| Software Tuning Discuss all software tuning topics. |
Drives: 2015 K1X_Halo FR-S
P0068 code on MAP turbo
So I just had DW injectors installed and was running FIC before with problems (found out they where faulty) but regardless I was driving today and upon coming off of the highway my car popped the P0068 code and went into limp mode. I can no longer pedal past half throttle without it dying down and defaulting to 2,000 RPMs. This is a new tune for a 3 bar and 700cc injectors. Do you think the scaling could be off? Or did one of the tubes pop off and how can I check to see if I tube did pop off.
#2 |
Drives: 2013 Asphalt FRS
A tube popping off usually results in a high idle... Try reloading map if it still does it go back to original map and try it.. MONITOR AFR and KNOCK CORRECTION if you try old map.. If it does not change look for a open or short to ground on the MAP circuit.
Basically this code is set with throttle open above 10% and and a difference between MAF and MAP correlation.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | steve99 (05-16-2016) |
#3 |
Drives: FT86
as above what justin said and also get your tuner to check the MAP sensor settings for whatever MAP sensor is installed.
they may have to also adjust the min/max expected voltage levels P0068 is map sensor out of bounds or correlation error. for example a omni 3 bar map sensor (your may be different and scalings can be in metric or imperial 3 Bar OMNI MAP sensor ECUTEK scaling in BAR Omni 3 Bar MAP Sensor (Metric in Bar) 0.617 - MULTIPLIER 0.03 - OFFSET scaling limits 0 - 4.75v Manifold Pressure Sensor Limits - (CEL still comes on ) High Input CEL Above - 5.00v Low Input CEL Below - 0.00v or sometimes they just Disable CEL P0103 and P0068 but safer to leave them in |
| The Following User Says Thank You to steve99 For This Useful Post: | FRS Justin (05-16-2016) |
#4 |
Drives: UK GT86
Yup, P0068/0069 CEL limits need adjusting.
.: Stealth 86 :.
| The Following 2 Users Say Thank You to Kodename47 For This Useful Post: | FRS Justin (05-16-2016), steve99 (05-16-2016) |
#5 |
fastest frs in sbg
Drives: sick ass ultramarine frs
Can someone with a good running car, unplug the map sensor and measure each wire voltage so i can check to see if my wires are good. I need to find out if my map sensor is bad or if i have a break in the wire.
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#6 |
Drives: UK GT86
What are you seeing if you log the sensor voltage?
.: Stealth 86 :.
#7 |
fastest frs in sbg
Randomly maxing out. If i tap it lightly with finger it maxes out. If i wiggle wires it maxes out. Idk wtf is going on
#8 |
Drives: 2016 Series.HyperBlue BRZ
#9 | |
fastest frs in sbg
map sensor was shot. changed it and car ran like no ones business.
#10 | |
Drives: 2013
#11 | |
Drives: FT86
Yeah when you go fi you tend to use more of the sensor range so you often need to extend the cel trip points. Im assuming the sensor is ok and scaked correctly. You should see 1 bar or 14psi with ignition on and engine stopped, that atmospheric pressure |
#12 |
Drives: 2013
in the base map instructions i was told that i should see 0.0 boost at key on engine stopped? and to email them if it was more then .3 off. its a BAR 3 that he scaled if for cause i put it in my mod list that i sent him. when i checked it today its at 0.15 boost engine off. (this is on the openflash system)
#13 | |
Drives: FT86
Oft boost parameter is reliative to atmostpheric so yes it should read 0 or close to zero, from memory its in psi so a reading of 0.15 psi is fine atmospheric pressure varies a little with altitude. It more likely the cel limit setting, the scaling seems ok |
#14 |
Drives: 2013
ahhh ok, kinda what i was thinking. thank you. ill include that the light came on in my next revision map request.
| Another CEL code | whitefrs | Forced Induction | 20 | 11-27-2019 12:27 PM |
| Lean Code and 02 Code diagnostics. | Kiske | Engine, Exhaust, Transmission | 12 | 04-28-2016 11:19 PM |
| P0301 code -turbo frs | mario17623 | Forced Induction | 25 | 09-14-2015 07:38 PM |
| P0068 code on tuned vortech help please | Frs32907 | Forced Induction | 23 | 04-09-2014 09:19 PM |
| CEL code | ChandlerSwyng | Issues | Warranty | Recalls / TSB | 2 | 04-08-2014 02:27 AM |
