Old 04-10-2019, 07:09 AM   #701
ermax
ermax's Avatar
So, another thing to check before and after the recall work - the length of the dipstick tube -
I’m starting to think it would also be a good idea to make sure they remembered to put the engine back in the engine bay. Hahaha
Old 04-10-2019, 07:33 AM   #702
Reminds me of this....
[ame]https://www.youtube.com/watch?v=yGkMhGqbJhY[/ame]
Dadhawk is online now   Reply With Quote
Old 04-10-2019, 09:41 AM   #703
c.klingner
hmmm.....I reckon it didn't leave the dealership with no oil showing on the dipstick or it most likely wouldn't have run for two weeks.
So, my concern would be - where did the oil go?
That’s what I said and again the tech’s exact words were that he naver seen it low on oil so he can’t say. He recommended I check it every few hundred miles after they fix it and I get it back. It’s just ridiculous to me that they keep pushing this off on me to look into.
c.klingner is offline   Reply With Quote
Old 04-10-2019, 11:47 AM   #704
Is that on the checklist?
Old 04-10-2019, 12:16 PM   #705
maslin
Benz Tech
Drives: 2017 BRZ Premium
Not specifically. It does say check all fluid levels, but Oil is not singled out.
maslin is offline   Reply With Quote
Old 04-10-2019, 09:49 PM   #706
Turfstuff
Drives: FRS, Miata,Jeep, K5Blazer
I had the recall work done and 1000 miles later the same ticking noise kicked in as many people here have reported. Car has 56k and is now a push car. Dealer has said there is a problem with the recall and Toyota has basically told me that since I don't have every receipt for every service done they are probably not going to cover it. SO long story short I am stuck with a car I can't drive. If they will not fix it I am going to tear the engine down and document everything I find. Dealer pulled the oil pan and the oil screen was gone when I viewed it. I am going to see if I can get by with a new crank. pistons and bearings. Any recommendations on these parts? I am not seeing a lot of options.
Turfstuff is offline   Reply With Quote
Old 04-10-2019, 10:19 PM   #707
ermax
ermax's Avatar
Of course they hid the pickup screen. If I were you I wouldn’t rebuild the bottom end but simply replace the whole short block. When I did mine I got the short block for 1800. Rebuild gasket kit for 240. I also replaced my OCV screens and DI seals which was $20 or so. I went through 2.5 tubes of TB1217H at $20 each. 2 would probably do the job but I spread the work over a few days so I threw out an opened tube and got a fresh one. You also need oil and coolant. I doubt you could rebuild the bottom end for much less than that.
I’d put up more of a fight before throwing your own money at it.
Old 04-10-2019, 10:57 PM   #708
maslin
Benz Tech
Toyota /= the dealer. Toyota not covering the repair means the recalled parts replaced did not fail again and break your engine.
It’s the dealers problem to fix this. Who cares if you used Walmart oil for the last 5 years? They took your engine apart, then it blew up. That isn’t your fault.
Old 04-11-2019, 07:42 AM   #709
msaikhan
Drives: frs
Find out where the Fk is the oil screen. If dealer doesn't want to fix it, make a complaint to Toyota and the general manager of your dealer should give you a call. Then try to work things out with the GM. And i wouldn't go cursing and yelling at him. Try to find out where they made mistake(like applying sealant to wrong place) etc...
Try this before tearing apart the engine.
If all fails, then i would get a used long block for 2,3k.
msaikhan is offline   Reply With Quote
Old 04-11-2019, 08:18 AM   #710
Have to wonder just how many will let the car sit for a full two hours before adding the oil. Wonder how many will pull the relay to build pressure for that matter.
Old 04-11-2019, 09:51 AM   #711
Ichima
Drives: 13' Lightning Red Brz
so my cars going back to the initial dealership that screwed my car after the recall. The second dealership that diagnosed my vehicle states that my passenger side heads are bad. Stating they would fix it under TSB 02-151-14R. "If you receive a customer concern of a tapping sound from the B2 cylinder head, confirm it is isolated
to the B2 valve train area before proceeding with any repairs. Once verified, order and replace the
intake and exhaust camshafts, the 4 intake valves, 4 exhaust valves, all 8 rockers and all 8 pivots.
Refer to the service procedures outlined in the applicable Service Manual for installation."
That dealership didn't process any repairs on my car because when dropping my oil pan, they noticed an excessive amount of RTV inside the oil pan and pickup screen. They called me right away and stated that when the initial dealership replaced my headgaskets, they used too much sealant and now i'm looking at a case of oil starvation.
Now today, my car is being towed back to the initial dealership who worked on my vehicle for repairs. What should i expect? and what should i fight for in terms of damage done to my vehicle.
Ichima is offline   Reply With Quote
Old 04-11-2019, 10:00 AM   #712
ka-t_240
If SOA is standing behind the details given by dealership # 2. Dealership # 1 should be fixing anything related to the excessive oil contamination/starvation due to the sealant.
The sealant is an issue related to this recall not the headgasket repair IMO. The actual head gasket repair would not really be a cause of any extra sealant to be used beyond the valve spring recall.
As for the issue with the head, if that is not covered under normal warranty, not sure you can expect either Subaru or the dealer to fix it unless there is a sign that parts/process of the valve spring recall would have caused it to fail.
ka-t_240 is offline   Reply With Quote
Old 04-11-2019, 10:09 AM   #713
Ichima
My main reasoning for adding the headgasket repair is because when resealing the heads, I am to believe they used the same sealant and this is why the second dealership questioned me if I've had my headgaskets done. In which the first dealership did service my headgaskets the same time they serviced my valve springs. The Headgasket job did come with a 1 year unlimited mile warranty.
Second, I did get the okay from Subaru of New England to repair the heads on my vehicle under TSB 02-151-14R when they personally came to look at my vehicle at the second dealership. If the second dealership did not perform this, may I still fight the stance that it should be repaired by the first dealership?
Also, what damage should I be aware of with oil contamination/starvation?
Old 04-11-2019, 10:16 AM   #714
ka-t_240
If the second dealership did that repair, they would have had to pull your motor pull the cover, etc like done in the vavle spring recall. Then remove your head(s) for a read rebuild. It is unlikely they did this with out telling you. Especially if they have concerns with the oil starvation,
brz, failure, frs, i cant even, j02, recall, so much glue
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 02:46 PM
Is the fad threads ruining our fad threads? Andrew025 Off-Topic Lounge [WARNING: NO POLITICS] 12 10-04-2017 09:12 PM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 05:18 PM
BRZ or FRS (yes, another one of those threads) lisaaaxo FR-S / BRZ vs.... 19 04-11-2015 02:44 PM
Vs. threads.... TwinscrollGT35R FR-S / BRZ vs.... 34 05-22-2012 08:21 PM
