Following User Says Thank You to MJones_RB For This Useful Post:
humfrz (06-21-2019)
Old 06-21-2019, 03:42 PM   #19
extrashaky
Drives: 2014 BRZ Limited
My fuel economy did not change at all when I installed my cat back. It wouldn't, because a tune isn't necessary for that.
Old 06-21-2019, 03:42 PM   #20
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
Originally Posted by ephemerality View Post
By 'normal' I meant a typical non-86 driver. Only kept it under 5000 for the purposes of testing efficiecny
You'll eat more gas when shifting above 4000 rpm. Shift between 2500-3800 rpm , then you should do better.
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 06-21-2019, 04:04 PM   #21
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
LOL, I get half of what some of you do, and my only worry is how to get it lower. Humf thinks I drive like a nut, but I just drive normally compared to the rest of the zombies on the road.
What other reason for a car like this than to put your boot to the gas and the brakes as often as possible?
PetrolioBenzina is offline   Reply With Quote
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
humfrz (06-21-2019)
Old 06-21-2019, 04:10 PM   #22
Adam_L
Adam_L's Avatar
The OP concern was with achieving a lower then expected MPG.
Some may say "go buy a Prius" . I'm not saying that, but read the above on what you can do to put your car in check.
Old 06-21-2019, 04:33 PM   #23
PetrolioBenzina
Drives: 17 86
You should not have to anything, they should all be the same. However, there does seem to be some significant mpg differences. I never saw 30 mpg in mine, even during break-in.
Old 06-21-2019, 06:02 PM   #24
p1l0t
p1l0t's Avatar
Oh you're not the OP haha my bad. Still if you change your car and don't tune it I'm not sure why that would do any good.
Old 06-21-2019, 09:24 PM   #25
A shot of ol PetrolioBenzina 's dash, as he tools on down through Oregon.
They don't call him "Petrol" fer nutten -
Old 06-21-2019, 09:43 PM   #26
Impureclient
Drives: 2015 FR-S
I get almost exactly the same 8.8l/21gal as the OP with a header/tune but my driving is 90% 5-10 minutes trips and I don't really take it too easy.
Longer trips and driving normal it easily gets that 12+km/l or 30+mpg.
Old 06-21-2019, 10:24 PM   #27
I got the picture.
Ol Impureclient out to run an errand -
Impureclient (06-22-2019)
Old 06-22-2019, 03:44 PM   #28
extrashaky
I did it 100% for the sound, because I understand that that's why you install a cat back. A good muffler will make a car feel faster without actually making it any faster, just by adding aural stimulation to the overall driving experience.
If you install a cat back expecting moar horsepowers and torques, you're wasting your money. The amount of restriction you lose by going from a stock muffler to aftermarket is not going to make enough difference to register on a dyno.
The Following User Says Thank You to extrashaky For This Useful Post:
humfrz (06-22-2019)
Front Driver Side Clunking - Already checked the usual suspects PandaSPUR Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 08-24-2018 01:01 PM
What colors compliment Ultramarine besides the usual Bronze/Silver/White. Ginger Academy Cosmetic Modification (Interior/Exterior/Lighting) 5 04-08-2016 10:36 PM
Brakes feel 'stiffer' than usual after pumping 1Cor10:23 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 04-14-2014 02:57 PM
Stock wheels in different colors? (other than the usual black/gold/bronze) CaptainSlow Cosmetic Modification (Interior/Exterior/Lighting) 7 04-10-2013 11:03 AM
Business as usual at Scion Canada HQ colHolm Scion FR-S / Toyota 86 GT86 General Forum 5 07-04-2012 10:17 PM
