Old 04-15-2019, 10:16 PM   #1
msaikhan
Drives: frs
how much POG oil to put into AC after condenser replacement
Hey all,
I had a hole in my condenser, so i replaced the condenser. How much POG oil do i add? Dealership tried to suck up all the freon but said there wasn't any left because of the hole in the condenser. Haven't used ac during winter, except window defrosting.
msaikhan is offline   Reply With Quote
Old 04-15-2019, 10:55 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Well, since yours had a hole, I would either buy two big bottles of ac recharge. At the local auto parts store. It doesn't take a whole lot but I'm no mechanic. Also they have a cool little filler gauge that tells you if you need more or less
But since you didn't mention any diy or know of said ac refills I would recommend you take it to a pro ac place have them top you off.
The Following User Says Thank You to Mr.ac For This Useful Post:
humfrz (04-16-2019)
Old 04-16-2019, 01:15 AM   #3
AFRichZC6
AFRichZC6's Avatar
Seems credible. Name checks out.
AFRichZC6 is offline   Reply With Quote
The Following User Says Thank You to AFRichZC6 For This Useful Post:
humfrz (04-16-2019)
Old 04-16-2019, 09:05 AM   #4
msaikhan
Drives: frs
Well, thanks for response, but i already know how much 134a i need. I was asking about the POG oil that needs to be added along with refrigerant.
Old 04-16-2019, 11:01 AM   #5
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
They should not sell these refill kits because people usually do not use them correctly. If you need to refill your A/C, you have a leak in your system. That means, properly evacuating the system (not venting it into the atmosphere), finding the leak, fixing it then applying a vacuum to the system for at least an hour.
In the case of the OP, it definitely needs vacuum for a while to draw out any moisture and air inside his system and he knows that.
I have done this a few times but have never found a definite answer because no one really knows. Since you probably lost PAG oil through the following:
1. hole in your condenser releasing all of your refrigerant/vaporized oil.
2. oil physically in your old condenser that you will toss.
My guess is that you probably lost half of the oil in your system. I think it would be more harmful to have too little compared to too much. I'd put 50-70% of the factory fill in the system
projek_01 is offline   Reply With Quote
The Following User Says Thank You to projek_01 For This Useful Post:
msaikhan (04-16-2019)
Old 04-16-2019, 02:29 PM   #6
ls1ac
ls1ac's Avatar
It is unusual to loose all the oil with a leak, better parts stores sell small cans of oil Freon mix to add some back to the system. The cans say to add one can to a discharged system. The cans come in different colors to match the oil in the system. I am not sure if there is a difference in the oil by color , but I use the same color. If you have a large compressor you can use an air driven vacuum like the one from Harbor freight. You will need a gauge set with three lines to do it properly. A vacuum pump is better but costs a lot more.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 04-16-2019, 02:36 PM   #7
msaikhan
Drives: frs
i got compressor and gauges loaned from autozone.
Got a bottle of r134a and POG 46 (7oz). I'm just gonna go ahead and put half of the bottle.
Old 04-16-2019, 02:40 PM   #8
projek_01
projek_01's Avatar
You should put the system under vacuum for at least 30 min. The humidity and air in the system right now will cause problems/corrosion later on.
Also any air in the system will overwork the AC pump. Paying ~$100-150 for a A/C recharge is well worth it in my opinion because the machine does a much better job.
Old 04-16-2019, 02:48 PM   #9
msaikhan
Drives: frs
Yes, i will pull vacuum for 30min or so. I'll just DIY this time, if ac compressor dies in the next year, i'll take it to a shop. I have trust issues after valve spring recall, blew my engine.
Old 04-16-2019, 02:49 PM   #10
Grady
Grady's Avatar
I agree, about 4oz should keep you safe.
Old 04-16-2019, 03:08 PM   #11
maslin
Benz Tech
Drives: 2017 BRZ Premium
I have never put more than 2oz in an AC system. 0.5oz is now the way we go. 4oz is a lot of dye, 2 of the single use bottles.
maslin is offline   Reply With Quote
Old 04-16-2019, 08:41 PM   #12
ls1ac
ls1ac's Avatar
Remember the small cans are a mix of Freon and oil, not all oil. Usually delivered to the system slowly and inverted.
Old 04-17-2019, 09:16 AM   #13
msaikhan
Drives: frs
i put in oil not dye.
Old 04-17-2019, 09:17 AM   #14
msaikhan
Drives: frs
got a bottle of pog 46 oil only. not a mix of freon and oil.
WTB: A/C Condenser SmireyFase Want-To-Buy Requests 1 05-16-2017 09:28 PM
AC Condenser MicheleAbbate Engine, Exhaust, Bolt-Ons 1 05-17-2016 08:11 PM
FS: OEM AC Condenser and lines MicheleAbbate Engine, Exhaust, Bolt-Ons 7 09-26-2014 03:16 PM
WTB: A/C Condenser 86_ZN6 Engine, Exhaust, Bolt-Ons 13 08-21-2013 10:26 AM
Wtb a/c condenser CivicEx13 Want-To-Buy Requests 0 08-12-2013 06:43 PM
