Old 12-10-2016, 04:42 AM   #15
Jarlax
Drives: brz
Did you have any concerns about quality of gas in your region before you purchased the oft? This is pretty much whats holding me back from buying an oft.
Jarlax is offline   Reply With Quote
Old 01-27-2017, 09:36 AM   #16
Lorico
Drives: 2015 FRS
which header would give MOST gains with the OFT?
Lorico is offline   Reply With Quote
Old 01-27-2017, 10:32 AM   #17
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
Originally Posted by Lorico View Post
mr impreza, can i ask why you didn't buy the OFT_OFH combo? seems pretty cheap about 1200 canadian
Hey sorry. Never knew you asked a question haha.
Main reasons;
1. I don't like the UEL sound
2. I don't like the amount of noise it creates
3. I want a catted Header
The header that I will get in the future is the Fujitsubo Catted Header. It's EL and doesn't increase the noise levels. (well it does, but barely. It's the quietest header on the market apart from stock)
Not really. I just use Shell V-Power 91 and never had any issues. Also with Shell 91 you don't get crickets. If you have that issue.
Without doing a custom tune, the Open Flash Header Ver.3 would give you the most gains since when they make the tunes for Stage 2, they use there own headers.
However, if you go with a Custom tune, ($200.00 extra option) you can achieve similar gains with most headers. Word on the street is Ace headers create the most gains.
I actually plan to get the Custom Tune when I put the catted header on in the long away future
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Old 04-01-2017, 12:27 PM   #18
timmydatooth
Drives: Scion Frs
Hey guys really considering buying a OFT for my 2013 scion FRS.
The only mods I have right now are invidia Q300, invidia catless front pipe, afe dry drop in filter, and a mishimoto silicone intake hose. It is an automatic transmission by the way.
If I buy this and just do the pre-programmed stage 1 tune would I feel a noticeable difference in the drive? Don't really want to mess with any of the custom tune settings because I really know nothing about tuning at all. Just want to be able to plug it in, update the tune, and enjoy it.
timmydatooth is offline   Reply With Quote
Old 04-01-2017, 03:42 PM   #19
LancePower
Drives: 2020 BRZ tS
I have a Manual Trans and only the TRD exhaust and the OFT makes a noticeable difference in the drive quality. Much more linear power delivery.
LancePower is offline   Reply With Quote
Old 04-01-2017, 03:46 PM   #20
timmydatooth
Drives: Scion Frs
Do you know if you get better MPG? also it shouldn't do anything to affect the car in a bad way in the long run right?
Old 04-01-2017, 05:49 PM   #21
phrosty
It does run leaner so I wouldn't be surprised if it makes a miniscule improvement.
phrosty is offline   Reply With Quote
Old 04-01-2017, 06:18 PM   #22
timmydatooth
Drives: Scion Frs
Does doing the tune make the tone of your exhaust sound different?
Old 04-02-2017, 05:49 AM   #23
LancePower
Drives: 2020 BRZ tS
I haven't done calculations, but no noticeable difference either way.
Old 08-16-2017, 01:13 PM   #24
Brzed85
Drives: Brz
Still get crickets
Main reasons;
I still get crickets on v-power 91. And it's all I've pumped since I got Subrina(Name of my car)
Brzed85 is offline   Reply With Quote
Old 08-16-2017, 01:17 PM   #25
Brzed85
Drives: Brz
I can't wait to install my UEL headers. I got them from FedEx last night along with my OFT which I used as soon as I updated it and added the tunes. Subrina has changed and will change more one the headers are on.
Old 05-06-2019, 09:23 PM   #26
-AREN-
Drives: 2018 BRZ Limited
Have you experienced that throttle delay that everyone seems to be talking about after the Stage 1 tune? I flashed my 2018MT BRZ to Stage 1 and am experiencing that throttle delay. Did this about 2 days ago.
-AREN- is offline   Reply With Quote
Old 05-09-2019, 03:05 PM   #27
pancake
Drives: 2015 BRZ Limited MT
If you're referring to the 'dead pedal' feeling (where the first inch or 2 of gas pedal throw does nothing), it lasts quite a while. It took me several days / ~100 miles to completely go away.
pancake is offline   Reply With Quote
Old 05-11-2019, 03:26 AM   #28
Kodename47
Kodename47's Avatar
Drives: UK GT86
People just need to search
After flashing/reset of the ECU:
- Turn on ignition (press start button twice).
- Pump throttle pedal 5-10 times in quick succession, making sure to go all the way down and all the way up.
- Start the engine and allow to idle for ~1 min
That has always worked for me. They don't even have to be done at the same time. Pressing the pedal lets the ECU learn max/min of the pedal and TPS, which is what causes the dead pedal. Idling allows it to learn the idle position. If the engine is warm the last step may take less time, if the AVCS actvates then you're food to go.
.: Stealth 86 :.
Kodename 47 DJ:
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 FRSTEVE Software Tuning 105 08-04-2017 04:48 AM
MotoEast NA Stage One Tune Review - Two thumbs Up! brillo Software Tuning 2 01-06-2016 12:16 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 08:15 PM
Perrin Stage I tune review brillo Engine, Exhaust, Transmission 18 12-09-2013 11:06 PM
Visconti Stage 1 NA Tune Pump & e85 Review CBR600RR Engine, Exhaust, Transmission 22 04-26-2013 10:36 AM
