Old 04-21-2019, 01:32 PM   #1
Sharpilot
Drives: 2013 Scion FRS
What is this part?
Need help figuring out the name and part number of this part. Came off the driver side of the engine. The seal is melted and is leaking oil.
https://imgur.com/a/spkeeRa
Sharpilot is offline   Reply With Quote
Old 04-21-2019, 01:50 PM   #2
It looks to be a camshaft position sensor.
Describe the position on the engine and the person at the parts department will know what to look for.
Old 04-21-2019, 01:50 PM   #3
Tonrogs
Drives: 2014 BRZ Limited, Satin White Pearl
Part Number: 10921AA231
Vvt control solenoid. It's not a sensor.
'14 SWP BRZ 6MT | FBM built 9:1cr engine w/ GTX3076R Turbo | Mazworx CD009 trans swap | EcuTek | Jackson Racing Dual Oil Cooler/Radiator | SPAL fans | JDL 3" Dual Resonated OP/FP | Perrin 3" | Radium Dual Cans | 18" Rota Titans | M85 3.73 diff | DSS 1k axles | And more....too much more....ugh.
Tonrogs is offline   Reply With Quote
Old 04-21-2019, 01:56 PM   #4
Sharpilot
Thank you sir!!
Old 04-21-2019, 01:57 PM   #5
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
This.
Old 04-21-2019, 02:00 PM   #6
My bad -
Old 04-21-2019, 02:04 PM   #7
Tonrogs
Your solenoid is probably fine, you just need a new o ring for it.
Old 04-21-2019, 02:21 PM   #8
Sharpilot
Yeah I know the solenoid is fine. Just needed to find which part it was so I could find a new O-ring.
Old 04-21-2019, 02:46 PM   #9
Although not a valve. All manufacturer's tech docs refer to it as an oil control valve, or 'OCV.'
Old 04-21-2019, 04:01 PM   #10
maslin
Benz Tech
Drives: 2017 BRZ Premium
Clipped, not melted. As in installed incorrectly.
It’s a magnet the runs in and out to control the timing adjustment.
maslin is offline   Reply With Quote
Old 04-21-2019, 04:30 PM   #11
RZNT4R
I'm slightly annoyed that more and more makers are using this style of VVT solenoid. I don't like them.
Sure, they simplify the head casting a lot, but I don't like how they rely on pushing a spinning valve with a stationary pin. Not as dumb as nissan eVTC "Hey let's retard the exhaust cam by dragging it against the timing cover with a clutch", but pretty dumb. But hey, maybe I'm just insane, they're pretty reliable on most makes, wear hasn't shown itself to be a problem and they're easy to service, so I can just shove my lunatic ramblings up my ash I guess...
Old 04-21-2019, 04:42 PM   #12
soundman98
ProCrastinationConsultant
soundman98's Avatar
something-something, recommended serviceable life... similar reasons they no longer intentionally overbuild motors like they did with the 2jz.
Old 04-21-2019, 05:32 PM   #13
maslin
Benz Tech
We have far less issues on the m156 linear style actuator than the magnets used on series engines.
Numbers in circulation are obviously skewed 1000% or more, but I’ve never had an issue with the AMG system. We were replacing magnets on m272 and m273’s daily a while back.
Microabrasions on the sealing surface of the actuation piston blah blah blah. At least they’re cheap, and labor on all 4 in the worst case scenario is only like 4 hours.
Opened the bulletin, “Scoring formation at the piston by dirt entry leads to stiffness/seizing of the solenoid plunger. The piston in the new camshaft adjustment solenoid has a nitrided surface to prevent seizing.“
These Subaru ones look downright easy to replace.
Old 04-21-2019, 05:46 PM   #14
RZNT4R
Strange, I've had to replace a bunch of linear actuator (lots on chevy ecotec, a few on chrysler world engines, a single on a toyota 5.7), but this style, not a single one so far, all brands combined, even including all the old and busted volkswagen CCTAs.
Part Diagrams / Numbers for BRZ (like RealOEM for bmw), Part Vendors vlad128 BRZ First-Gen (2012+) — General Topics 7 06-29-2018 04:05 PM
FS: PART OUT Complete OEM Audio Plus Sound Solution & More! PART OUT dinoniel Audio/Visual, Electronics, Infotainment, NAV 15 06-04-2017 03:27 PM
Part autocross, part road course race justinco Tracking / Autocross / HPDE / Drifting 2 03-28-2017 09:47 PM
Found some rust on a part... what part is this, and is it a problem? flashburn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-02-2015 09:56 PM
Got hit (bumped)! Need part number for the black part of bumper. scottsampaio.com Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 04-25-2014 12:05 AM
