Old 04-22-2019, 07:10 PM   #15
Impureclient
Drives: 2015 FR-S
Using a 3 pc. J. A. Henckels Classic set and they are pretty decent. It's around $100 and anything more than that seems like it's just showing off.
Honestly something from Walmart would probably work 99% as good unless you have money burning a hole in your pocket or are just really
into cooking and want the "best".
It's pretty much the same with any hobby. There's people in here that think we must drive on forged wheels that cost $4k a set and anything
less than will crumbled or fly off the car. You can spend 1/4 of that and it will be perfectly fine in also 99% of applications.
The Following User Says Thank You to Impureclient For This Useful Post:
Tcoat (04-22-2019)
Old 04-22-2019, 07:43 PM   #16
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Been using the same $1 8" chefs knife for almost 20 years now.
Use it for everything.
I learned at an early age how to use a whetstone so that helps alot.
Old 04-22-2019, 08:00 PM   #17
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
J. A. Henckels here as well but they are from decades ago Made in Germany.
All of my sharpening stones are from Japan but I tend to use this the most but usually for my utility knifes.
[ame]https://www.youtube.com/watch?v=5LBDnJv5B58[/ame]
krayzie is offline   Reply With Quote
Old 04-22-2019, 08:06 PM   #18
Originally Posted by Impureclient View Post
….Honestly something from Walmart would probably work 99% as good unless you have money burning a hole in your pocket or are just really into cooking and want the "best".
I agree, I've had one like this for lots of years now. The tip on the handle is good for busting up bony pieces, the handle edge is great for tenderizing meat and the blade is sharp on both sides, for cutting things both ways.
NWFRS (04-22-2019), soundman98 (04-22-2019)
Old 04-22-2019, 08:11 PM   #19
Issued when he was a middle aged officer hitting the trenches of the Somme.
humfrz (04-22-2019), new2subaru (04-22-2019), NWFRS (04-22-2019), Sapphireho (04-25-2019), soundman98 (04-22-2019)
Old 04-22-2019, 08:53 PM   #20
new2subaru
Weight Weenie
Drives: 15 FR-S
I've been using this knife for a decade+ Best knife I've ever owned. I like the Carbon blade. You can get it razor sharp and it's economical.
http://www.leevalley.com/en/wood/pag...cat=63281&ap=1
Old 04-22-2019, 08:59 PM   #21
krayzie
Drive From Home
krayzie's Avatar
Two pages and nobody mentioned this?!?
[ame]https://www.youtube.com/watch?v=4q7GCuWFsSs[/ame]
The Following User Says Thank You to krayzie For This Useful Post:
Ultramaroon (04-22-2019)
Old 04-22-2019, 08:59 PM   #22
HaXx
Drives: jrsc_brz
this is a rediculous topic, but id like to weigh in, lol. many years ago i got my mom a wustof ~10 piece set with the wooden block thing for christmas and thats what we still use many many years later. 10/10 would recommend.
HaXx is offline   Reply With Quote
Old 04-22-2019, 09:02 PM   #23
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by JoeC View Post
For Christmas last year, my wife bought me the first and only fancy knife I've ever had; a Shun Kaji chef's knife and I think it's AMAZING. I can't imagine the stuff the stuff you have if this is your "junk" knife...
It's not that the Shun is a bad knife - it holds an edge reasonably well and resists staining. It's just really heavy and clumsy by comparison. It's what I use when I need that weight. The one I have is slightly uncomfortable for the grip I use as well. I much prefer the 'wa' handle style, but there's this decorative metal bit on the Shun that's just bad.
The Konosuke I use is considered a 'laser' style - it's quite thin. It's second from the bottom in this photo. Bottom is a nice 150mm Petty - that gets a lot of use also. Top is the most expensive of the bunch and is absolutely incredible to work with, but... it's just a little bit big for most of the work I do at 270mm and rather tall. Insane edge it holds though. Second from top is a slicer. Third is a single bevel and only works for some stuff... but also holds a wicked edge. I have a few more I work with regularly as well, including a 180 petty and a couple paring knives of different shapes/handles.
The Following User Says Thank You to cjd For This Useful Post:
JoeC (04-22-2019)
Old 04-22-2019, 09:22 PM   #24
serialk11r
Drives: '06 AM V8V Coupe
I have a carbon steel Chinese "cleaver" style knife to do most of my cutting, got it on Aliexpress for 30 bucks after seeing some people talk about it on the internet. The handle is kind of crappy and it leaves behind some rust but the edge holding is phenomenal.
I sharpen it every 4-5 months but by the time I actually sharpen it, it's still plenty sharp, I just do it for fun so it can push cut thin paper like grocery receipts. The sharpness is actually a bit of a problem because when I clean it, it tends to shave off any bit of sponge that goes over the edge.
It's kind of fun to use it as a box cutter since it has a low angle grind and the blade is thin. When I need to get rid of Amazon boxes, I can easily hack through one face of a box with one swing
Other than that I got a few cheap stainless steel knives. Some paring knives for cutting steak on the plate and a 12" cheapo sashimi knife. I have been thinking about getting a carving knife and a butcher's knife, but haven't gotten around to it.
Old 04-22-2019, 09:35 PM   #25
soundman98
ProCrastinationConsultant
soundman98's Avatar
this is currently my go-to knife set.
https://www.walmart.com/ip/Hampton-F...&wl13=&veh=sem
so 2 years in, and they're all still plenty sharp.
humfrz (04-22-2019)
Old 04-22-2019, 09:38 PM   #26
new2subaru
Weight Weenie
Drives: 15 FR-S
I sharpen it every 4-5 months but by the time I actually sharpen it, it's still plenty sharp, I just do it for fun so it can push cut thin paper. The sharpness is actually a bit of a problem because when I clean it, it tends to shave off any bit of sponge that goes over the edge.
Based on your username I figured you'd have more...
The Following 2 Users Say Thank You to new2subaru For This Useful Post:
soundman98 (04-23-2019), Ultramaroon (04-22-2019)
Old 04-22-2019, 09:45 PM   #27
serialk11r
LOL living around NYC is tough man, my kitchen is bigger than the average studio kitchen already and it barely fits my limited collection of cooking supplies.
Old 04-22-2019, 10:10 PM   #28
new2subaru
Weight Weenie
Drives: 15 FR-S
I bet!
Sharing hunting/shooting/knives/oudoor items site Impureclient Off-Topic Lounge [WARNING: NO POLITICS] 1 07-21-2015 12:15 AM
