Old 04-09-2019, 09:53 PM   #141
mistople
mistople's Avatar
Drives: 2017 BRZ (Sold), 2023 GR86
Photos from Ridge Motorsports Park 4/05
I got some great shots delivered last night from Kirk Myhre at RMP. Rain = great track photos.
mistople is offline   Reply With Quote
The Following 4 Users Say Thank You to mistople For This Useful Post:
Go Frogs (06-04-2019), jflogerzi (04-13-2019), new2subaru (05-24-2019), Vic4uf (04-09-2019)
Old 04-21-2019, 12:29 PM   #142
mistople
mistople's Avatar
Track day at RMP 4/19/19 - 2:07
I had another great day at Turn2's season opener event at the ridge on Friday!
The day ranged from damp to wet and back to a damp/drying track for the latter part of the day. Great for learning how to handle changing conditions. I noticed in particular how the car reacted as the rain actually started to affect the limits of the car.
Typically I find myself going out on a wet track and it stays wet. In that case, its relatively easy to adapt and know the limits right away. Under changing conditions, I found that I had to be much more aware of how the car felt corner by corner. Useful experience.
I wasn't able to go faster than a 2:07.xx given the conditions and what are probably slower tires than last year. Although I can tell I'm a net faster driver, the confidence in the car's grip was just much lower than the day I set my pb of 2:05. That said, lap times are just a lap time and I can feel the improvement as a driver, so I'm happy in any case.
There were some amazing open wheel cars and a handful of GT3s and GTSs out there as well. Nothing like a couple million dollars worth of german engineering to make you feel inadequate
Hope to see some out you out at RPM and PR in May!
[ame]https://www.youtube.com/watch?v=kpQvWt35Dt4&[/ame]
The Following User Says Thank You to mistople For This Useful Post:
pillbox (07-15-2019)
Old 05-20-2019, 08:45 PM   #143
mistople
mistople's Avatar
AiM Solo 2 DL + JDL Ultra Quiet Front Pipe
AiM Solo 2 DL
I picked up an AiM Solo 2 DL to start logging and analyzing data at the track. I'm super excited to pick my laps apart and compare to other 86s with similar setups.
I'll be honest—the quality of the hardware isn't anything to write home about. The software that comes with it is of extremely poor quality. But I don't know of a better option that has the same adoption and quality at this price point. I'll get to try it out this Saturday. Will report back with my thoughts.
I also decided to finally complete my exhaust setup with a JDL Ultra Quiet Front Pipe. Should be a nice pairing with the JRSC!
Old 05-24-2019, 01:39 PM   #144
mistople
mistople's Avatar
Turns out the JDL UQFP doesn't fit the Perrin catback. Ugh.
I swore the donut gasket at the rear flange was the correct option, but it basically only sits up against the entrance to the midpipe without actually fitting inside. Back under the car I go to return it to stock.
Anybody in the market for a UQFP? Will be listing shortly.
Old 05-24-2019, 05:40 PM   #145
kch
Senior Misanthrope
kch's Avatar
Can't you just snip off the extra piping? My first JDL UQFP had the donut gasket, but I later converted it to fit with my perrin. Just brapp your way over to an exhaust shop and they'll have you sorted real quick
Old 05-31-2019, 11:23 AM   #146
mistople
mistople's Avatar
Maybe I'll bring it by Doug to see what he can do. Thanks for the tip.
In other news, I picked up a set of 5 lap old RE71Rs from @rice_classic last weekend. Should be a fun step up from the SX2s when the time comes!
Old 05-31-2019, 11:57 AM   #147
WC-BRZ
Drives: Black BRZ
What is the timeline like for the JRSC install? Looking forward to the numbers you put down and also your driving impressions.
Many say the JRSC is a bit underwhelming and I suspect it's because it makes power higher up and the torque down low isn't as strong as a turbo or perhaps even the Edelbrock.
WC-BRZ is offline   Reply With Quote
Old 05-31-2019, 01:07 PM   #148
mistople
mistople's Avatar
I've been punting it forever. It's possible I may do it this weekend.
I don't expect mind blowing power down low. That said, pairing it with the A350 probably gets better results than most. Since my car is optimized for track driving, I don't have a huge need for walls of power below 5k.
Old 05-31-2019, 01:33 PM   #149
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Sounds like a fun weekend project! Hopefully you can get the JDL front pipe to fit on with the Perrin CBE, I'm curious to hear what it'll sound like!
In for updates!
-Sam
eastendraceshop is offline   Reply With Quote
The Following User Says Thank You to eastendraceshop For This Useful Post:
mistople (05-31-2019)
Old 06-01-2019, 03:29 AM   #150
WC-BRZ
Drives: Black BRZ
Sounds good.
IIRC, you have CSG Spec Teins, correct?
I'm wondering if you have a review posted for them anywhere?
Really curious to hear your feedback with respect to how you perceived body roll, turn-in, change in direction, etc. after you put them on. Other things like build quality, daily comfort on full soft and responsiveness on stiffest setting would be really helpful.
I'm curious about going with something like this as opposed to saving for a bit longer and going all out on a set of JRZs or something.
Old 06-01-2019, 07:22 PM   #151
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
I might be biased, but I think you should sell the kit and instead, put in a roll cage and come racing. It will change your life... in a very good way.
PRO86 | WTCC | STL
Old 06-01-2019, 07:25 PM   #152
jflogerzi
jflogerzi's Avatar
He could do both..
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
mistople (06-01-2019)
Old 06-01-2019, 11:26 PM   #153
mistople
mistople's Avatar
As soon as I get setup with a truck and trailer, I'm game. I would consider getting a second dedicated race car at some point...T4 looks like fun So does SM, but I can't say that around these parts! I like the idea of a purist NA race car alongside a fun FI build. Best of both worlds.
I did end up starting the install got about halfway through today. The NA -> FI conversion for the JR oil cooler is a bit confusing given the lack of documentation on the process. That said, I deconstructed the front of the car, ripped out all the stock intake bits, mounted the supercharger, and mounted the intercooler once I could disassemble my existing oil cooler setup.
Should wrap it up tomorrow!
jflogerzi (06-01-2019)
Old 06-03-2019, 12:59 PM   #154
mistople
mistople's Avatar
Something looks different here...
NoHaveMSG (06-03-2019), Racecomp Engineering (06-11-2019), tehShirt (06-03-2019), weederr33 (06-03-2019)
2017 BRZ Performance Package DD Build mjanmohammad Member's Car Journals 230 11-01-2023 12:31 PM
QueenBRZ's 17' BRZ performance package DD / track build QueenBRZ Member's Car Journals 125 06-29-2021 01:34 PM
Spicy.Ricecake's 2017 CWP BRZ PP Build spicyricecake Member's Car Journals 115 12-15-2019 07:42 PM
Ohlins Road & Track - settings (clicks) for street/track/ax dp1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-27-2016 09:36 PM
MVP Track Time 2014 Road Atlanta Track Dates Feffman Southeast 2 03-27-2014 06:51 AM
