Old 01-11-2019, 06:57 PM   #29
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
OP's mechanic?
The Following User Says Thank You to x808drifter For This Useful Post:
alphasaur (01-18-2019)
Old 01-11-2019, 07:17 PM   #30
Jordanwolf
Rice King
Jordanwolf's Avatar
Originally Posted by RickyRacer View Post
Thanks for all your help in narrowing down all the suspension kits that exist out there for the FRS. Much appreciate, can't wait to upvote your comment after i hit submit here
He's an interesting fellow.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 01-11-2019, 07:27 PM   #31
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by x808drifter View Post
OP's mechanic?
Lmao you guys are hilarious. It wasn’t THAT easy, he put one hand under the wheel and with his shoulder pushed up, said there was lots of play on he springs
RickyRacer is offline   Reply With Quote
Old 01-11-2019, 09:22 PM   #32
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
That makes zero sense to anyone who knows how this suspension goes together and has used a spring built in the last 20 years for a significant amount of time.
I mean I've driven cars older than me with 200k miles (~320k km) and the springs are fine.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Ultramaroon (01-12-2019), wparsons (01-13-2019)
Old 01-11-2019, 10:45 PM   #33
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Why would I lie?
He pushed the wheel up easily, he said this means my shocks are wearing out / going out...I can’t remember exact words. But he’s a trustworthy guy, he said I can probably keep going on them if I want but the signs are there.
Not to mention, I said myself..the ride in the car is not the same as it was years ago. Pot holes are more clunky, road bumps are more intense.. even to someone who knows nothing about suspensions I can tell the suspension is wearing out.
If it’s not the shocks, then what is it?
Old 01-11-2019, 11:56 PM   #34
Tokay444
Well this thread is certainly starting to deliver.
The Following User Says Thank You to Tokay444 For This Useful Post:
Old 01-12-2019, 12:04 AM   #35
If anything it's the dampers, not the springs. Others here are correct in advising you to check all articulating joints.
RickyRacer (01-12-2019), strat61caster (01-12-2019)
Old 01-12-2019, 12:36 AM   #36
strat61caster
Why would I lie?
I'm not suggesting you're lying, your mileage and feelings about ride quality are logical given the mileage of your car and replacing dampers is a reasonable path to follow, I say go for it.
Good luck
ineedyourdiddly
RickyRacer (01-12-2019), Ultramaroon (01-12-2019)
Old 01-12-2019, 12:40 AM   #37
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
thanks guys.. i appreciate all the replies
car is reliable and the community for it is rock solid too!
looking forward to buying the 17' OE set from StraightOuttaCanada and replacing the other components as reccomended
The Following User Says Thank You to RickyRacer For This Useful Post:
Old 01-12-2019, 12:02 PM   #38
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
So I'll throw my $0.02 in here...I'd say that after 200k miles of northern driving, your shocks easily could stand being replaced. However, shocks have nothing to do with the type of movement described. My guess would be worn out upper strut bushings. The movement your mechanic produced wasn't from compressing the springs at all, but rather, slop in the toasted bushings. Replacing your current setup with takeoffs from another car will probably include the good upper bushing, so you're covering all bases with this approach..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following User Says Thank You to venturaII For This Useful Post:
Old 01-12-2019, 01:17 PM   #39
Jordanwolf
Rice King
Jordanwolf's Avatar
Careful @StraightOuttaCanadaEh 's car is red, so you know already he's a menace. He's also taller than me, so be careful of that too.
Glorious Honda.
Old 01-12-2019, 05:54 PM   #40
Wes
i already tried to peddle him my red fender garnish things lol
Instagram: @gt86ws
The Following 2 Users Say Thank You to StraightOuttaCanadaEh For This Useful Post:
Jordanwolf (01-12-2019), new2subaru (01-12-2019)
Old 01-12-2019, 06:09 PM   #41
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
Shocks from a red car? Ruined.
Old 01-13-2019, 10:28 PM   #42
wparsons
wparsons's Avatar
Movement at the wheel still needs to compress the spring, unless the upper mount is unbolted from the body at the top. You'll get lateral play if the bearing is bad, but not enough vertical play to see the wheel being lifted up.
flickr
strat61caster (01-14-2019)
Looking for mechanic in Southeast radroach Southeast 0 07-27-2017 09:36 AM
Looking for a mechanic in Queens jarviz NY / NJ / CT / PA 3 08-18-2016 05:15 PM
Mechanic zen themadscientist Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2015 03:03 PM
Because car mechanic Boxer-86 Off-Topic Lounge [WARNING: NO POLITICS] 1 10-26-2012 01:34 AM
Mechanic Approved ashtray BRZ First-Gen (2012+) — General Topics 10 06-15-2012 05:53 PM
