Old 06-18-2019, 11:21 PM   #1
Rogues Gambit
Rogues Gambit's Avatar
Drives: '21 Bronco Badlands, '25 GR86
New lurker saying hi, plus curious about weaklinks
Hey, how are ya guys?
Rogue Here, lurker, and while I don't have a BRZ yet, plan on getting one in either fall or winter.
Hope to be a frequent here, but also curious what parts to stock pile while I wait, what weak links to address off the bat.
Thanks for taking a look, have a good night!
Rogues Gambit is offline   Reply With Quote
Old 06-18-2019, 11:31 PM   #2
alphasaur
friendly
Drives: 17' 86
Don't really know if there are any weak links, but most suggest an oil cooler if you drive hard.
Seek comfort in discomfort.
alphasaur is offline   Reply With Quote
Old 06-18-2019, 11:35 PM   #3
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Welcome, prospective buyer. If you plan to be a lurker here, check the following threads, they'll help you significantly more than a post I type here would -
http://www.ft86club.com/forums/showthread.php?t=11587 - PROBLEMS LIST
http://www.ft86club.com/forums/showthread.php?t=81493 - BOLT ONS GUIDE
http://www.ft86club.com/forums/showthread.php?t=6064 - EXHAUST COMPILATION
http://www.ft86club.com/forums/showthread.php?t=94640 - ENGINE SWAPS
http://www.ft86club.com/forums/showthread.php?t=42290 - TURBO / SUPERCHARGER DYNO NUMBERS
http://www.ft86club.com/forums/showthread.php?t=56783 - COST TO TURBO / SUPERCHARGE
http://www.ft86club.com/forums/showthread.php?t=81428 - TURBO KITS
http://www.ft86club.com/forums/showthread.php?t=81487 - SUPERCHARGER KITS
http://www.ft86club.com/forums/showthread.php?t=29340 - TUNING HELP
http://www.ft86club.com/forums/showthread.php?t=8374 - READ THIS.
http://www.ft86club.com/forums/showthread.php?t=15007 - WHEELS/TIRES
http://www.ft86club.com/forums/showthread.php?t=7535 - MOAR WHEELS/TIRES
http://www.ft86club.com/forums/showthread.php?t=130834 - WHEEL FITMENT
http://www.ft86club.com/forums/showthread.php?t=8739 - COILOVERS
http://www.ft86club.com/forums/forumdisplay.php?f=36 - BODY KITS / WINGS/ ETC
Come back after you've read at least 5-10 pages of each of these. If you don't want to, best of luck, you'll be sent to one of these threads until you've read them. We welcome you, and wish to prepare you for the battle ahead as best we can. Unfortunately, the only tool you're licensed to use here is your brain, and only you control that. So equip yourself well, research the threads I gave you, and explore the forum until you have no questions.
Common acronyms / things -
OFT = OpenFlash Tablet
I-H-E = Intake, Headers, Exhaust
TBE = Turbo-Back Exhaust
Crickets = High Pressure Fuel Pump noise
Pedal Dance = disables all traction control systems using physical inputs with gas and brake pedals
ALSO - Our exhaust is configured like this, from front to back - headers, overpipe, front pipe (has catalytic converter), catback.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
alphasaur (06-18-2019), MCTeeJ (06-19-2019)
Old 06-18-2019, 11:48 PM   #4
Rogues Gambit
Thank you, I appreciate it.
Not my first rodeo with modding,
B7 A4: JHM St2 w/HPFP, JHM HFC+B7 S4 FI Catback, JHM St1 Clutch/Flywheel, S4 Recaros, JHM Shift-Trio+Cross Rod, Bi-xenon Headlights, JOM Smoked Tail Lights, Enkei PF01, Conti DWS, Solo-werks S1 Coilovers
Ram Rebel: American Hard Tri-Fold Tonneau Cover, Hellwig RSB, Bwoody Endlinks, Go Rhino RB10, AFE Magnum Force St2 CAI w/PRO 5R filter
Now to take a look at the threads
Old 06-18-2019, 11:49 PM   #5
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
Welcome,
Make a list if you want, but don't buy anything yet. Just enjoy the car as is.
Eventually you'll know what you want to change. I wanted an SC right away, 5 yrs later I'm glad I did not buy one. I do not even feel the torque did anymore.
Just read a lot, don't believe everything people write it's a great car right out of the box.
This advice has been given many times before by so many different people on this site....
Read, read, read, just so much great information here.
Oh, 1 more thing, read those links above...
CB750F is offline   Reply With Quote
Old 06-18-2019, 11:52 PM   #6
DarkPira7e
DarkPira7e's Avatar
Nice, which engine in the A4? You will be spending about 5K on this engine to get anywhere near the torque you had in the A4, regardless of which model you owned. Forced induction is a must for over 200 wtq
Old 06-19-2019, 12:10 AM   #7
Rogues Gambit
B7, aka 05.5-08, so Fsi I think
Right now, I'm in no rush for the power, still have to save up first, though also gotta get the throttle body for my Ram http://www.moes-performance.com/Moe_...87mm-tb-13.htm to go with the intake (Father's Day, sisters birthday)
How are the STI short shifters btw, in case I decide to order one
Old 06-19-2019, 12:16 AM   #8
DarkPira7e
DarkPira7e's Avatar
It's a short shifter, works well enough. Just stay away from the TRD short shift kit. Generally anything that you want to know can be found also in Google by searching "PART NAME brz issue" and you'll find threads referencing pros/cons.
Old 06-19-2019, 12:27 AM   #9
Rogues Gambit
Alright, so while it wasn't an option, no trd
Right now, about to see which exhausts are relatively drone free, the one thing about my Audi I can't stand, didn't realize FI would be so bad
Old 06-19-2019, 12:36 AM   #10
DarkPira7e
DarkPira7e's Avatar
If you eventually go with a turbo setup, you can get an external wastegate that bleeds pressure off through the dump tube instead into the exhaust. This frees up the need to have a large diameter exhaust to keep power up. There are several smaller 2.5" exhausts that are regarded as drone-free and quiet that would be applicable. I only have experience with the stock exhaust, which with a catless header and catless frontpipe, is more than loud enough without drone.
Old 06-19-2019, 01:45 AM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
You Are The Weakest Link! Goodbye!
...sorry, it was the only part of the show i watched for.
Long time lurker making his first post. JNthe86 Scion FR-S / Toyota 86 GT86 General Forum 24 02-06-2017 12:41 AM
Long timer Lurker/BRZ owner looking for some advice Tsuin BRZ First-Gen (2012+) — General Topics 33 06-24-2015 03:49 PM
Long time Lurker seeking advice on a budget suspension setup sunset_blvd Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 12-28-2014 06:48 PM
Long time lurker new FR-S owner durdinn Scion FR-S / Toyota 86 GT86 General Forum 19 08-31-2014 12:03 PM
Long time lurker, brand new owner SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 26 09-24-2013 08:43 PM
