#729 | |
Actually doing the head gaskets adds significantly more work with sealant. The cam subassemblies have to come of to remove the heads and they are loaded with sealant. |
#730 |
Drives: N/A
Got the car back yesterday from getting a new short block post recall. So far so good.
#731 |
Drives: 13 BRZ
So many failures posted that it has made a ton of people not even dare to get the recall done. I am curious to know the actual percentage of successful services...
#732 |
Drives: 2019 Mazda Miata RF
I think the dealership that did mine, has done about 5 or 6 others, and mine is the only one with issues.
#733 |
Drives: 2017 Subaru BRZ PP WRB
#734 | |
Just for shits and giggles let's make some numbers up. There are 2,5000 affected FA20s (there are no reports of failures in the other engines involved) Take a worst case scenario that only 10% of them have been fixed. The number is probably far higher but lets keep it simple. The google list published on here is a compilation of forum, Facebook and other media sites. It has about 50 reported failures. So now we will say that this is only 10% of the failures (keeping it simple) So now we are at 500 failures out of 2,500 cars repaired. Now I know everybody is going to cry "bullshit there are more than that" but the "so many failures number is not as bad as it appears. Still more than should have happened but they have dealt with the sealant issue and we are simply not seeing the rash of them we did at the start. It is a sort of a glitch in the system whee the Google list does not included date of repair so we don't even know if most of the failures were before the updated instructions went out. Personally, if I had to have it done, I would do it now while it is high enough profile that the dealers are going to ensure the work is done right. The early guys suffered through the lack of instruction and those that wait too long may get stung by the techs getting complacent again so this may be the sweet spot for getting it done right.
#735 |
Drives: UK GT86
Thanks to all this noise, the UK has only just started doing the recalls. Massive training programme has caused a delay in the start-up, TGB referencing the large number of failures so far in the USA and they don't want what's happening to happen here.
.: Stealth 86 :.
#736 | |
Drives: frs
#737 |
99.999999999%
#738 |
Drives: 13 Subaru BRZ
#739 |
#740 |
Drives: 2013 Firestorm FR-S AT
Numbers we do know from nhtsa.gov: https://www.nhtsa.gov/recalls?nhtsaId=18V772
In the US the recall affects the 2012-2014 Subaru Impreza, 2013 XV Crosstrek, 2013 Subaru BRZ, and 2013 Toyota Scion FR-S vehicles. The potential number of units affected is 165,534. Of those 25,300 are Scion FR-S. Chronology of Defect / Noncompliance Determination https://static.nhtsa.gov/odi/rcl/201...8V772-0340.pdf April 2012-Aug 2015: "During this period, eleven technical reports related to stalling were reported from the U.S. Because of the limited number of reporting, Subaru continued to monitor the field for any changes and continued parts (engine) collection for additional analysis." Aug 2015-Oct 2016: "Three technical reports related to stalling was issued from the U.S. Due to the continued low number of reports, Subaru continued to monitor field data." Of the 165,534 affected vehicles have there been more than 14 valve spring failures since Oct 2016?? If only 14 then the chance of a valve spring failure in the affected vehicles is 14/165534 x 100 = ~0.008%. If true, I like those odds and I will not, at this time, be taking my FR-S in for the recall. Last edited by RickyBobby; 04-14-2019 at 06:54 PM. Reason: Included 3 reported from Aug 2015-Oct 2016 |
#741 | |
#742 |
Just got my car back from the valve spring recall. I wasn't planning on having it done since I wasn't worried about the stock springs failing (they've survived 100k miles and several track days) but my cam carriers were leaking and it was much cheaper to have them resealed during the recall then as stand alone job. I did a lot of research when I first heard about the valve spring issues, and I honestly think people are making a bigger deal out of this then there needs to be. As stated above, the odds of failure are very small and the bad ones would likely have failed by now due to the age of the car. On the flip side most dealership techs are far more skilled then people give them credit for (I was a tech for 3 years) so the odds of your engine being destroyed after having the work done is also very slim. My advice would be to hold off on the recall until other major work is needed so you can save some cash. Odds are the vast majority of owners will experience no issues before or after the work is performed.
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
