Old 05-14-2019, 12:59 AM   #1
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Check engine lights C1237 C1541 U0122 U0131
Greetings car fam,
For starters I'm getting and have been getting these check engine light codes for over 9 months now and about 12k miles.
On and off...basically they'll pop on showing:
Abs light
Traction control light
Speedometer will show zero mph
Power steering light
And check engine light.
I can turn the car off then back on (on freeway even as it's manual) and the lights will go away. Sometimes come back right , away other times go away for weeks.
I do have a widebody setup. 10.5" rears 9.5" fronts. Big 18x40x285 tires on rear.
Only started happening after I got these tires. Could it just be something I live with or is there a fix??
Celigts is offline   Reply With Quote
Old 05-14-2019, 10:23 AM   #2
NCtoBRZ
Drives: 2017 Subaru BRZ PP WRB
Maybe a wheel speed sensor was damaged when installing your new tires? Do you still have the stock wheels/tires that you can temporarily reinstall to see if the problem goes away?
NCtoBRZ is offline   Reply With Quote
The Following User Says Thank You to NCtoBRZ For This Useful Post:
Celigts (05-14-2019)
Old 05-14-2019, 11:51 AM   #3
Celigts
Celigts's Avatar
I do have stock wheels and tires.
I did take it down to a local Toyota dealership and they said it's the speed sensor not liking the oversized tires but it wasn't faulty they claim. I hate having no power steering or the ability to go above 4k rpm when driving until I restart the car ... also did I mention cruise control light turns orange as well and is unusable.
Any other widebody peeps having this issue? Any fix?
If it is a faulty speed sensor what's a replacement cost?
Old 05-21-2019, 03:17 PM   #4
Celigts
Celigts's Avatar
Bump ...
Old 05-21-2019, 03:54 PM   #5
Grady
Grady's Avatar
Tire width does not matter, Tire Diameter does. What size are your fronts?
The Following User Says Thank You to Grady For This Useful Post:
Celigts (05-21-2019)
Old 05-21-2019, 04:13 PM   #6
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Your rear tire diameter is 8.74% bigger than stock. It could have something to do with it. Have you tried putting the stock tires back on and driving for a bit?
BigTuna is offline   Reply With Quote
Old 05-21-2019, 08:31 PM   #7
Celigts
Celigts's Avatar
I have not. Problem is it's random when the lights come on.
So for like 500 miles it's good.
Then it's on constantly after I turn on the car, it goes over the 2 minute engine checks etc then BAM my dash lights up like a Christmas tree.
I could put the stocks on ... ultra lame on a widebody ... but you're right I could resort to testing that.
Fronts are 9.5" rims.
Tire size alludes me. I'll check when I run out to the car next.
Old 05-22-2019, 03:08 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Most probably the diameter size mismatch between front and rear tires is too large and it's throwing off the wheel speed sensors.
Old 05-22-2019, 11:31 PM   #9
Celigts
Celigts's Avatar
How does one fix this issue?
Aside from getting smaller tires ...
Old 05-23-2019, 12:04 PM   #10
Sportsguy83
Drives: Limited BRZ
There is no fix, only thing to be done is getting front tires which diameter closely matches the rears.
Go to this website:
https://tiresize.com/calculator/
Input your 285/40/18 and it will give you a list of alternate tire sizes, with similar diameter (less than 3% difference) that you could use on the fronts and would keep the WSS happy.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
Alpha_noob (01-15-2021), Celigts (05-24-2019)
Old 05-24-2019, 02:15 AM   #11
Celigts
Celigts's Avatar
This is disappointing as I finally have dialed in my suspension...
Lower Control arms ...
Toe arms ...
Coils obviously...
My rear tires are big ... but damnit anything smaller looks weird af with the widebody. Finally sitting flush.
Old 05-30-2019, 09:20 AM   #12
Sportsguy83
Drives: Limited BRZ
Toe arms ...
Coils obviously...
You don't need to change your rear tires, change your front tires to match the diameter. There are many options with similar diameter.
Old 06-01-2019, 10:20 PM   #13
Celigts
Celigts's Avatar
So like ... 245 x 40 x 18?
I'm on 255 x 35 x 18
Would 245 x 40 x 18 fix my issue?
Old 06-01-2019, 10:37 PM   #14
Sportsguy83
Drives: Limited BRZ
Go to this website:
Go to this website and see what it tells you is of similar diameter.
ABS , Slip indicator , check engine lights all on ( Not flashing ) Enrique_13 Issues | Warranty | Recalls / TSB 5 10-09-2018 12:47 PM
Help needed! Check engine light after weird traction lights. dillanp86 Engine, Exhaust, Transmission 3 12-08-2016 09:17 AM
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
DTC Codes U0122 and U0131 pleong Electronics | Audio | NAV | Infotainment 1 09-03-2014 01:40 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
