View Poll Results: Do the MY17 twins chirp?
My fuel pump is chirping 10 52.63%
My fuel pump is not chiping 9 47.37%
Voters: 19. You may not vote on this poll
Old 01-20-2019, 03:12 PM   #71
Brink
Drives: 2017 BRZ
Crickets got burned up because of bad valve springs.
Brink is offline   Reply With Quote
Old 01-20-2019, 03:13 PM   #72
Originally Posted by LimitedSlip View Post
What about indoor plumbing in general?
Well now, THAT brings to mind so many back-in-the-day stories it would overload this non R/T thread -
Short answer - as long as the cistern ain't run dry and the hand pump on the kitchen sink is primed, we have indoor running water, it jest ain't hot.
LimitedSlip (01-20-2019)
Old 01-20-2019, 03:16 PM   #73
OK, so, since my car don't have the crickets, does that mean that my car's valve springs ARE bad and I should take it in for the recall??
Old 01-21-2019, 09:21 PM   #74
BierMeister
Drives: 2017 BRZ PP CWP
Mine chirped for a couple days after the car sat for over a week. I think it was due to the small amount of gas that was in the tank during that time.
Crickets died the day after I filled up again.
BierMeister is offline   Reply With Quote
Old 01-21-2019, 10:58 PM   #75
Ragin Gti
Drives: '15 Subaru BRZ
Subaru updated the "cricket" TSB 09-54-12R on 12/10/18 to include '13-'19 BRZ. They put the most recent updated high pressure fuel pump starting with VIN J9603681. Part number for the newest high pressure pump is 16625JB022. Depending on Year/VIN at the most you would need the pump, drive case and a left side valve/rocker cover. There are no changes to the camshaft. I'm pretty sure you could bolt the newest pump up without any problems. The drive case and rocker cover changes are to help eliminate the noise. The following is a quote from the TSB.
"This bulletin provides a procedure to address customer concerns of a high-pitched “chirp”, “squeak” or “cricket” sound heard coming from the engine’s Direct Injection (DI) high-pressure fuel pump. Not all DI pumps may exhibit this sound. Some vehicles may have components which in combination with certain fuel temperatures and / or formulations, may result in aeration of the fuel within the body of the pump and cause this sound. This result is non-detrimental to the vehicle. Production changes have been made to eliminate the source of the sound."
It's just an annoying noise...
Ragin Gti is offline   Reply With Quote
Old 01-21-2019, 11:13 PM   #76
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
Is this something a dealership would do for free? Like is this under any sort of warranty? I don't really care about the crickets but I'll take free updates lol. Or are MY17's up to date with this part? I bought mine in early 2018 if that matters.
Borchert97 is offline   Reply With Quote
Old 01-21-2019, 11:20 PM   #77
I suggest you contact your dealer and ask them.
A TSB usually just shows how to do something.
The adverse condition must exist in your car before they will usually do anything about it.
My take, "if it ain't broke, don't fix it".
Old 01-22-2019, 12:07 AM   #78
Ragin Gti
If you're still inside 3 years/36,000 miles everything(mostly) is free. They will need to duplicate the noise, so if your car consistently chirps you're good to go. If it's intermittent it'll be harder to get them to replace it.
The Following User Says Thank You to Ragin Gti For This Useful Post:
Borchert97 (01-22-2019)
Old 01-22-2019, 12:51 AM   #79
Thunder86
Thunder86's Avatar
Drives: 2018 Toyota 86 GT trim (Thunder)
My 86 chirps at idle when up to temp on hot days. Like "humfrz" said... if it ain't broke...
[insert poor quality, phone-taken picture here]
Thunder86 is offline   Reply With Quote
The Following User Says Thank You to Thunder86 For This Useful Post:
humfrz (01-22-2019)
Old 01-22-2019, 01:11 AM   #80
Impureclient
Drives: 2015 FR-S
Somebody needs to look at why some of the TSB fixes worked for some and not others. I definitely was chirping and after the fix, it's gone.
Maybe it's something weird like a screw too tight/not tight enough somewhere in the process? There's a reason that it works for some and not others.
I can't believe nobody hasn't pinpointed where the noise originates from exactly.
Old 01-22-2019, 01:48 AM   #81
Well now, as mentioned up above:
"Some vehicles may have components which in combination with certain fuel temperatures and / or formulations, may result in aeration of the fuel within the body of the pump and cause this sound".
ALL you have to do, there, @Impureclient is to sort that out and you have your answer -
HINT: the HPFP is a mechanically driven, positive displacement, high pressure, liquid pump.
Soooo, -
Fuel Pump "Chirping" relaxjim Hawaii 27 04-20-2016 12:51 AM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 04:52 PM
Important Chirping Pump Update... 5AD86D Issues | Warranty | Recalls / TSB 92 02-07-2015 03:52 PM
cricket chirping after replaced fuel pump withbrz Issues | Warranty | Recalls / TSB 3 02-18-2014 09:18 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 05:53 PM
