Old 01-27-2019, 07:57 AM   #169
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Originally Posted by Slade View Post
Can I ask a few newb questions on tuning?
All the info I learned from tuning has come from this site, but their are a few things I am not clear about. Now I have a 14 BRZ, with an axle back, drop in filter, and a Perrin intake tube. That is considered stock, so I would need the ECUTEK 1 tune correct?
http://www.ft86speedfactory.com/ecut...l#.XE1REy2ZNQI
I have nothing, so I would need the ECUTEK, the cable, and the license, I am just confused on what exactly the license is, and what do I do with it. I know its not s literal license but still. I am not sure what its benefit is for the installation.
After purchasing this what happens if I do more mods and I want to do a stage 2 tune? Would I need to buy it again? Is there a way to just add it to the tablet I will have already owned?
And last question once I have everything, the tune is fairly simple to do right? You just plug it in, start the car on ACC II (engine off) and follow the directions right? Or am I wrong? Thanks in advance for all answers.
with your mods I would just get an OFT which you get stage 1 and 2 tunes for free on it. If get catless headers than you can use the stage 2 on it , or sell it then step up to ecutek
SuperTom is offline   Reply With Quote
Old 01-27-2019, 10:13 AM   #170
86TOYO2k17
Drives: 2017 toyota 86
The license just allows you to use the ecutek tuning program on your car. The license, cable, and dongle are a one time purchase you don’t need to keep rebuying. If you change your mods and need a new tune you will need to either purchase a tune revision if it’s a “simpler mod” or a new tune all together.
You need a laptop to flash the tune to the car. The steps are pretty straight forward and easy. They will give you noob friendly step by step instructions. Most of the actual tunes for ecutek come with atleast one free revision so it will be more dialed in then a ots tune.
But depending on your future mod plans OFT could be a cheaper solution with almost as good results. Good for basic mods and “common” headers. But not recommended if going FI unless you know how to tune yourself.
Old 01-27-2019, 11:30 PM   #171
Slade
Slade's Avatar
Drives: 14 Limited BRZ
Thanks for the replies guys. Much appreciated! I’m gonna look into OFT now. Thanks again
Slade is offline   Reply With Quote
Old 02-17-2019, 02:47 AM   #172
Netgore
Update for anyone that might be curious. I've been running the E85 stg 2 tune from oft with a hi flow catted uel header and magnaflow catback and it is running great. Only issue I've had is cold starting in the mornings which I hear is a normal thing running E85 in the winter. But I'm super happy with what the tune provided. If anyone is looking for an easy and cheap reliable tune I would recommend it until you want to go for some heavier mods like boosting and such.
Netgore is offline   Reply With Quote
Old 02-20-2019, 12:48 PM   #173
vladniko86
vladniko86's Avatar
Drives: FRS
I have a guy selling sti injectors. I'm a noob to fuel stuff, are our injectors top feed or side feed? Want to know which ones I can pick up
vladniko86 is offline   Reply With Quote
Old 02-20-2019, 04:42 PM   #174
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Side
Dr. BRZ is offline   Reply With Quote
Old 04-22-2019, 07:42 AM   #175
bdtbdtbdt
Drives: 2015 Scion FRS
I'm thinking of going back to my stock FRS muffler from my Nameless track muffler because of the noise. Does anyone know how much horsepower I would lose if any.
bdtbdtbdt is offline   Reply With Quote
Old 04-22-2019, 07:50 AM   #176
steve99
Drives: FT86
Almost none, the stock catback flows pretty well.
Old 05-11-2019, 04:36 AM   #177
Jdmuscle
Drives: Supra, Viper, Z06, GT350 and GX460
How are Subaru dealers if your car is tuned for warranty claims?
IG: @vipraz 94 Supra Turbo // 15 Viper GT // 16 Corvette Z06 // 18 Shelby GT350 // 19 BRZ LTD // 18 GX460 Premium // 13 Vrod Muscle
Jdmuscle is offline   Reply With Quote
Old 05-11-2019, 09:35 AM   #178
Pat
Pat's Avatar
Drives: 2023 BRZ
Terrible regardless of tune.
Old 05-11-2019, 10:52 AM   #179
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Mine's pretty good, they pulled my motor for an oil leak under warranty, even though the car had a header and tune on it. Every dealer is different.
Old 05-27-2019, 02:26 PM   #180
Lav
Drives: Frs
Originally Posted by Pkush View Post
I suck at explaining what I want.
So my question is what it'll cost to run the flex fuel versus OFT and UEL header.
For the Flex fuel it'll be
649 for kit
749 for ecutek
UEL Header ~600
Anything else? Is there another tune that I need?
Of course labor if not installed by myself but that comes with either setup.
So total is 2,000, just double of the OFT OFH Combo?
Oh man reading this exchange. You explained perfectly well from the start. Other guy was not reading though he was trying to be helpful
bibbity boppity give me the zoppity
Lav is offline   Reply With Quote
Old 05-11-2020, 09:00 AM   #181
phm14
Loves the Smell of Track
phm14's Avatar
Drives: '13 86
'17+ Update?
With the improved header in the '17+ cars, what happens to the "+5-8hp" gain, over a tune on stock header scenario? Seems like going to a UEL catless header will get me more/different sound, some improved mid range, possible inspections issues (in Texas?), but little, if any (or loss of) peak HP? From a peak HP standpoint, given the improved OEM header, seems like I'm better off just getting a tune for the stock system I'm running with Nameless axleback...which is already at the max noise level for me. With the improved fueling mentioned in the '17+ cars, are the gains of ~10hp for a tune alone also diminished with the '17 updates?
2020 86 Hakone MT build thread: https://www.ft86club.com/forums/show...31#post3326231
2013 Toyobaru 86/FR-S 6MT, Red, aka Candy O SOLD
http://www.ft86club.com/forums/showthread.php?t=7934
phm14 is offline   Reply With Quote
Old 05-11-2020, 09:11 AM   #182
Lantanafrs2
Drives: 2013 frs red
You're probably right. Dont spend a grand for a little more torque. A good tune is probably your best bet
Lantanafrs2 is offline   Reply With Quote
Useful/Frequent mods: a BRZ/FRS/GT-86 basic ! Simon99 BRZ First-Gen (2012+) — General Topics 104 10-10-2016 12:45 PM
What mods next? Exhaust? Intake? Ludacrits Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2013 08:25 PM
Question about basic performance mods bdanisi Engine, Exhaust, Transmission 2 01-25-2013 05:40 PM
