Drives: Argento 2014 FRS
Turning lamp won't turn on with low beam
Hey guys,
First time poster. Please let me know if I'm in the wrong thread. I am also a noob, so I don't know too many technical terms. My turning lamp doesn't turn on when my low beams are on, but the signaling works. Here's a link to a video of my car: Only my right side is having an issue. Any suggestions as to how I can fix this, or any possible guesses for what the problem might be are appreciated. Thank you. |
#2 | |
![]() First, I'd check the fuse that is associated with that light. If the fuse is good, maybe the bulb is bad. Swap it with the other side, if it works over there, it may be a ground issue. If it doesn't work on the other side, it's most likely bad. humfrz Last edited by humfrz; 03-31-2019 at 11:51 PM. |
#3 |
[insert cool phrase here]
Drives: BRZ Premium
You'll need a new bulb.
One of the two lightly thingys is gone. Common problem and solution since 1940's? Give or take a few years.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
#4 |
Thanks guys! I'll definitely try all the solutions.
#5 | |
My grandfather also (later on) had a new Oldsmobile and he let me dust off the dash - that's where I learned not to touch the other end of the knob that popped out from the dash - ![]() Sorry - I'm rambling again - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | bcj (04-01-2019) |
#6 | |
Drives: BRZ Premium
#7 |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 11:40 PM |
| Steering wheel issue---left turn lighter than right turn!!! | xingxingtjf | Issues | Warranty | Recalls / TSB | 12 | 10-14-2015 07:47 PM |
| ***Group Buy: FR-S LED Turn Signals (Dual Color, White/Regular, Amber/Turning)*** | Vicious LED | Groupbuys | 293 | 08-22-2013 06:26 PM |
| TC turning back on after turning it off | Xdragonxb0i | Issues | Warranty | Recalls / TSB | 2 | 02-01-2013 05:19 PM |
| ***FR-S/BRZ LED Turn Signals (6K WHITE/AMBER FOR TURNING, NO HYPER FLASHING!)*** | Vicious LED | Exterior Parts - The Rest | 7 | 11-02-2012 11:05 AM |
