Drives: 2013 Scion FRS
What is this part?
Need help figuring out the name and part number of this part. Came off the driver side of the engine. The seal is melted and is leaking oil.
https://imgur.com/a/spkeeRa |
#2 |
It looks to be a camshaft position sensor.
Describe the position on the engine and the person at the parts department will know what to look for. humfrz |
#3 |
Drives: 2014 BRZ Limited, Satin White Pearl
Part Number: 10921AA231
Vvt control solenoid. It's not a sensor.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
| The Following 2 Users Say Thank You to Tonrogs For This Useful Post: | RZNT4R (04-21-2019) |
#4 |
#5 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
#6 |
My bad -
![]() humfrz |
#7 |
Your solenoid is probably fine, you just need a new o ring for it.
#8 |
#9 |
Although not a valve. All manufacturer's tech docs refer to it as an oil control valve, or 'OCV.'
#10 |
Benz Tech
Drives: 2017 BRZ Premium
Clipped, not melted. As in installed incorrectly.
It’s a magnet the runs in and out to control the timing adjustment. |
#11 |
I'm slightly annoyed that more and more makers are using this style of VVT solenoid. I don't like them.
Sure, they simplify the head casting a lot, but I don't like how they rely on pushing a spinning valve with a stationary pin. Not as dumb as nissan eVTC "Hey let's retard the exhaust cam by dragging it against the timing cover with a clutch", but pretty dumb. But hey, maybe I'm just insane, they're pretty reliable on most makes, wear hasn't shown itself to be a problem and they're easy to service, so I can just shove my lunatic ramblings up my ash I guess... |
| The Following User Says Thank You to RZNT4R For This Useful Post: | soundman98 (04-21-2019) |
#12 | |
ProCrastinationConsultant
#13 | |
Benz Tech
Numbers in circulation are obviously skewed 1000% or more, but I’ve never had an issue with the AMG system. We were replacing magnets on m272 and m273’s daily a while back. Microabrasions on the sealing surface of the actuation piston blah blah blah. At least they’re cheap, and labor on all 4 in the worst case scenario is only like 4 hours. Opened the bulletin, “Scoring formation at the piston by dirt entry leads to stiffness/seizing of the solenoid plunger. The piston in the new camshaft adjustment solenoid has a nitrided surface to prevent seizing.“ These Subaru ones look downright easy to replace.
#14 |
Strange, I've had to replace a bunch of linear actuator (lots on chevy ecotec, a few on chrysler world engines, a single on a toyota 5.7), but this style, not a single one so far, all brands combined, even including all the old and busted volkswagen CCTAs.
| The Following User Says Thank You to RZNT4R For This Useful Post: | maslin (04-21-2019) |
| Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors | vlad128 | BRZ First-Gen (2012+) — General Topics | 7 | 06-29-2018 05:05 PM |
| FS: PART OUT Complete OEM Audio Plus Sound Solution & More! PART OUT | dinoniel | Audio/Visual, Electronics, Infotainment, NAV | 15 | 06-04-2017 04:27 PM |
| Part autocross, part road course race | justinco | Tracking / Autocross / HPDE / Drifting | 2 | 03-28-2017 10:47 PM |
| Found some rust on a part... what part is this, and is it a problem? | flashburn | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-02-2015 10:56 PM |
| Got hit (bumped)! Need part number for the black part of bumper. | scottsampaio.com | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-25-2014 01:05 AM |
