Old 02-06-2019, 10:22 PM   #29
Headlights have become too fucking bright. Is there no legislation to protect us from this macular assault?
mrg666 (02-12-2019)
Old 02-06-2019, 10:23 PM   #30
Even the bloody tail lights on the 17s are to damn bright! I still have Johan's burned into my retinas and that was two years ago.
Right?
Tcoat (02-07-2019)
Old 02-06-2019, 10:28 PM   #31
CBRZY
CBRZY's Avatar
Drives: 2017 BRZ PP (White)
Anything other than the BMW i3 lights are fine in my book.
CBRZY is offline   Reply With Quote
Old 02-06-2019, 10:52 PM   #32
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Originally Posted by dhuang View Post
I get flashed all the time in my '17 Series.Yellow, and I'm lowered on RCE Yellows'.
I checked how they're aimed and the beam cutoff is at my kneecap from 25ft away.
I really think the LEDs are just that bright. I've seen many of the LED headlights on other newer fancy cars appear blinding as well -- then they do their auto adaptive magic when they see me approaching.
LED's are not as bright as HID, I have read. The aim has to be off if you are getting flashed regularly. This goes without saying, but headlights are designed to not blind oncoming traffic.
B-R-Z is offline   Reply With Quote
The Following User Says Thank You to B-R-Z For This Useful Post:
soundman98 (02-07-2019)
Old 02-07-2019, 02:18 AM   #33
Thunder86
Thunder86's Avatar
Drives: 2018 Toyota 86 GT trim (Thunder)
After almost a year of ownership, I have not noticed anyone flashing their brights at me. Probably blissful ignorance due to the fact that I'm seated so close to the ground every car on the road appears to have their brights on.
Most importantly... the 17+ heads/tails look fantastic! The "86" engraving on the side of the headlight bezel is also a nice touch for an OEM headlight.
[insert poor quality, phone-taken picture here]
Thunder86 is offline   Reply With Quote
The Following User Says Thank You to Thunder86 For This Useful Post:
B-R-Z (02-07-2019)
Old 02-07-2019, 10:37 AM   #34
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Yes, multiple.
Any well designed D2S system outperforms a D4S system in my experience.
The S2000 has the best headlights of any car I've ever driven with an OEM setup. The setup in my E36 M3 was better - but also completely custom built.
The BRZ lights aren't bad, but they aren't anything special. Neither are the Focus headlights.
D2S is brighter then D4S but the difference is ~100 lm or so, once you go with aftermarket bulbs the difference becomes greater. I'd love to get some better bulbs than what I have now(Osram D4S Night Breaker Unlimited) but the price is killer(~130 USD per bulb).
Trueweltall is offline   Reply With Quote
Old 02-12-2019, 01:45 PM   #35
Myriad
Myriad's Avatar
Drives: 2017 86, 2012 Tundra, 1999 Integra
Here is a copy/paste of an old post I made from a different thread about getting flashed. It didn’t really get any responses, but I think my unanswered question is still relevant:
I have owned a MY17 86 for almost a year now, but I have never been flashed like this. I wonder if my driveway is responsible. I park my car at home with the nose tilted up each day. Now I know the automatic adjusting headlights are supposed to do their thing when they detect a slope, but there is so little information about the details of how this works. So when I start my car on an up slope, presumedly the lights should adjust down. Once I back out and drive on level surfaces, presumedly they should level out. Or do they? How often do they adjust? Only at start up? Constantly as you drive? It can't be constantly or else they would be bouncing around with every hill, and I don't notice that happening. Maybe they only level off if at an incline for a set amount of time? Maybe they move so slowly that it is imperceptible? I can't find anything in the manual that explains under what parameters the auto leveling headlights work. If they level only at startup, my inclined driveway might always point them down. Just a theory. However they work, I do not think the shine level is ever high enough to be above another car's hood. They are bright, though. My old Integra has the dimmest lights ever and compared to that I'm driving in a lighthouse for lost ships!
Myriad
Myriad is offline   Reply With Quote
Old 02-12-2019, 03:11 PM   #36
maslin
Benz Tech
Drives: 2017 BRZ Premium
Myriad
They adjust for the weight in the car, not the slope the car is on. There are level sensors on the suspension, it measures front and rear ride height to determine the angle the car is at relative to the pavement. No way to know the slope of the pavement.
Headlamp aim is a determined drop at a set distance, 4" at 12' I believe? Flat ground, angle ground, doesn't matter as long as the 12' out is the same slope as the car is sitting on.
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Myriad (02-12-2019)
Old 02-12-2019, 03:21 PM   #37
RayRay88
Drives: 2017 86 860 Special Edition
Myriad
I've read that the MY17+ cars only adjust during start up and hold that till the next start up. Which, overall, makes the auto level feature, pretty fucking stupid.
I hope that's not the case.
RayRay88 is offline   Reply With Quote
Old 02-12-2019, 03:23 PM   #38
RayRay88
Uses only the rear control arm, it doesn't read the front. Meaning on a slope facing up, with the rear suspension under greater load, it would think there's weight in the back.
Old 02-12-2019, 03:36 PM   #39
maslin
Benz Tech
The ride height difference parked flat or on a slope is going to be very very small. I'm just saying the car isn't accounting for the fact that it's parked on a hill. If it considered that it was parking on an uphill the lights would be pointed at the ground, not up.
Checked the aim of my headlights. Lowered on Eibach Pro springs. The only manual adjustment I see is on the adjustment motor itself. I did not touch the adjustment.
Left and right cut off just above the center line, exactly how I set them. Works for me
Also noted the cut off on these LED lamps is nothing like the bi-xenons from a few years ago. They fade off at the top, no harsh line at all.
Myriad (02-12-2019)
Old 02-13-2019, 05:37 AM   #40
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Older Honda projector headlights were amazing. Even the Integra halogen projector headlights had a really wide beam pattern and very bright, and this was before HID was even a thing.
I would imagine these newer LED headlights have worse contrast than Xenon HID headlights, not so much about brightness. The glare coming off these LEDs also sucks big time for us eyeglasses wearers.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
RToyo86 (02-13-2019), Ultramaroon (02-13-2019)
Old 02-13-2019, 05:39 AM   #41
JD001
JD001's Avatar
Drives: Subaru BRZ
Can't see where this thread is going... Can someone shine a light on what it's about and where it's going?
Old 02-13-2019, 12:06 PM   #42
[ame]https://www.youtube.com/watch?v=7T22XVzoCLA[/ame]
[ame]https://www.youtube.com/watch?v=Zzyfcys1aLM&list=RDZzyfcys1aLM&start_radio =1[/ame]
[ame]https://www.youtube.com/watch?v=b07-yKnKRMQ[/ame]
[ame]https://www.youtube.com/watch?v=lcWVL4B-4pI[/ame]
JD001 (02-14-2019), TachyonBomb (02-25-2019)
MORIMOTO XB LED HEADLIGHTS/FT86SF LED Headlights Juanito08 Exterior Parts (Aero, Lighting, Etc.) 3 12-14-2018 07:29 AM
changing from 2015 jdm gt86 headlights to frs headlights 420zn6 Cosmetic Modification (Interior/Exterior/Lighting) 9 12-16-2016 05:18 PM
WTT: Trading my blacked out OEM headlights for your stock chrome headlights DCStorm Exterior Parts (Aero, Lighting, Etc.) 7 06-28-2015 12:01 PM
GT86 headlights vs. Maserati Ghibli Headlights l0aded Scion FR-S / Toyota 86 GT86 General Forum 7 08-29-2014 09:39 AM
