Old 03-18-2019, 09:12 PM   #15
msaikhan
Drives: frs
Originally Posted by ermax View Post
I just worry that you will drop the pan and find packing in your pickup and then go complain to the dealer and they will claim you voided your warranty by dropping your pan.
I’m curious what a dealer would charge you to drop the pan and check the pickup. At least then they are doing the work and can’t pawn it off on you if they find packing.
BTW, the other member that dropped his pan proactively did end up finding packing in his pickup. You could clear the pickup and possibly consider yourself lucky but there is no telling where else the packing might be stuck.
Quick question for you, they are replacing the short block. What other parts could be damaged by clogged screen? basically what should be replaced after this other than short block. I was thinking cams etc... but not sure what else.
msaikhan is offline   Reply With Quote
Old 03-18-2019, 09:32 PM   #16
ermax
ermax's Avatar
It’s kind of hard to tell how bad the cams are watching the video on my phone. Didn’t look that bad from what I can tell. If they are damaged then most likely the journals on the heads are also damaged. If you can get them to cover them under warranty then go for it. I would also replace the OCV filters while it’s apart. There are 4 of them and they are cheap and drop right in.
Do you have any pictures of the front cam caps? Subaru warns about hydrolocking old packing in one of the bolt holes and busting out the back side leaving shards of aluminum in the head.
Old 03-18-2019, 09:59 PM   #17
msaikhan
Drives: frs
no i don't a picture of that, i posted everything i have. The cams didn't have any deep scratches but some sealant on it and like very light black scraches where it rolls. I'm just trying to get them to replace/inspect everything that could've been affected by this.
Old 03-18-2019, 10:12 PM   #18
ybotspawn
ybotspawn's Avatar
Drives: 13 Subaru BRZ
This is a slippery slope. What happened with the focus rs was they replaced the gasket but didn't fix the cylinder scoring in many cases. I'd push to replace the cams and bearings if possible.
Sent from my PH-1 using Tapatalk
ybotspawn is offline   Reply With Quote
Old 03-18-2019, 10:35 PM   #19
Open Loop
2013 FR-S Whiteout / SSC
If the screen at the oil pickup were significantly blocked, shouldn't a sensor report a low oil pressure reading to the warning lights in the gauge cluster?
Open Loop is offline   Reply With Quote
Old 03-18-2019, 10:39 PM   #20
ermax
ermax's Avatar
No, the oil light just means you engine blew. Hahaha. Seriously
The Following 2 Users Say Thank You to ermax For This Useful Post:
gravitylover (03-18-2019), Open Loop (03-19-2019)
Old 03-18-2019, 10:56 PM   #21
Does the FA20 engine have oil "pressure" - or, is the oil jest slopping around in there?
Maybe they should have stuck with the old oil dippers?
On second thought, that wouldn't have worked - they went and put the engine in sideways -
Old 03-18-2019, 10:59 PM   #22
ybotspawn
ybotspawn's Avatar
Dating yourself much?
The Following User Says Thank You to ybotspawn For This Useful Post:
humfrz (03-18-2019)
Old 03-18-2019, 11:07 PM   #23
maybe?
PWBRZ (03-19-2019)
Old 03-18-2019, 11:09 PM   #24
msaikhan
Drives: frs
They actually tested my oil pressure on my car, and said it came up normal.
Old 03-18-2019, 11:47 PM   #25
ermax
ermax's Avatar
Perhaps it did for the short time they tested. Once the screen was full of crap I doubt it was producing enough pressure for redline. Hell they may not have even let it get up to normal temps before calling it a success. This car takes a good 10-15 mins of driving (not just idling) to get up to 180F. When cold it will generate really high numbers even at idle.
Old 03-19-2019, 05:34 PM   #26
ka-t_240
If you are worried about engine condition, you could ask to have a machine shop inspect your heads, cams, etc prior to assembly.
ka-t_240 is offline   Reply With Quote
Old 03-20-2019, 12:21 PM   #27
msaikhan
Drives: frs
I got a list of parts they are going to be replacing. Let me know if i should push on other parts added to this list.
Thanks,
short block
cam carrier
oil pump integrated with front cover
both intake gears vvt actuator
thermostat
Old 03-20-2019, 12:23 PM   #28
ybotspawn
ybotspawn's Avatar
Thanks,
short block
cam carrier
thermostat
Just musing here.. but if they're replacing cam carrier wouldn't it stand to reason the camshafts were damaged as well?
ermax (03-20-2019)
Failure After J02 Recall - Discussion Threads mswbrz Issues | Warranty | Recalls / TSB 1654 05-30-2023 03:26 PM
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 03:46 PM
Catastrophic Engine Failure After Recall Work? MJones_RB Issues | Warranty | Recalls / TSB 20 06-09-2019 10:54 PM
RACER X FRONT LOWER CONTROL ARM FAILURE WHILE DRIVING ON HIGHWAY: UPDATE WITH MORE D chezzy79 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 12-19-2017 09:55 PM
Litchfield BRZ & GT86 Recall flash update Litchfield Engine, Exhaust, Transmission 2 11-24-2012 08:02 AM
