Old 01-30-2019, 10:10 PM   #43
ermax
ermax's Avatar
FR-S Valve Spring safety recall Ħɞ||
Or it was "adjusted" (bucketed) too tight -
By adjusted I assume you mean valve clearance. I didn’t bother reshimming. They were all still within spec though. More on the loose side than tight. If it was a simple process I would have improved the clearance though. I kind of wrote it off as the valve not seating well, engine being cold and dry and the fact that I was turning it over buy hand rather than by the starter. It was a big discrepancy though and it was all leaking past one intake valve.
Old 01-30-2019, 10:12 PM   #44
I missed that! So it is a double interference engine. Crap, that would not be pretty at all.
hmmmm…… one valves hooks over the other valve and the piston comes up and smashes the hell out of both of them -
Why did we ever get away from big block engines - enough room for everything -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Dadhawk (01-31-2019), dnieves (02-02-2019), gravitylover (01-31-2019), Tcoat (01-30-2019)
Old 01-30-2019, 10:16 PM   #45
Yep! And a valve job consisted of a couple of gaskets and a whole two hours start to finish.
humfrz (01-30-2019), Teseo (02-25-2019)
Old 01-30-2019, 10:24 PM   #46
Yep, valve clearance.
Let's see, you have one hand trying to hold the compression gauge in the spark plug hole tight - then with the other hand you are trying to turn over a cold, dry engine.
Now, HOW could you get a false reading?? -
Back in the day, it took me both hands to hold a compression gauge in a spark plug hole (on a 8:1 compression ratio engine) -
(hesh up, @Tcoat , I was NOT a 98 pound weakling - I just weighed 98 pounds)
Tcoat (01-30-2019)
Old 01-30-2019, 10:46 PM   #47
Yep, the old days. I used to take off the head(s), put them in the truck, before school, drop it (them) off at the automotive machine shop in town, have the head(s) milled (actually trued), valves replaced or ground, buy a gasket set, borrow a torque wrench, take them back to the farm, install the head(s) adjust the valves, all after school.
Actual work time, not much more than two hours -
Old 01-31-2019, 04:56 AM   #48
ermax
ermax's Avatar
I have threaded fittings on my compression and leak down gauges so that helps.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (01-31-2019)
Old 01-31-2019, 12:29 PM   #49
Well, what won't they invent next -
Old 02-01-2019, 12:11 PM   #50
Hypnocracy
Hypnocratic Missionary
Hypnocracy's Avatar
Back at the dealership today...addressing new suspension noises that weren’t there before safety recall work...loose bolts on sway bars is my guess
So, any oil on the garage floor ??
Thankfully...no new leaks
Hypnocracy is offline   Reply With Quote
The Following User Says Thank You to Hypnocracy For This Useful Post:
humfrz (02-01-2019)
Old 02-01-2019, 12:51 PM   #51
dodj
Drives: Rallye Blue BRZ
Some of us didn't. My other fun car is a 440 4sp Challenger
dodj is offline   Reply With Quote
The Following User Says Thank You to dodj For This Useful Post:
humfrz (02-01-2019)
Old 02-01-2019, 09:29 PM   #52
Now, that's getten into @Tcoat territory -
Old 02-01-2019, 10:04 PM   #53
well there are at least two of us on here that know the beauty of the 440!
Dadhawk (02-25-2019), humfrz (02-01-2019)
Old 02-01-2019, 10:43 PM   #54
in b 4 circle jerk
Old 02-01-2019, 11:25 PM   #55
in b 4 circle jerk
Stick around. Everybody's coming.
Old 02-25-2019, 07:49 PM   #56
Hypnocracy
Hypnocracy's Avatar
joy joy happy happy...CEL back on today...feels sluggish and not like the normal peppy FA20...stopped at teh AutoZone and had them pull the code....Oil Control Valve
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
Valve Spring Recall Dealers AsianStyle Mid-Atlantic 20 05-04-2019 03:43 PM
Valve Spring Recall for FI (Turbo or SC) Eazy-V Issues | Warranty | Recalls / TSB 8 01-28-2019 01:56 PM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 09:44 PM
