Old 04-13-2019, 10:03 PM   #8317
jflogerzi
jflogerzi's Avatar
Originally Posted by brybot View Post
Appreciate that, but JBP rebuilt mine when I purchased it used two years ago. The catch can and sight glass they installed leaked, and the copper tubing it was fixed to actually sheared off when I touched it, so I'm not terribly impressed with their work. He also wouldn't answer my questions about these issues. I understand they're busy, but I'm not motivated to go back to them.
Not that I won't send to them before I dumpster the whole thing, but it seems worthwhile to attempt myself before I resort to it.
The catch can? Is the little add on that is supposed to help relieve pressure in the blower to prevent leakage?
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
Old 04-14-2019, 09:10 AM   #8318
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
That's disappointing, but hopefully an isolated issue. I wouldn't use the impact on any of these parts. You'll want a wrench for the pins and then turn the big bolt.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
brybot (04-14-2019)
Old 04-14-2019, 11:12 AM   #8319
brybot
Drives: 13 DGM BRZ 6MT
Yeah that's what I'll do, but I wanted to make sure it wasn't reverse threaded before I get the breaker bar out.
brybot is offline   Reply With Quote
Old 04-14-2019, 03:04 PM   #8320
Xero-Limit
Xero-Limit's Avatar
Originally Posted by sqd View Post
Does anyone know the diameter of the black plastic intake tube/pipe, from the MAF to the throttle body?
I'd like to use a aftermarket air filter, and replace the plastic tube with a stainless steel pipe. But I need a MAF housing or MAF flange, but I'd ideally like to have the housing and intake pipe the same size.
Pretty much exactly like this, but with the intake pipe replaced as well.
Is there any interest in doing more of these 3" intakes we've built in the past? We're running a batch of 3" filters for another intake project and we could make more of these if there is sufficient interest. Pricing is around $200.
That I don't know, you're breaking new ground here! You'll know pretty quick though once it starts moving.
Kenny_LongWrench (04-14-2019)
Old 04-14-2019, 07:40 PM   #8321
Kenny_LongWrench
Tacticool_BRZ
Kenny_LongWrench's Avatar
Drives: ZC6 - AW11
I would actually like a new intake. Was going to have one made, but yours looks clean! @Xero-Limit
Kenny_LongWrench is offline   Reply With Quote
Old 04-14-2019, 07:58 PM   #8322
jflogerzi
jflogerzi's Avatar
Does this include the intake pipe and maf housing for 200$?
Old 04-14-2019, 10:50 PM   #8323
Xero-Limit
Xero-Limit's Avatar
Includes the MAF housing you see in the picture with the mounting arm, and the air filter.
Old 04-15-2019, 04:29 AM   #8324
sqd
sqd's Avatar
Drives: '13 SWP GT86
I'm having one made actually, stainless steel intake pipe (all the way to the throttle body) and MAF-housing It helps having friends who works as fabricators, haha.
IG @squareddesign
http://www.squareddesign.se
sqd is offline   Reply With Quote
Old 04-30-2019, 05:33 PM   #8325
ptschmidt77
Drives: 2014 BRZ Limited
Does anyone have a source for a 90mm pulley? I see it listed as available in the Google docs spreadsheet, but my searches have been fruitless.
https://docs.google.com/spreadsheets...#gid=516451831
ptschmidt77 is offline   Reply With Quote
Old 04-30-2019, 05:36 PM   #8326
jflogerzi
jflogerzi's Avatar
Stock was 80 or 75. Why would you want a 90?
Old 04-30-2019, 05:44 PM   #8327
ptschmidt77
I plan on using a 335 on a stock motor while I build another bottom end, then I'll go 80.
Old 04-30-2019, 06:21 PM   #8328
jflogerzi
jflogerzi's Avatar
Yeah 335 is a whole other animal
Old 04-30-2019, 06:39 PM   #8329
86TOYO2k17
Drives: 2017 toyota 86
From reading sprintex 335 forums. It looks like the 85mm slightly rubs the hood when the engine rocks just enough under hard acceleration. Maybe stiffer engine mounts could fix that, didn’t seem like much of an issue if you didn’t care about your paint much though. But it sounds like you need to make hood modifications to fit a 90mm pulley.
Old 05-01-2019, 12:46 AM   #8330
jflogerzi
jflogerzi's Avatar
officially add me to the list. better late than never
The Following User Says Thank You to jflogerzi For This Useful Post:
Kenny_LongWrench (05-01-2019)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 11:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 07:15 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 01:18 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-18-2012 12:38 AM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 06:14 PM
