Old 03-28-2011, 11:00 PM   #169
OldSkoolToys
Is a Monster
OldSkoolToys's Avatar
Drives: AE86, MA70
Originally Posted by Want.FR-S View Post
I have seen this comment before: I do heel-n-toe on daily driving. I am curious how and when you will use this technique on daily driving, unless you are street racing all the time.
Can you give me some example when you really need to heel-n-toe to down shift? Wouldn't it make sense just hold the clutch and shift to the correct gear when slowing down?
You don't really NEED to heal-toe in daily driving, its just something you do....either cause, eh, why not, or because you're practicing.
I used to do that all the time because anytime I got to hear the 4A rev up, was a good time.
OldSkoolToys is offline   Reply With Quote
Old 03-28-2011, 11:04 PM   #170
enc0re
enc0re's Avatar
Drives: BMW 325i (E46)
Slowing down with the clutch in is unsafe. You should always be in gear. Heel and toe is to rev-match on the downshift. Saves wear on the clutch specifically, and drivetrain in general. I don't street race.
If you can't heel and toe, I recommend doing a rev matched downshift first, and then slowing down.
enc0re is offline   Reply With Quote
Old 03-28-2011, 11:14 PM   #171
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
And the reason that it is unsafe is because? (now I think this is a noobs question.)
Want.FR-S is offline   Reply With Quote
Old 03-29-2011, 12:42 AM   #172
Allch Chcar
Drives: N/A
If they do use an automated transmission my only request is that it be an automated manual and not a torque converter based transmission. The Auto usually anchor the overall fuel economy numbers for the car while manuals get the shorter final drive for performance. It's amazing how tall of gearing an auto needs to run to match a manual's efficiency but for an automated manual like a dual clutch, the efficiency is similar so the MPG is better on the EPA cycle. Hopefully it can get a sport mode override so that it doesn't force shift before redline like some do. But that would be a minor grip in comparison to a CVT being the automatic version.
I'm sure you guys would appreciate an unrestricted manual version. A slushy auto would paint a negative view on the car anyway. A DSG should be more connected than a CVT in operation. I won't comment on CVT efficiency, MPG, or reliability since in a car like this "feel" is more important than those factors. What are your opinions?
Allch Chcar is offline   Reply With Quote
Old 03-29-2011, 05:01 AM   #173
enc0re
enc0re's Avatar
Costs time if you have to emergency accelerate. In Germany, during your driving test, it'll literally cost you points to slow down like that. Unfortunately, driving a manual isn't taught anymore in the U.S., so many of those little things are being forgotten.
Old 03-29-2011, 05:23 AM   #174
OldSkoolToys
Is a Monster
Drives: AE86, MA70
My opinion? Okies...
Unassisted manual stick...could care less about how they go about sugar coating the automatic transmission.
Old 03-29-2011, 05:26 AM   #175
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
AFAIK this is done because of the powerband of the engine. near the redline the power tends to drop off anyway, it gets to a point where you may as well change gear to get back into the powerband, and a lot of the time this is before the actual redline or rev limiter.
Snaps is offline   Reply With Quote
Old 03-29-2011, 11:32 AM   #176
Want.FR-S
Want.FR-S's Avatar
Thanks for the explanation. Now, can you teach me what the proper way to slow down during red-light: imagine if you are driving 40 mph on the road in 5 gear, probably 2500 to 3000 rpm, and you see the red light in front of you. So you press brake to slow down. Then, what is next?
Thanks.
Old 03-29-2011, 11:34 AM   #177
Zorro
Zorro's Avatar
Drives: G35 V36 6MT
Originally Posted by Archer256 View Post
not necessarily, lets face it. Stick is dead/dying few more years and you either have auto/sport shift or only paddles. I wouldnt be surprised if Toyota offers Paddles only as an option.
btw can you have 3 pedals w/ shifters? (sorry if thats a noob question)
GTFO....
Zorro is offline   Reply With Quote
Old 03-29-2011, 01:02 PM   #178
Archer256
Archer256's Avatar
Drives: TSX
lol dude it has nothing to do with opinion FYI, it's just how the entire industry is headed. All if not like 99% of supercars use shifters and have no stick now that's the biggest sign.
Archer256 is offline   Reply With Quote
Old 03-29-2011, 01:02 PM   #179
dominican
Lude Dude
Drives: 1998 Honda Prelude
ok, there are 4 types of transmissions commonly used in cars today:
Automatic (the slushbox). This is the most common type with the beige masses.It uses a torque converter, which makes these slushboxes less efficient. With advancements, however, there have been improvements, such as locking torque converters. Manufacturers also add paddles so that you can "shift" your own, but it's really not the same
CVT: Continuously variable Transmission. This uses Variable-diameter pulley system to change gear ratios continuously. In theory, this is best because you it can rev the engine to desired power level and speed up the car accordingly. You can also have as many "fixed" speeds as you'd like, by having the computer map out the ratios. If you've ever driven one, they feel like doodoo. Paddles can also be added, but meh.
Dual Clutch Transmissions (DCT) These are the newest transmissions being put into higher end performance cars (and some lower end cars also have them). This is the paddle shifter's dream. It is basically two manual transmissions in one, and takes care of shifting for you when you want, or your can shift yourself. In my opinion, the future of performance is going to be these types of transmission.
good ol 3 pedal action: This has been around for a while. You have a transmission that you can pick the ratios for, you have the engine, and in between a flywheel and a clutch. That's the good stuff, and only this has the three pedals, as this type of transmission requires the clutch pedal to control the clutch, something that computers do on the DCT and something the torque converter takes care of in conventional autotragics.
cheers! :happy0180:
dominican is offline   Reply With Quote
Old 03-29-2011, 01:31 PM   #180
Allch Chcar
Drives: N/A
With paddles? It'd have to be a sequential tranny.
If you think stick is dead or dying you're ignoring the rest of the modern world. The US is only 5% of the total population even if we have something crazy like 10% of the cars. Manuals are still cheaper, simpler, and the most efficient transmission aside from a single speed. An automatic typically adds $500-$1000 to the purchase price of the car.
Granted 6spds aren't really taking the US by storm since they were introduced. They're far more common in Europe than here. And they do offer good automatics there too. From what I've read in reports, something like 90% of new cars are sold with automatic transmissions since the 90's. And companies are still selling 5spds and 6spds and people are still buying them 10 years later. So I'd say it's still going even though it's a niche. If gas prices keep climbing up do you think people are going to cling to their automatics? Most people buy used and they're mostly automatics now. I imagine that demand for manual cars is going to go up a teeny bit, eh?
Old 03-29-2011, 04:00 PM   #181
Archer256
Archer256's Avatar
Drives: TSX
My point wasn't that manual is dead, my point wass that STICK is being replaced by DCT's. So like instead of auto and manual/stick cars will be either auto or DCT
Old 03-29-2011, 04:05 PM   #182
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
dual clutch transmissions don't count as any sort of manual transmission, especially as most of them have an "auto" mode.
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Things I wish for.... Please Toyota! EJ20 Scion FR-S / Toyota 86 GT86 General Forum 80 10-12-2010 12:56 AM
FIVE THINGS TO NEVER DO TO YOUR CAR Raiden Other Vehicles & General Automotive Discussions 11 08-27-2010 09:55 AM
