| Engine Swaps Discussion of engine swaps. |
#29 |
Drives: LS Swapped Scion FRS = 440HP
No, factory LS sensor, to the factory GM ECU. MRS Canbus translating the temp signal to gauges from GM ecu.
#30 |
What are you trying to accomplish? Operate the factory temp gauge or an aftermarket gauge that will show exact numbers?
#31 |
Drives: Subaru brz 2013 LS1 swap
Aftermarket for better numbers and stock sensor to trigger fans. I'm using OEM relays. Unless I'm looking at it wrong.
#32 |
Aftermarket, just get a port in there somewhere and plug that shit in. No sweat. For OEM gauge, just use whichever works with your computer choice. Probably the stock LS sensor
| The Following User Says Thank You to Ashikabi For This Useful Post: | Merc (02-04-2019) |
#33 |
Thanks I have a way of over complicating in my head sometimes.
#34 |
#35 |
Drives: Frs-t
Fuel pump controller bypass wiring setup
Hello, I am in the process in getting the Radium's dual pump hanger with their two relays kit. I'm dubious on how to connect all this correct.
Can any of you guys could help wire the signal wires and the power wires? I doubt that saying that a standalone is installed but, if it does then it is. Thank you |
#36 | |
Sent from my ONEPLUS A5010 using Tapatalk |
| Tail light wiring question | andrew_l_s | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 08-14-2015 11:13 PM |
| DRL Wiring Question | afoust50 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-14-2014 05:25 PM |
| headlight wiring question | Lydin | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 04-11-2014 11:02 PM |
| Wiring Harness Question | Sigh-on-Rice | Electronics | Audio | NAV | Infotainment | 0 | 08-10-2013 11:46 PM |
| New Head Unit Wiring Question | sikest | Electronics | Audio | NAV | Infotainment | 2 | 01-17-2013 06:15 PM |
