Old 03-25-2019, 10:38 PM   #15
ermax
ermax's Avatar
Originally Posted by kt45 View Post
Well the other 2 valves look like the right valve in the picture.
Okay so your even more unlucky. Hahaha.
Considering your cats are falling apart and you aren’t burning oil then I’m guessing you are running really rich. Maybe a bad O2 sensor or something or maybe an exhaust leak is making the car think you are lean so it’s dumping lots of fuel to compensate.
Old 03-26-2019, 05:24 PM   #16
kt45
Drives: BRZ 2013 MT
Cranking it over I noticed this. Stuck Valve??
kt45 is offline   Reply With Quote
Old 03-26-2019, 05:39 PM   #17
ls1ac
ls1ac's Avatar
First question I would ask is how did the oil get all the way back up in the manifold? Did it back fire? or is it coming from a vent tube?
With someone else turning the key is that valve moving? or is it stuck? Could just be up on the cam.
Old 03-26-2019, 05:39 PM   #18
maslin
Benz Tech
Drives: 2017 BRZ Premium
Attachment 176395
Yup.
They open and close together.
maslin is offline   Reply With Quote
Old 03-26-2019, 06:31 PM   #19
ka-t_240
Time to bring it in, the dealer/manufacture may cover hauling. Call them and discuss, and describe your symptoms and see what they say.
The issue we see here may not be related to your valve springs; however the sounds could be. Regardless you have an issue, and the issue likely can be fixed now as part of the recall for much less.
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Lantanafrs2 (03-26-2019)
Old 03-26-2019, 07:20 PM   #20
I wouldn't be so quick to dismiss a valve spring issue. A weak or broken spring could have the same symptoms.
Attachment 176395
Too lazy to write it again.
ermax (03-26-2019)
Old 03-26-2019, 07:35 PM   #21
ermax
ermax's Avatar
I was waiting for “I told you so”. Hahaha
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (03-26-2019)
Old 03-26-2019, 07:57 PM   #22
Didn't seem like a mystery to me (other than the oil part) since his first post reads almost word for word like the recall notice. Almost like a book made into a movie.
Old 03-26-2019, 07:58 PM   #23
Lantanafrs2
Drives: 2013 frs red
Lost a rocker?
Lantanafrs2 is offline   Reply With Quote
Old 03-26-2019, 08:32 PM   #24
maslin
Benz Tech
Originally Posted by Lantanafrs2 View Post
Lost a rocker?
Depends on which one isn't moving. Closed stays closed you lost a rocker. Open stays open you bent a valve.
Broken spring usually leads to a floated valve that finds the piston and tweaks. Gets stuck in one spot, bound in the guide.
Old 03-26-2019, 09:48 PM   #25
Lantanafrs2
Or worse. That amount of oil looks worse than a bad guide seal imo.
Old 03-27-2019, 07:22 AM   #26
kt45
Drives: BRZ 2013 MT
Yep exactly what it is. So valve spring is good! Its somewhere hiding behind the cam. I can jiggle it around. Surprisingly the cam seems pretty much unscathed. I was expecting a lot of marring and what not.
As for the oil Im guessing rocker fell off first -> Intake valve stuck closed -> rich afr in cylinder -> a lot oil blowby -> oil recirculated into intake.
Calling the local dealer tomorrow to see if its worth the chance of spun bearings for them to fish it out.....
Old 03-27-2019, 09:59 AM   #27
maslin
Benz Tech
Rockers can’t really just fall off, they’re stuck between the cam and valve. Something has to move for it to come out. Considering the cam isn’t exactly flexible, that really only leaves the valve.
Old 03-27-2019, 10:47 AM   #28
ermax
ermax's Avatar
The pin holding the roller is known to come apart on early builds. Mid 2014 the valves (longer), rockers and pivots (smaller oil hole for more lift) were revised to combat this problem. So yeah they don't just fall off, the roller comes loose and then they fall off.
Tcoat (03-27-2019)
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Past Engine Repairs Recall Related? LlamaRay Issues | Warranty | Recalls / TSB 17 03-05-2019 08:44 PM
BRZ Valve Spring Recall mrhemi Issues | Warranty | Recalls / TSB 6 03-01-2019 04:35 PM
Valve Spring Recall venturaII New England 13 02-25-2019 08:41 PM
