#43 |
Drives: STI
I talked to the local dealer and they said number one if the car fails from the recall subaru will be footing the bill. They also said when we pressed them on the post failures they believed any issues were related to dealers who got the parts early but neglected to wait until they could be trained be an area rep mechanic despite subaru warning them to wait.
I guess I was overreacting in my post above but I find it very alarming people having failures right away. Also the gentleman claiming he had to pay labor for the fix. I don't see how they could pull that. My thing is have a rule where I cut ties on anything with an imminent mechanical failure, so it's better to rip the band aid off early. |
#44 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Anyone check forums for the other cars included in the recall? Like the other Subaru's? See if they are reporting problems too. |
| The Following 2 Users Say Thank You to x808drifter For This Useful Post: | ermax (02-28-2019), ZionsWrath (03-01-2019) |
#45 | |
Drives: STI
![]() Six years after Subaru first learned that a crucial engine part might fail and cause the vehicle to stall the automaker is recalling about 165,000 vehicles in the United States. The automaker told federal regulators it first learned of a problem in April 2012 and in May 2013 it made a manufacturing improvement to the valve springs to make them stronger. Between April 2012 and August in 2015 Subaru said it had eleven reports of vehicles stalling in the United States. However, because of the “limited number” instead of a recall it decided to “monitor the field for any changes and continued parts (engine) collection for additional analysis.” They knew they were a problem the second the made the manufacturing change. They simply did not want to announce a 150+ thousand examples of their new engine platform came with a fatal flaw. LIMITED NUMBER MY A. This deceitful statement paints their true intentions in my opinion. Also they say it's a safety issue now so it's good to know 165k? in the us only not even worldwide, don't matter and are a "limited" number. They also strategically waited until cars were long out of warranty assuredly hoping cost would be minimized by people being ignorant of the problem, out of warranty and having their engines blow with no other recourse than bucko bucks. We know of at least a number of those from the forum. https://www.forbes.com/sites/jensen/.../#67ba3b453d58 Last edited by subaru; 02-28-2019 at 05:03 PM. |
| The Following 2 Users Say Thank You to subaru For This Useful Post: | Decay107 (02-28-2019), Ultramaroon (03-01-2019) |
#46 |
Failure After J02 Recall: Registry Thread
I would love to know what bearing number is failing too. There is a oil gallery near the edge of the timing cover that feeds the heads. The RH block is feed through the heads and the LH block is feed direct. So if that one oil gallery was blocked it would potentially starve the RH block. I can't recall which rods are feed by the RH block though. When I get home tonight I will look at my old block and crank to find out. My bet is that most of the rod failures will be the ones feed by the RH block and could be due to that oil gallery in the timing cover being blocked.
![]() Edit: Scratch that. I looked at my block and all bearings (mains and rods) are feed via the LH block which is a direct feed from the pump with packing no where in sight. The chart actually shows that I just didn’t read it correctly. The only thing I can see going wrong due to the recall is packing in the pickup either from excessive packing breaking off or debris from the clean up. If they blocked the gallery in the timing cover that I was referring to it would actually just divert more pressure to the bearings. My block had packing blocking one of the returns from the heads but this packing isn’t touched on the recall. So now I’m curious if they aren’t using the correct Threebond and it breaks away easier than the correct stuff or maybe they are throwing oil in it and starting it before it cures. I forget what the cure time was on the Threebond. I didn’t put oil back in mine for days because I just didn’t have time to work on the project. What a mess this whole recall is. I feel really bad for everyone getting screwed by the dealers. Last edited by ermax; 02-28-2019 at 10:56 PM. |
| The Following User Says Thank You to ermax For This Useful Post: | H1C (03-01-2019) |
#47 | |
Drives: 13' Lightning Red Brz
#48 |
Drives: 2013 FRS , 2002 MDX, ZZR600
The dealer that did my service recommended I call the Toyota Experience hotline at 1-800-331-4331. I spoke with Jeff who advised me to take my car to another shop for a second opinion and continue to press the issue. Here we go.
#49 | |
Drives: Your FR-S like he stole it.
If these engines were failing after repairs, and still covered by the Manufacturer's Warranty, the Dealers and Toyota/Subaru could fight over who's paying for it while the customer drives away. |
#50 | |
Two hour cure time I believe. |
| The Following User Says Thank You to ORrooster For This Useful Post: | ermax (03-01-2019) |
#51 | |
Actually no they aren’t supposed to use the Toyota stuff. The manual, recall instructions and a TSB all mandate Threebond 1217H. I have no doubt they use the Toyota stuff though because it’s on hand. Edit: Sorry I misread you post. It’s past my bedtime. Hahaha |
#52 | |
The amount of sealer circled in the picture doesn't look too excessive to me for a plate blocking where the vacuum pump mounts for automatic transmission equipped vehicles. The cam is still pretty far away from that and there's no pressurized oil or passages there. I would not go in screaming about what I'm seeing in that picture other than, I hope they're not planning to reuse any of that. That is shit technique for organising anything you plan to reassemble. |
#53 |
#55 | |
Who do you go after though? It’s the dealers causing the problem, not Toyota. Seems you would only have a case if you had several failures at the same dealer. Maybe a lawyer could find a clever way to pin it on Toyota. It does seem like Toyota should have some liability in this. |
#56 | |
Drives: 2013 BRZ Limited
What confuses me is that the car didn't make that noise before I took it in. |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 03:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 10:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 06:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 03:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 09:21 PM |
