#43 | |
Señor Member
EDIT: The Jun one isn’t really Porsche like.
1974 TA22 Celica
2013 86 GT Last edited by Turdinator; 03-10-2019 at 10:07 PM. Reason: I read further |
#44 | |
Drives: GTS 86
#46 |
Only happy when it rains.
Drives: series.blue
#47 |
Drives: GTS 86
#48 |
Señor Member
I had thought about doing that. I also have a spare plastic manifold that I could cut up and with some PVC pipe and some silicon couplers I reckon I could fab up some prototypes that would safely get through a few dyno pulls. Once volumes and runner sizes were worked out it would be a matter of finding someone to weld up an alloy version.
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Hawk77FT (03-16-2019) |
#49 |
Drives: Subaru BRZ, Toyota MR2 Turbo
Manifold #7 Results
Well, after 6 failed attempts, why not try again? So here it goes… With manifold number 7, we took a deep dive and looked at all of our previous data. We saw a few elements that made power or had the potential to assist in making power, so we used those elements to design manifold number 7. Most of you probably overlooked the fact that manifold number 6 had pretty good improvements in the 3500 to 4000 RPM range when compared to OEM, and without mention, failed miserably at the higher RPM range. With manifold number 5, we modified our flange design and kept the larger runner diameter where it made the best power, but still less than OEM. We combined these manifolds and made a few tweaks to build manifold number 7. We kept the small plenum design and increased the runner diameter, yet again. These changes led to basically matching OEM power (well slightly higher than OEM), but peaks at 6550 instead of 6800. What it does do is increase horsepower and torque from 3900 to redline. There is a little hiccup from 4600 to 4900, but I have a feeling that actual tuning for the manifold could fix this.
Looking forward to comments and questions, we will be updating again after we add a full exhaust system. ![]()
| The Following 8 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: | Axis2011KR (04-25-2019), fika84 (04-10-2019), PulsarBeeerz (04-10-2019), RSKYBZ (05-05-2019), Spuds (04-10-2019), Tristor (04-10-2019), Victorscp (04-13-2019), wparsons (04-10-2019) |
#50 |
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
I want to see how it performs on e85!!
| The Following User Says Thank You to Dr. BRZ For This Useful Post: | PulsarBeeerz (04-10-2019) |
#51 |
| The Following 3 Users Say Thank You to Jeff@Racer X Fab For This Useful Post: |
#52 |
Drives: JRSC BRZ SOLD
I love the commitment you all have at RacerX.
The current torque and power curve look very similar to an OEM IM with Crawford BPBs. Which was kind of the point right? Just matching or besting OEM at all is an accomplishment because many thought it wasn't possible. The full exhaust setup will look meaty.I had the BPBs on my first 93 octane setup, why more people don't run them for the extra area under the curve if they don't have access to E85 is beyond me... Speaking of E85, hmm the torque surge we get from the longer runner VE doesn't play well with E85 in the past at least. Hopefully this will be different.
| The Following 3 Users Say Thank You to PulsarBeeerz For This Useful Post: |
#53 |
Drives: 2013 frs red
Good job! If these gains stack on header and tuning I'll buy one.
#54 | |
That Guy
Drives: 2013 asphalt FRS MT
#55 |
Are these untuned results?
#56 |
The Dictater
Drives: '13 Red Scion FRS
Cool results, though it looks like you/they stopped the pull at 7000 rpm. Last I checked redline was 7500 rpm...
| Racer X Fabrication air intake design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 45 | 08-01-2019 01:29 PM |
| FRS / BRZ Intake Manifold - Development Thread - FT-86SpeedFactory by Velox | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 733 | 12-11-2018 11:13 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 11:40 AM |
| Project BRZ Intake Manifold Development | TurboBRZ | Engine, Exhaust, Transmission | 27 | 08-05-2015 08:44 PM |
| Racer X Fabrication oil pan design and development! | Jeff@Racer X Fab | Engine, Exhaust, Transmission | 87 | 06-03-2015 12:10 PM |
