Old 04-15-2019, 12:57 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Don't lurk, post reports about your new car.
PetrolioBenzina is offline   Reply With Quote
Old 04-15-2019, 01:17 PM   #16
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
He did have the recall done. Probably has several hundred miles on the car since it was done. Was probably a success story that has now been turned into a horror one.
It is sad that the odds of an engine failure seem to be significantly increased if you do the recall which is meant to prevent a possible engine failure.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 04-15-2019, 02:13 PM   #17
I still am baffled why they recalled for this. There have been other issues that would cause the car to stall that they just issued TSBs for (the TOB and injectors on the early ones).
People also are forgetting, didn't know about, or are just ignoring the oil system failures that resulted in spun bearings on cars that had came straight from the factory. We have about 30 spun bearings reported on this forum before the recall was even thought of much less made. Most of those failures were cars from the same date range as the recall and the majority of the info we received included silicone blocking channels. I bet many of the others where no cause was found (or were blamed on low oil) also had sealant where it didn't belong but it was never found since nobody dug deep enough to see it.
So, with the current known number of post recall failures the odds of an issue are only slightly worse than they were right from the start.
NWFRS (04-16-2019)
Old 04-15-2019, 02:57 PM   #18
xdavidx
Emperor McDuck
xdavidx's Avatar
Drives: 2019 86 GT; 2018 BMW S1000RR
Given the frequency of issues after having the recall work done vs the frequency of issues for which the recall was created combined with the current value of the older cars that are the only ones effected, I'd think it makes a lot more sense to take your chances with not having the recall done. Prime example of 'if it ain't broke, don't fix it'.
If your car only last a month longer and you lose $10k in value when it blows up, you are still better off than 1 months depreciation on a fiat 124.
xdavidx is offline   Reply With Quote
The Following User Says Thank You to xdavidx For This Useful Post:
Tcoat (04-15-2019)
Old 04-15-2019, 03:02 PM   #19
funwheeldrive
FIX
IT
AGAIN
TONY
Old 04-15-2019, 04:56 PM   #20
PetrolioBenzina
Drives: 17 86
I traded my 13 because it needed new tires.
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
Adam_L (04-15-2019), Tcoat (04-15-2019)
Old 04-15-2019, 04:58 PM   #21
I thought you wanted that more aggressive 17 front bumper!
Old 04-15-2019, 05:04 PM   #22
PetrolioBenzina
Drives: 17 86
That, too. Agression, grrrrrrrrrrrrrr...............
Scares all the Camry's.
Old 04-15-2019, 05:06 PM   #23
Not the new ones!
soundman98 (04-15-2019)
Old 04-15-2019, 05:22 PM   #24
PetrolioBenzina
Drives: 17 86
JFC that's ugly. It might be worse than a Type R, too.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Rampage (04-15-2019)
Old 04-15-2019, 05:25 PM   #25
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I thought it was because it needed a cabin air filter? It never runs the same after you change the original.
Old 04-15-2019, 11:16 PM   #26
Oh, I think it's quite handsome, for a 4-door sedan.
HKz (04-16-2019), OwlDance (04-16-2019)
Old 04-16-2019, 02:09 PM   #27
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I've been following this recall for a while and watching the post-recall engine-failure thread. I'll take my chances without the fix. Honestly not even really worried about it. The cost of a new engine/rebuild/upgrades are negligible anyway, especially when measured against the cost of jumping ship and taking that initial new-car depreciation hit again.
But whatever. I understand the appeal of Fiat. I'd go back to one of the old ones in an instant if I could justify a fair-weather car again. My 1970 124 Sport Spider was nothing but reliable after some performance upgrades and a professional tune-up. Best driving car I ever owned. Those Lampredi twin-cam engines were ahead of their time. The original 124 Spiders had dual overhead cams, timing belts, and all-wheel disc brakes from 1966.
NWFRS is offline   Reply With Quote
The Following User Says Thank You to NWFRS For This Useful Post:
Tcoat (04-16-2019)
FS: SOLD SOLD Sprintex 210 Stage 2 Supercharger-Finally have a fast car! SOLD SOLD continuecrushing Engine, Exhaust, Bolt-Ons 7 02-19-2017 01:46 PM
Cravenspeed MINI Flexpod Mount SOLD SOLD SOLD SOLD xkalelx Interior Parts (Incl. Lighting) 3 07-06-2016 11:50 AM
SOLD FS: Ark Grip Catback - Socal-SOLD SOLD SOLD continuecrushing Engine, Exhaust, Bolt-Ons 9 03-05-2016 02:02 PM
Forgestar F14 18x8.5 & 18x9.5 +35 SOLD SOLD SOLD SOLD Chillemall Wheels and Tires 27 07-06-2015 12:58 PM
SOLD SOLD Homelink mirror with compass SOLD SOLD theanswer3 Interior Parts (Incl. Lighting) 1 05-09-2015 04:05 PM
