Old 06-16-2019, 02:43 AM   #15
Originally Posted by Aydrian View Post
What would I do to fix this?
Unless it can be opened up enough in place to get to the evaporator, the HVAC unit will have to come out and be cleaned.
BTW, I tested this for myself by sticking a sheet of paper over the cabin filter. After a minute, mine started cycling exactly like yours. I pulled out the paper and it went right back to normal.
Old 06-16-2019, 07:08 PM   #16
Aydrian
Drives: 2015 Black Scion Fr-s
Smile
I've notice now when the car is cold the ac compressor will work normally, but when it's been running for a little bit it will do the cycle if I put it in neutral. Also would I clean the part where the air filer goes? When I search up HVAC it shows the climate controls sorry for all the question ac is my blank area on cars
Aydrian is offline   Reply With Quote
Old 06-16-2019, 08:14 PM   #17
Take it to an auto hvac shop and ask them if they might be able to backflush or properly clean the front face of the evaporator.
I'd start by removing the blower motor, setting it to floor mode, covering one of the outlet holes on the floor, and then taping a leaf blower over the other. I don't know how much that would help but I know I would try it first.
HEATING /AIR CONDITIONING UNIT: COMPONENTS; 2013 MY FR-S [05/2013 - ]
Old 06-21-2019, 05:36 PM   #18
Aydrian
I took it back and it turns out the expansion valve replacement didn't work and they had to replace it again. It's working fine now thanks for all your help!
Old 06-22-2019, 02:08 AM   #19
Oh, man. That's a WAY better outcome.
Old 07-28-2019, 11:27 PM   #20
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Did you have your car first worked on that you had to bring it back ?
mswbrz is offline   Reply With Quote
compressor, rpms
Help!! shuts off once warm. Klassickk1 Issues | Warranty | Recalls / TSB 8 06-22-2018 12:36 PM
Help please. maybe battery bad but shuts off while driving Nefarious Issues | Warranty | Recalls / TSB 13 03-20-2017 11:14 PM
NAV unit shuts off when doing tight turns ReaperX43 Electronics | Audio | NAV | Infotainment 2 09-24-2014 10:32 PM
car beeping after engine shuts off mystic Southern California 10 04-14-2014 06:47 PM
Nürburgring shuts down.. Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 12 04-10-2013 03:17 PM
