Old 01-10-2019, 10:32 PM   #1
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Mechanic said my suspension is done.. What should I do?
I DD my FRS.. so it's above 200k KM now.
I took it for an oil change and tire rotation.. the mechanic was able to easily push up the wheels with one hand while it was on the hoist. he said this means suspension is going bad.
I also noticed small bumps in the road feel like hell on earth ... which normally would just drive over with a slight "Swoosh" when the car was new
I like that new car feeling, and since it's a DD and i don't do any track.. I am considering just buying a new set of stock coilovers from Toyota dealership.
I looked at some premium aftermarket offerings like KW, Ohlin, etc. But i don't think they're made to last 200k like the stock ones have served me gracefull so far?
Thoughts? Also, while im replacing the coilovers, what else should i refresh?
This is IN ADDITION to the appointment I have in Feb for the spring valve recall.
Ah, the joy of owning a 13' FRS
Thanks all!! Sorry for the newb questions
Edit: just to confirm. I don't want to lower my car at all. Even If the right decision is to go with ohlin or KW.. I will prefer to keep as stock as possible and built for comfort.
Here she is in all her glory
RickyRacer is offline   Reply With Quote
The Following User Says Thank You to RickyRacer For This Useful Post:
humfrz (01-11-2019)
Old 01-10-2019, 11:18 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Check the member's for sale section, plenty of members are selling their newer 2017+ Performance Pack suspension as they upgrade to coils and bags.
This should tick both your boxes by giving you the same reliability and mileage that you had on your older 2013 OEM setup and an improved ride over what you had when you bought the car new.
Plus, if patient, you will also likely find these for much cheaper than what you can buy anything in the aftermarket should you go that route.
The Following 3 Users Say Thank You to Kiske For This Useful Post:
olsonpg (01-18-2019), RickyRacer (01-11-2019), why? (01-19-2019)
Old 01-10-2019, 11:30 PM   #3
fatoni
yeah i would have loved to upgrade to pp suspension but there wasnt any real cheap anywhere near me. i ended up getting some tein flex z for around 700 and its pretty comparable to stock if you want it to be.
Drive upgrades. Don't buy them.
The Following User Says Thank You to fatoni For This Useful Post:
Old 01-10-2019, 11:51 PM   #4
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
thanks. price is not really a factor though, I just want reliability + longevity without having to rebuild/oil up these coilovers all so often.
willing to invest as much as it takes (to a reasonable amount) to achieve that
Old 01-11-2019, 02:58 AM   #5
Turbo
Drives: FR-S Turbo
I was going to over you my old coilovers (HKS Hipermax SP) but they are more track oriented then street so they wouldn't be a good fit for you.
As an aside, did we used to play C.O.D. together online? Your username is very familiar.
Turbo is offline   Reply With Quote
The Following User Says Thank You to Turbo For This Useful Post:
Old 01-11-2019, 08:05 AM   #6
StraightOuttaCanadaEh
Wes
I have the stock '17 suspension as I installed coilovers I think less than 6 months after owning the car, and I am in Toronto so pm me if you like
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
Old 01-11-2019, 08:05 AM   #7
new2subaru
Weight Weenie
Drives: 15 FR-S
^^Nice
Old 01-11-2019, 11:14 AM   #8
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
pm sent
What parts would a mechanic generally advise be replaced along with the suspension refresh?
Old 01-11-2019, 11:14 AM   #9
Vital
Drives: 2015 BRZ
Get some Bilstein B6 shock/strut since they seem to be slowly coming back
The Following 2 Users Say Thank You to Vital For This Useful Post:
mrg666 (01-12-2019), strat61caster (01-11-2019)
Old 01-11-2019, 12:34 PM   #10
Tokay444
Get new suspension.
Old 01-11-2019, 12:40 PM   #11
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Originally Posted by Tokay444 View Post
Get new suspension.
Thanks for all your help in narrowing down all the suspension kits that exist out there for the FRS. Much appreciate, can't wait to upvote your comment after i hit submit here
The Following 2 Users Say Thank You to RickyRacer For This Useful Post:
Impureclient (01-12-2019), Jordanwolf (01-11-2019)
Old 01-11-2019, 12:41 PM   #12
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
pm sent
Ball joints, tie rod ends, stuff like that.
Old 01-11-2019, 12:56 PM   #13
RickyRacer
RickyRacer's Avatar
Drives: 13 FRS
Hmm I cant find ball joints or tie rods on this suspension parts diagram
https://parts.toyota.com/a/Toyota_20...4420-4804.html
https://parts.toyota.com/a/Toyota_20...4420-4803.html
are they called something else there
Old 01-11-2019, 01:01 PM   #14
wparsons
wparsons's Avatar
OEM balljoints aren't available separately, have to get the whole front lower control arm.
That's the wrong front diagram, you need the one with the whole assembly, not just shock/spring.
As for the original question, get 2017+ shocks/springs/mounts and be done with it. Ohlins will ride nice, but won't last as long as OEM without a rebuild.
flickr
Looking for mechanic in Southeast radroach Southeast 0 07-27-2017 09:36 AM
Looking for a mechanic in Queens jarviz NY / NJ / CT / PA 3 08-18-2016 05:15 PM
Mechanic zen themadscientist Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2015 03:03 PM
Because car mechanic Boxer-86 Off-Topic Lounge [WARNING: NO POLITICS] 1 10-26-2012 01:34 AM
Mechanic Approved ashtray BRZ First-Gen (2012+) — General Topics 10 06-15-2012 05:53 PM
