Old 01-31-2019, 07:48 PM   #1
YamahaR86
JDM Vaping Stance Nation
YamahaR86's Avatar
Drives: 2013 White
What is this black stuff in my clutch reservoir?
42k miles, changing out my fluids and when I took the cap off the clutch fluid reservoir I saw this.
Any idea what it is and how do I clean it?
Clueless
YamahaR86 is offline   Reply With Quote
Old 01-31-2019, 08:06 PM   #2
Grady
Grady's Avatar
Normal, flush it with new fluid.
Old 01-31-2019, 08:27 PM   #3
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
I just vacuum bled in new fluid and it didn't really go away. Old fluid was brown, new is clear.
If I agitate the black stuff it'll move. Should I stick a brush in there?
Clueless
Old 01-31-2019, 10:21 PM   #4
If the dark stuff floats, just suck it out with turkey baster (don't tell SO/mom/wife/GF that you used it for that).
Old 01-31-2019, 11:11 PM   #5
YamahaR86
YamahaR86's Avatar
Drives: 2013 White
Doesn't float, it's just at the bottom. The new fluid is clear though.
Clueless
The Following User Says Thank You to YamahaR86 For This Useful Post:
humfrz (02-01-2019)
Old 02-01-2019, 12:30 AM   #6
Oh well, I'd suggest you just sop up what you can and then like ol @Grady says, just flush it out.
It's just a hydraulic system, not an operating room -
Grady (02-01-2019)
Old 02-01-2019, 01:37 AM   #7
It's rubber worn from the piston seals. No worries.
Tcoat (02-01-2019), YamahaR86 (02-01-2019)
Old 02-01-2019, 02:51 PM   #8
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Happens all the time...I use a q-tip and swab it clean when I do a flush. Still doesn't clean things beyond the reservoir though, so there's probably no point in doing it, other than it making you happy.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 2 Users Say Thank You to venturaII For This Useful Post:
Old 02-02-2019, 07:08 PM   #9
qqzj
Drives: MDX, Camry
I stirred it up really well before bleeding. It's all gone afterwards.
Sent from my Pixel 3 XL using Tapatalk
qqzj is offline   Reply With Quote
The Following User Says Thank You to qqzj For This Useful Post:
YamahaR86 (02-04-2019)
What's the black tire stuff dealerships use? BigHugeFatGuy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 27 06-02-2017 03:23 PM
Black Flakes in Coolant Reservoir?? John Rambo Issues | Warranty | Recalls / TSB 7 07-15-2015 06:58 PM
CruiseControl's Ultramarine FR-S - Perrin Tips, Shark Fin, JDM Stuff, Other Stuff CruiseControl Member's Car Journals 4 07-01-2014 06:53 PM
Anyone with black/aluminum acrylic stuff from DD? Vmax911 Cosmetic Modification (Interior/Exterior/Lighting) 5 11-05-2013 09:26 PM
