#1247 |
Drives:
I made some progress on squaring up my rear overfender to my sideskirt yesterday.
My gaps are pretty much on point. The plan is to 3M bond, fill, and mold the seam where the rear of my sideskirt meets my overfender. The skirt and overfender are held together with a bolt and rivnut setup. This fastener will also help keep everything tight while the 3M bonding adhesive cures. I also have a bolt, spacer, and rivnut setup securing and maintaining the gap between the overfender and rear bumper extentions. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() IG @zeal.eightsix |
| The Following 2 Users Say Thank You to zeal86 For This Useful Post: | Irace86.2.0 (02-25-2019), Raven86Project (01-21-2019) |
#1248 |
Drives:
Did some more sanding today...still more work to do here though.
Can't wait to get this extension and rear overfender primed...all the colors are driving me nuts... lol ![]() ![]() ![]() ![]() IG @zeal.eightsix |
| The Following 2 Users Say Thank You to zeal86 For This Useful Post: | DustinS (01-22-2019), Irace86.2.0 (02-25-2019) |
#1249 |
Drives:
![]() I'm considering a color change from the OEM pearl white to something different...and by different I mean white but not pearl. I do like the bright whites but too white may clash with my engine bay since it is the base color of my pearl...I just need it to be close. For that reason I'm leaning towards the Championship White (NH0) because from what I've read about the color it is described as creamy...creamy should work with my engine bay... however, I have time to figure this out so any suggestions on non-pearl whites will be appreciated. I'm also considering: HONDA: Frost White (NH-538) Aspen White (51E) Taffeta White (NH-578) TOYOTA: Super White 2 (040) BMW: Alpine White (300) NISSAN: Solid White aka Glacier/Blizzard (QAK) IG @zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | DarkPira7e (01-24-2019) |
#1250 |
Drives: toyota 86
I always loved the pearl white used on the Toyota jzx100 chaser. I believe it is paint code 044
| The Following User Says Thank You to johl For This Useful Post: | zeal86 (01-24-2019) |
#1251 |
Rust bucket enthusiast
The warmer championship white gets my vote. The warmer white does better in direct sunlight in my opinion. Your panel work is incredible
| The Following User Says Thank You to DarkPira7e For This Useful Post: | zeal86 (01-24-2019) |
#1252 | |
Drives:
IG @zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | johl (01-24-2019) |
#1253 | |
#1254 | |
Drives: '13 Scion FR-S & '17 Toyota 86
+1 for championship white looking very "creamy". |
| The Following User Says Thank You to eastendraceshop For This Useful Post: | zeal86 (01-24-2019) |
#1255 |
Drives:
So I've been busy with finishing the fitment of my fenders, skirt, and rear bumper extention. I made some adjustments on front fender that squared it up with the door. The front fender is getting close to being ready for paint and primer... I just sprayed it with a guide coat so I can eliminate any low spots. I'll be doing that with the skirt next.
I'll post pics once I have all my passenger side panels primed and temp installed. IG @zeal.eightsix |
| The Following User Says Thank You to zeal86 For This Useful Post: | DustinS (02-05-2019) |
#1256 |
Drives:
Here are some progres pics... I may mock up my L1 3P wheels tomorrow... stay tuned...
Minor tweaks to be made and a few more holes to be drilled but for the most part this side is done. I may start on my front bumper or rear bumper next before moving on to the driver side. ![]() ![]() ![]() ![]() IG @zeal.eightsix |
| The Following 5 Users Say Thank You to zeal86 For This Useful Post: | arkanist (02-18-2019), DustinS (02-20-2019), Irace86.2.0 (02-25-2019), Lococholo84 (02-18-2019), Raven86Project (02-18-2019) |
#1257 |
Drives:
Sorry for the picture overload... Progress has been made... still working the rear bumper extention. Happy with how everything has turned out so far...
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() IG @zeal.eightsix |
| The Following 6 Users Say Thank You to zeal86 For This Useful Post: | arkanist (02-20-2019), Busybee (03-06-2019), DustinS (02-20-2019), ichitaka05 (02-21-2019), Irace86.2.0 (02-25-2019), wolffbite (02-28-2019) |
#1258 |
Drives:
I finally got around to cutting my rear bumper to fit my rear beam brace support for my swan neck chassis mount wing.
To make the perfect cuts... I found the center on both bumper and support as pictured. The result were basically the minimal width cuts I could make. However, I widened the openings up almost equally around to leave room for adjustments and/or movement. Btw... the little black spots that look like miscuts are actually the black plastic underneath showing after I sanded and filed the edges... I'm very happy with the end product! What I did: >>Measured centerline of both bumper and support brace. >>Lined them up with a square. >>Used a ruler and sharpie to make a dashed lines. >>Connected the dashes with a white paint marker and ruler. >>Used Dremel with cutting wheel, sanding drum, and file make my openings. >>Cleaned the edges up with sandpaper on a piece of sheet metal. ![]() Perfect alignment on first try! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() IG @zeal.eightsix |
| The Following 2 Users Say Thank You to zeal86 For This Useful Post: | Irace86.2.0 (02-25-2019), wolffbite (02-28-2019) |
#1259 |
I advise you look for a way to reinforce the bumper cover itself since it had so little structure left in it. I expect it will vibrate/flap badly at speed
| The Following User Says Thank You to Ashikabi For This Useful Post: | zeal86 (02-25-2019) |
#1260 | |
Drives:
IG @zeal.eightsix |
| Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 08:52 PM |
| PC Build Thread | WingsofWar | Off-Topic Lounge [WARNING: NO POLITICS] | 126 | 01-22-2017 10:59 PM |
| Kylefrs Build Thread | kylefrs | Member's Car Journals | 14 | 01-28-2015 09:27 PM |
| Jac's BRZ build thread | Jac | Member's Car Journals | 0 | 04-30-2014 08:09 PM |
| EOJ (Not much of a Build) Thread | jonbatz01 | Member's Car Journals | 41 | 07-31-2013 08:34 PM |
