Old 03-04-2019, 08:13 PM   #15
norcalpb
norcalpb's Avatar
Does pulling up on the seat adjuster make the sound go away?
Old 03-04-2019, 08:34 PM   #16
new2subaru
Weight Weenie
Drives: 15 FR-S
My lumbar supports does this on occasion
Old 03-04-2019, 08:36 PM   #17
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
Originally Posted by maslin View Post
Found it this morning, it's the dead pedal. I must be loading it up to hold myself in the seat. Might mention it when it's in for a free service, they'll think I'm crazy.
Good point. My 2017 developed an irritating creak/pop in the dead pedal at about 4K miles when pressure was applied during cornering. Easy fix. Pull back the carpet. Put a couple pieces of double sided tape on the metal support behind the pedal fascia (it's part of the carpeting). Done.
LimitedSlip is offline   Reply With Quote
The Following User Says Thank You to LimitedSlip For This Useful Post:
soundman98 (01-19-2021)
Old 03-05-2019, 10:59 PM   #18
toijin
Drives: 2017 86 GTS
Thanks for the replies.
I've checked under the seat and there is nothing loose or rattling about. Took out seats and re-bolted it back on tightly but the clicking sounds are still there.
As someone else mentioned, it sometimes happens mid-back/back rest(lumbar support) area too. When i have time next to take it apart again, i might take the SEAT itself apart instead of just the railing.
Pulling on the seat adjuster to change distance i am from the pedals only stops its from clicking for a little while. It comes back (i was sitting close enough to headbutt the steering wheel) after awhile of driving. I also noticed it happens more when the temperature is higher.
Will get back to this once i take apart the seat itself.
toijin is offline   Reply With Quote
The Following User Says Thank You to toijin For This Useful Post:
humfrz (03-05-2019)
Old 03-05-2019, 11:15 PM   #19
gravitylover
You guys have lumbar supports? I'm jealous
Old 03-05-2019, 11:39 PM   #20
Can you make it make the sound just by setting in the seat and briskly moving from side to side or trying to move up and back?
Hopefully you won't have to take the seat apart, however, it could be that a spring inside the seat has become detached -
Old 03-06-2019, 03:00 AM   #21
norcalpb
norcalpb's Avatar
The linkage in the seat adjuster clanks with itself in multiple locations, especially over time. Once you have the seat out you’ll see what I mean. I just put .5inx.5in dynamat squares in every place the linkage comes in contact with itself.
Old 03-06-2019, 07:20 AM   #22
new2subaru
Weight Weenie
Drives: 15 FR-S
Okay, where the lumbar support is supposed to be
The Following User Says Thank You to new2subaru For This Useful Post:
gravitylover (03-06-2019)
Old 01-19-2021, 04:35 PM   #23
Alastor
Alastor's Avatar
Drives: Toyota gt86 my19
nothing else is known? I have the same problem
Alastor is offline   Reply With Quote
Old 01-19-2021, 04:44 PM   #24
gpvecchi
gpvecchi's Avatar
I swapped seat, and actual one sometimes makes a click from lumbar support too..
The Following 2 Users Say Thank You to gpvecchi For This Useful Post:
Alastor (01-20-2021), spike021 (01-21-2021)
Old 01-20-2021, 03:13 PM   #25
Alastor
Alastor's Avatar
So, is the lumbar part the problem?
Old 01-20-2021, 05:47 PM   #26
gpvecchi
gpvecchi's Avatar
I hear the click coming from that part, yes.
Old 01-21-2021, 02:15 AM   #27
Alastor
Alastor's Avatar
My toyota avensis, had the same problem
WTB: frs base drivers seat icybrzzz Canada Classifieds 0 03-17-2017 08:44 AM
WTB: drivers seat for FRS Beckder Canada Classifieds 4 04-15-2016 08:51 PM
FRS drivers seat Beckder Want-To-Buy Requests 1 01-05-2016 03:22 PM
clicking noise from drivers side rear CARBONGT86 CANADA 11 08-23-2015 07:58 PM
RHD drivers seat Basti Want-To-Buy Requests 0 09-07-2013 02:31 AM
