Old 03-03-2019, 11:30 AM   #1177
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
forgive me for my ignorance, but what exactly does the new version do? wouldnt the map be the same so it wouldnt make a difference?
Old 03-18-2019, 05:34 PM   #1178
B T
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
What is the most current revision? I'm currently running V25
B T is offline   Reply With Quote
Old 03-18-2019, 10:37 PM   #1179
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by thatfilipinoguy View Post
Hi William! Quick question, I just got my car back from the dealer (recall). I noticed that the rev match wasn't working, but launch control does. Should I just reflash the ECU with the last tune I received, or should I wait for an updated one from you guys.
Yes, try reflashing it and see if that resolves it. Sorry about the delay, been quite busy as of late.
Old 03-18-2019, 10:44 PM   #1180
DeliciousTuning
Originally Posted by Breadman View Post
forgive me for my ignorance, but what exactly does the new version do? wouldn't the map be the same so it wouldn't make a difference?
For forced induction applications we are on 25 and will be moving to 26 within the next month or so. More to come on that.
As for the NA tunes.
Stage 1 we are currently on version 9.
Stage 2 we are on version 10.
Stage 2 + ACE header we are on 11.
As for the reason for the updates. EcuTeK release more tables for us to refine the tune, which we then take advantage of. We also do refine the tune further as time progresses, including low end response, throttle mapping, cam angles, di angles, etc....
Regards,
William
Old 03-18-2019, 11:00 PM   #1181
stlgrym3
Regards,
William
My NA ACE with flex fuel tune was done with Zach back on last September, am I due for an update?
stlgrym3 is offline   Reply With Quote
Old 03-19-2019, 09:39 AM   #1182
Breadman
Breadman's Avatar
i just went back and checked on my laptop and i have 11.01
Old 03-21-2019, 04:21 PM   #1183
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Thanks for getting back to me! I ended up reflashing and it finally came back. It took a few 100 miles for it to return believe it or not.
I am also looking forward to getting the update to the ACE tune, I am still on v8. Thanks for working on this!
thatfilipinoguy is offline   Reply With Quote
Old 03-29-2019, 02:31 AM   #1184
Mr_Eyo
Drives: 2017 Toyota 86
I have an AT with the Edelbrock kit and v25 tune for flex fuel and am having a rough idle. Sometimes sitting at a light, ignition advance timing is -2.5 deg. STFT is high, like +25%. Load is a little higher than normal. Vacuum sometimes is only -7psi vs the normal -10psi, so I imagine the bypass valve actuator is partially open, flooding the cylinders with compressed air and the ECU is pulling timing. If that sounds plausible, where could I be having vacuum issues?
Mr_Eyo is offline   Reply With Quote
Old 04-04-2019, 02:09 PM   #1185
DeliciousTuning
Yes, this sound like you have a vacuum leak and probably at the bypass valve.
Old 04-11-2019, 06:59 PM   #1186
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Hi everyone. I have two questions I'm hoping someone can help me with.
1. Where can I find an OEM ECUTek ROM so that I can put my 2013 FRS back to the stock ?
I currently have the Innovate 8.65 tune on my car, but I put the car back to stock so that I can take it in for the valve spring recall.
I searched the forum and was able to find what I believe is the stock tune, ZA1JB01C.hex, but people say it is not compatible with ECUTek. Apparently I need an ECUTek rom file and not a hex file? Please forgive my ignorance. The car is current;y at the mechanic shop waiting to be picked up and not having the stock tune is the only thing holding it back.
2. Will changing the exhaust headers require another tune?
I eventually plan to put the SC kit back on the car, but I'm thinking of changing exhaust headers when I do. The car was custom dyno-tuned by Bill with after market EL 4-1 headers on. Will changing the headers require another custom dyno tune or can the current tune be updated?
Thanks in advance to the forum community for always helping out. You guys are great!
GFR - aka my build thread
"They don't think it be like it is, but it do." -Oscar Gamble
MINOCIN is offline   Reply With Quote
Old 04-12-2019, 01:22 AM   #1187
tomm.brz
Drives: brz 2017 hksv2
you have them all on ecutek proecu software in your pc
Help - Ecutek update - Update rom list
then you will find them on c:/ecutek/proecuromfiles
MINOCIN (04-12-2019)
Old 04-12-2019, 12:42 PM   #1188
DeliciousTuning
1. If you can not find them, just email us and we can send the file over to you.
2. It depends on what your changing from the headers from and to. If they are going to be similar probably not, but if you are going to say a 4-2-1 unequal, etc... then we should adjust the tune a bit.
Cheers,
William Knose
Master Tuner @ Delicious Tuning
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Old 04-13-2019, 05:21 AM   #1189
MilkyWitness
Drives: fdsgh
My laptop died that had my ecutek program on it. Can I simply download it again on a new laptop and it’ll work just fine with my car as long as I have the USB that delicious gave me? The install and program I had wasn’t paired or anything with my car was it?
MilkyWitness is offline   Reply With Quote
Old 04-13-2019, 05:34 AM   #1190
tomm.brz
don't worry you can install it on every laptop/PC you want
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 04:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 06:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 06:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 02:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 03:33 PM
