Old 03-07-2019, 06:35 PM   #1
molassascookieman
Drives: 2013 FR-S Manual (Stock for now)
Possible rod knock
Story time. I have a 13 FR-S with 140,000 on the engine to date. About a month and a half ago, I raced a Jaguar at around 120 for a good 3 solid hours down I-10, and when I finally slowed down, I heard a weird, throaty rattle coming from the engine. At first I thought it was related to the clutch, as it stopped when I was in neutral with my foot off the clutch. I then took my car into Toyota to have the valve-spring recall done, and got a call saying my engine has a rod knock, it has nothing to do with the clutch, and my engine needs replacing.
Now I trust this dealership, and have no reason to believe they are trying to hustle me (they know full well I know a lot more about cars than the average person, and have even told me to go away and do it myself when I brought it in for some other stuff). BUT, I am skeptical of their diagnosis, because I have heard many rod knocks before, even from other BRZs, and this sounds way less violent, is coming from the bottom of the engine not the top, and because the sound gets louder when I accelerate. I can't really get a good audio clip or video clip because the short shifter starts rattling whenever I'm going fast enough to hear it.
The sound is a deeper rattle, almost sounds like somebody gargling water, but more mechanical. It has gotten somewhat worse since it started, and it does get slightly worse when the engine warms up, but everything else points to it not being a rod knock. Any idea what else this might be, and any fixes I could attempt?
molassascookieman is offline   Reply With Quote
Old 03-07-2019, 06:49 PM   #2
Subsonic
Subsonic's Avatar
Drives: Toyota 86 GTS
There are literally a million things it can be, so a diagnosis over the internet is going to be difficult. You could get a second opinion from another mechanic, or do an oil sample analysis which should show up bearing material in the oil if there is indeed a rod bearing issue.
Subsonic is offline   Reply With Quote
The Following User Says Thank You to Subsonic For This Useful Post:
Ultramaroon (03-07-2019)
Old 03-07-2019, 06:58 PM   #3
If it's rod knock you'd hear it just as well racing the engine in neutral. Take a recording of that outside so we don't hear echo from the garage. Make sure the oil is up to temp.
Old 03-07-2019, 07:29 PM   #4
James H
Drives: 2017 BRZ
Jaguar? I take it not a late model S Type with the supercharged V8
James H is offline   Reply With Quote
Old 03-07-2019, 07:51 PM   #5
maslin
Benz Tech
Drives: 2017 BRZ Premium
A rod knock is from the bottom end, not the top. They get much louder under load. A rod knock is a nice deep thunk thunk thunk, they don't always sound very metallic, and they usually sound "wet".
Basically, it sounds like you have a rod knock. But this is the internet. So it could really be anything.
maslin is offline   Reply With Quote
Old 03-07-2019, 09:19 PM   #6
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
this was my rod knock. Spun #4 rod bearing
Old 03-07-2019, 09:34 PM   #7
ermax
ermax's Avatar
That’s not rod knock. That is just your flasher relay.
I kid I kid.
The Following 3 Users Say Thank You to ermax For This Useful Post:
caus (03-15-2019), DarkPira7e (03-07-2019), Ultramaroon (03-07-2019)
Old 03-07-2019, 09:43 PM   #8
ermax
ermax's Avatar
If it was rod knock you wouldn’t have a hard time reproducing it or hearing it. My car has had a faint rod knock like sound from the day I got the car. It’s a 2013 I picked up used with 83k. I did end up spinning a bearing and I replaced the short block but what do you know it still has this damn rod knock like sound when under light load at about 2500rpm. I’ve finally gotten used to the sound so it doesn’t trigged butterflies in my stomach anymore.
The Following User Says Thank You to ermax For This Useful Post:
Knock Knock? Expired Warranty Frivo Issues | Warranty | Recalls / TSB 20 08-17-2020 10:04 PM
Tip in knock Tor Software Tuning 32 03-22-2018 01:13 PM
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 11:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 10:39 AM
Oft knock brady86 Software Tuning 26 07-15-2015 11:14 PM
