Drives: 2018 BRZ tS
JDL Over Pipe and Front Pipe
Hey Folks — I am looking to pick up a JDL UEL Catted Header, Over Pipe, and Ultra Quiet Front Pipe to pair with my 2.5 Resonated Perrin Catback, but I’ve come across a few questions I haven’t been able to find an answer to yet. I am also going to get all of these 2.5”, not 3.0”
1) Would you recommend buying the JDL OP and JDL Ultra Quiet FP as separate pieces OR the OP/FP Combo Pipe (this appears to have some of the regular OP as part of the FP, and V-Band connection). 2) JDL asks for the Rear Flange if you want (a) OEM Donut Style Gasket or (b) Flat Flanged. Any know which is better with the options I mentioned above? Any insight would be greatly appreciated. Thanks all! Links for reference: Combo FP/OP: https://jdlautodesign.net/shop/ft86-...e/#prettyPhoto Ultra Quiet FP: https://jdlautodesign.net/shop/ft86-...et-front-pipe/ OP: https://jdlautodesign.net/shop/ft86-overpipe/ |
#2 |
Drives: 2017 BRZ
IMO get the over-frontpipe combo unless you randomly think you may want to switch to the Ace header along the way (which replaces the header + overpipe). Either would be a good setup though.
With the Perrin, I believe you want the flat flange, as the Perrin already does away with the donut style gasket.
| The Following User Says Thank You to cjd For This Useful Post: | J1Avs (05-16-2018) |
#3 |
Drives: 2014 Scion FR-S Monogram
Definitely go with the OP/FP Combo. The V-Band connection is far superior to a 2 bolt flange connection. You can get it with the same cat and resonator as the super quiet FP.
As for the Donut gasket vs Flat Flange I would go with Flat Flange as the Perrin 2.5inch Catback uses a none donut type connection to the front pipe. (EDIT) Looks like cjd beat me to it.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
| The Following User Says Thank You to Detroiter For This Useful Post: | J1Avs (05-16-2018) |
#4 | ||
Drives: 2018 BRZ tS
#6 | |
Drives: 2017 BRZ
Hardest part is getting the stock overpipe out.
| The Following User Says Thank You to cjd For This Useful Post: | J1Avs (05-17-2018) |
#7 | |
Drives: 2018 BRZ tS
#8 |
Drives: 2013 FRS
Sorry to revive a 10 month-old thread, but I have a similar layout to OP in mind, so I thought my question might fit here. I am planning on getting the JDL turbo kit with recirculated wastegate, and want to ensure I have plenty of exhaust diameter to support it. My plan was to get a 3" overpipe and frontpipe, then a 2.5" catback, assuming that wouldn't be a bottleneck for my 300whp goal.
I was looking at getting the JDL OP/FP combo, but the site says the 3" option won't fit with an automatic transmission. My questions are: -Am I out of luck for a 3" OP/FP with AT? It seems there are very limited 3" options - the only other one I could find was the nameless overpipe and frontpipe combo, but that also supposedly won't work with AT. -Is 3" even necessary for this setup? Based on what I've found online, it looks like a 2.75"-3.00" diameter is recommended for that power goal, and I figured it'd be better to go larger due to the recirculated wastegate and catted FP. Any help is appreciated. Thanks in advance. |
#9 | |
Drives: 2020 Subaru BRZ (Edelbrock SC)
What do I do if I accidently ordered the donut flange? They seemed to have welded a piece of pipe for the donut. I need it flat now... |
| JDL 3" Over-Pipe/Front-Pipe Combo-Pipe SOLD | Jbelmonte | Engine, Exhaust, Bolt-Ons | 3 | 03-08-2018 09:00 PM |
| WTT Invidia catless front pipe for a resonated/catted front pipe | nickmerronesucks | Want-To-Buy Requests | 3 | 05-10-2016 02:25 PM |
| Gains from aftermarket catted front pipe vs stock front pipe? | Vmax911 | Engine, Exhaust, Transmission | 4 | 01-20-2014 01:42 PM |
| What is the difference between a Front pipe, a down pipe and an over pipe? | liajet24 | Engine, Exhaust, Transmission | 5 | 09-19-2013 10:03 PM |
