#29 | |
Benz Tech
Drives: 2017 BRZ Premium
Mercedes has been harping on proper clean up and resealing for years and years. Sealant application is specified as a bead width, usually 1-2mm. Even a 1mm bead of sealant clamped between 2 machined flat metal surfaces spreads out really wide. |
| The Following 3 Users Say Thank You to maslin For This Useful Post: |
#30 |
The sealant for this job goes on the timing cover, valve cover and cam caps. Yes the valve cover gasket is rubber but you still apply sealant in a few places to aid the rubber gasket. There is a significant amount of sealant to scrape off the cam caps though.
| The Following 2 Users Say Thank You to ermax For This Useful Post: | atomicalex (02-28-2019), wparsons (02-28-2019) |
#31 |
Yes it is OK. A problem may show up hundreds or even thousands of miles after repair work so they have to draw the line someplace. The majority of the time and serious issue will show up pretty quick though so a couple of miles is fine. Some don't even drive it that far.
#32 |
Rust bucket enthusiast
Update- they say they haven't found anything yet that points to why my rod bearing 4 was eaten. I drove over and took a couple pictures...
![]() ![]() These two in particular seem worth holding onto |
#33 |
Benz Tech
![]() ![]() ![]() ![]() That's a lot of sealant. Like a whole lot. One or two of those broken off in the pan and you're done. |
#34 |
That stuff is black. Threebond 1217H is gray. So right off the bat it looks like they didn't use the right stuff. That may not be the real issue but shows they aren't doing it by the book. It's also interesting that they haven't pulled the rockers, pivots and shims and indexed them. They are just asking to fall on the floor. Did you get any pictures of the timing cover? I see the crank on the floor so apparently they split the block. I'm curious how the pickup screen looked.
| The Following 2 Users Say Thank You to ermax For This Useful Post: | CT86 (02-28-2019), DarkPira7e (02-28-2019) |
#35 |
Benz Tech
That really is a massive amount of sealant. See how it bleeds over to the next part? That's one issue. The other is all those strings to push out the sides, as much goes in as out. They aren't really attached and can easily falling off and clog the screen.
| The Following 2 Users Say Thank You to maslin For This Useful Post: | CT86 (02-28-2019), DarkPira7e (02-28-2019) |
#36 | |
Drives:
Sent from my SM-G930W8 using Tapatalk |
| The Following User Says Thank You to N234 For This Useful Post: | wparsons (02-28-2019) |
#37 | |
Drives: 2018 BRZ Limited Perf Pack
Those sealant lines are pretty ridiculous. Modern cars are not built to use much of anything, and certainly not litres of liquid gasket. If someone can get hold of a crank with the failure, check the bore for the oil galley to the failed rod bearing. It will surely be closed up with something. If it were to be pushed through to the bearing face, the material would smear and burn. This could lead to carbonization, which would be identifiable on the journal faces. The fact that the failures are so heavily skewed to Toyota shops indicates it is a reassembly issue - it's not hard at all to dismantle an engine, but it is quite difficult to get it back together properly if you are completely unfamiliar with it and the necessary prep work during disassembly. Were there also failures on Subies, it would be more difficult to assign the fault. However, Subie techs would know exactly where and how much sealant to apply to their standard boxers. The apples fall not so far from the tree, so it is unlikely this motor deviates significantly from standard Subaru assembly technique. <-- armchair failure analyst, has done technical background on engine class-actions before and willing to address this from the chemistry side
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
| The Following 5 Users Say Thank You to atomicalex For This Useful Post: |
#38 | |
Drives:
Would you kindly mention this in the OP, and possibly summarize some other common failures in the OP as well? Sent from my SM-G930W8 using Tapatalk |
| The Following User Says Thank You to N234 For This Useful Post: | caus (03-15-2019) |
#39 | |
| The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
#40 |
Drives: STI
Wow, I knew this would happen.
This very well maybe our last Subaru after 8. This could have been done 4 years ago if Subaru was not afraid to give themselves the bad press of everyone knowing their newest highly used powerplants has a fatal flaw based upon cost cutting. BOoo. Can someone clarify something for me? I was under the impression at least in my state the car would have special coverage on engine warranty after this recall is done. Am I confused? Is there any possibility of a class action against subaru for not recalling this once they knew about it and also apparently not having a proper applicable fix? They should be buying our cars back at this point as nobody in the right mind is going to want to buy a used 2013. |
| The Following User Says Thank You to subaru For This Useful Post: | CT86 (02-28-2019) |
#41 | |
Drives: 2013 WRB BRZ
Unrelated: I find it interesting that haven't seen and BRZ owners posting any issues after taking the car in for the recall, only FRSs. Could it be just an issue of Toyota dealership techs not being used to working on boxer engines, thus misapplying sealant or making other errors on things specific to them?
| The Following User Says Thank You to BigTuna For This Useful Post: | CT86 (02-28-2019) |
#42 | |
Or us Toyota/Scion owners have bigger mouths |
| Tags |
| brz, failure, frs, i cant even, j02, recall, so much glue |
| Registry Thread: Failure After J02 Recall | DarkPira7e | Issues | Warranty | Recalls / TSB | 489 | 05-26-2023 02:46 PM |
| Is the fad threads ruining our fad threads? | Andrew025 | Off-Topic Lounge [WARNING: NO POLITICS] | 12 | 10-04-2017 09:12 PM |
| CV Joint Failure and Differential Failure | AreteAuto | Issues | Warranty | Recalls / TSB | 26 | 06-16-2015 05:18 PM |
| BRZ or FRS (yes, another one of those threads) | lisaaaxo | FR-S / BRZ vs.... | 19 | 04-11-2015 02:44 PM |
| Vs. threads.... | TwinscrollGT35R | FR-S / BRZ vs.... | 34 | 05-22-2012 08:21 PM |
