Old 02-08-2019, 04:37 PM   #253
I took the stick out. This is a major concern. My head isn't hard enough to support the hood
Well, OK then, just cut a couple of cattails from along an irrigation ditch -
finch1750 (02-08-2019)
Old 02-08-2019, 05:07 PM   #254
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I don't just check the level of my oil, I taste it as well. If it tastes like meth, time for an oil change. If it tastes like ethanol, I save a quart to drink. Keeps me regular and chirp-free.
PetrolioBenzina is offline   Reply With Quote
Old 02-08-2019, 05:49 PM   #255
Is that a carryover from your childhood ??
Old 02-08-2019, 06:22 PM   #256
PetrolioBenzina
Drives: 17 86
Never had that problem.
Old 02-08-2019, 06:25 PM   #257
Silverz
Drives: Black frs
You may have to take a few tums first because it might be a little acidic.
Silverz is offline   Reply With Quote
Old 02-08-2019, 08:49 PM   #258
PetrolioBenzina
Drives: 17 86
Dirty oil makes a fine salad dressing. Stomach knocks a bit, though.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
p1l0t (03-10-2019)
Old 02-09-2019, 01:49 PM   #259
Tokay444
The ms knock becomes predetonation, op will wonder why he’s stranded at the side of the road with a rod through the block, and won’t even remember this thread, and will take no ownership of the problem.
Old 03-10-2019, 11:38 AM   #260
p1l0t
p1l0t's Avatar
Hahaha oops you just made me bump this thread.
Old 03-10-2019, 04:48 PM   #261
THAT'S for bumping a dumb thread!
p1l0t (03-10-2019)
Old 03-10-2019, 08:51 PM   #262
Gonzos86
Gonzos86's Avatar
Drives: 2018 Toyota 86
They did. That is why 93 is recommended but 91 is REQURED. False economy if it eventually screws up the engine. Think how much could be saved if you never changed your oil!
Next post will probably be "How can I get more power"?
But he has over 94,000 trouble free miles on it already...
Gonzos86 is offline   Reply With Quote
The Following User Says Thank You to Gonzos86 For This Useful Post:
p1l0t (03-10-2019)
Old 03-10-2019, 09:08 PM   #263
Gonzos86
Gonzos86's Avatar
Originally, when Subaru and Toyota tested the car engine for production, it produced 200 or 205 hp at the crank, (depending on the engine). It did this on their recommended 93 octane gas, so, legally they have to indicate that you need to feed it 93 octane in order to stay legal with their numbers. What happens to the engine if you don’t use 93 octane? Simple...your engine will generate less horse power since ignition timing will be lowered to avoid engine knocking. And that’s it folks...and no, the engine will not blow up. Sorry.
Old 03-10-2019, 09:12 PM   #264
p1l0t
p1l0t's Avatar
Originally Posted by Gonzos86 View Post
When the car engine was originally tested/dynoed, it produced 200 or 205 hp at the crank, (depending on the engine). It did this on 93 octane gas, so, legally they have to indicate that you need to feed it 93 octane in order to stay legal with their numbers. What happens to the engine if you don’t use 93 octane? Simple...your engine will generate less horse power since ignition timing will be lowered to avoid engine knocking. And that’s it folks...and no, the engine will not blow up.
You're retarded. Who wants to drive with less HPs!?
Old 03-10-2019, 09:17 PM   #265
There is no "legal" retirement as you stated. Good atttempt at raionalizing but it is a false statement. The reason they recommend 93 and REQUIRE 91 is that it is a high compression engine that CAN be damaged by using fuel with too low an octane. Yes it will pull timing but that is only after the knocking occurs it can not preemptively save the engine when the wrong fuel is used.
THAT is all.
p1l0t (03-10-2019), Tokay444 (03-11-2019)
Old 03-10-2019, 09:19 PM   #266
Gonzos86
Gonzos86's Avatar
“You're retarded. Who wants to drive with less HPs!?“
Thanks for the nasty name calling...tells me a lot about the way you think.
I never said “you want to drive with less HP’s”. But that is what will happen if you decide to use a lower octane gasoline.
Oil grade opinion please. Mr_YUzU_FRS Forced Induction 47 03-10-2018 03:45 AM
Weapons Grade CNC Mounts Bullitt2496 Engine Swaps 8 02-28-2017 05:18 PM
Vette-Powered BRZ by Weapons Grade shiud BRZ First-Gen (2012+) — General Topics 28 04-28-2015 03:53 PM
Has anyone driven Laurales Grade in Monterey 1FunFR-S Southern California 0 09-30-2012 03:04 AM
Weapons Grade Performance Intro Doug@WGP Announcements, Contests, Giveaways 2 07-21-2012 06:24 AM
