Old 01-08-2019, 01:33 AM   #15
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Would they still perform the Safety Recall, even if you have basic bolt on mods? Headers, Intake, Catback Exhaust?
Sent from my SM-G965U using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 01-08-2019, 04:17 PM   #16
ottawafrs
Drives: 2013 Raven FRS
Originally Posted by FRSBRZGT86FAN View Post
@hgamit
FYI
"GT Super LLC Blue 00272-GTBC1" is toyotas "long life coolant" they definitely replaced the coolant and flushed it out if they used two bottles of it.
By AC "fluid" you mean refrigerant, which is probably listed on the receipt somewhere or they simply recovery vacuumed out the old refrigerant and reused which is a simple proper fix, replacing refrigerant isn't really necessary unless there's un-condensables/contamination in the system. They could've also just refilled it with new refrigerant without listing it.
Thanks.
The full procedure was posted in the other thread (https://drive.google.com/file/d/1uUi..._dVLZl_w7/view), makes clear that refrigerant is recovered and engine oil and coolant are drained before all new refrigerant/oil/coolant is replaced in the car.
ottawafrs is offline   Reply With Quote
Old 01-08-2019, 09:51 PM   #17
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
They should do it regardless as it's an NHTSA monitored recall however....
Put the stock tune, headers and intake back at the least, and they will very much so have to to it and won't damage your mods, it's a serious recall at this point not a TSB if i recall
Old 01-09-2019, 03:10 PM   #18
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Originally Posted by hgamit View Post
Happy New Year Everyone!!!
I wanted everyone to know that I took my FR-S into my local Toyota dealership on November 26 for the valve spring recall debacle.
Unfortunately, they didn’t have any info yet on the recall but they graciously gave me a rental car and covered the entire rental car cost.
Surprisingly, they called me today to tell me that my car was done and ready to be picked up. Moreover, I never received the “official” letter in the mail from Toyota.
It was about a $1300.00 dealer service charge (which will be billed to Toyota).
J02002 J02 - Perform J02 (Replace the Engine Valve Springs) on M
(1) Spring Valve Kit (MT) SU003-08062
(2) GT Super LLC Blue 00272-GTBC1
(1) Seal Packing 00295-1217H
New Oil, Oil Filter, Gasket
12.50 hours of labor
Thank you Scion and Toyota for the awesome customer service!!
That's AWESOME ! This was done at Tustin Toyota?
eastendraceshop is offline   Reply With Quote
Old 01-09-2019, 03:52 PM   #19
maslin
Benz Tech
Drives: 2017 BRZ Premium
Originally Posted by ottawafrs View Post
Thanks.
You don't "drain" refrigerant. It is recovered in to the same machine you use to recharge it. Recover 2 lbs, fill 2 lbs, no charge needed.
We reuse engine oil as well as coolant. Warranty doesn't pay to replace them if they weren't the problem. Say you need to remove a coolant hose and oil filter housing to reseal a front cover, the oil and coolant is reused, they were fine when you started the job.
maslin is offline   Reply With Quote
Old 01-09-2019, 05:22 PM   #20
ottawafrs
you refill engines with used oil?
The Following User Says Thank You to ottawafrs For This Useful Post:
DarkPira7e (01-09-2019)
Old 01-09-2019, 09:34 PM   #21
Eazy-V
What’s the support for this recall if you have FI kit since this is a major tuner car? I would assume this would be a re-occurring question?
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 01-09-2019, 09:41 PM   #22
Exrald
Exrald's Avatar
According to the dealerships that I have called about modded cars for this recall, they would still perform the job but would charge extra for removing the parts that are in the way.
2013 Scion FRS
2022 Toyota GR86
Old 01-09-2019, 09:42 PM   #23
Decep
Drives: 2013 FR-S Series 10
thats what he said.
Old 01-09-2019, 09:57 PM   #24
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
You are suppose to replace the coolant and the engine oil. Read page 10 of the repair manual.
Muaddib is offline   Reply With Quote
Old 01-10-2019, 12:07 AM   #25
Dake
Dake's Avatar
Yeah. Reusing refrigerant for sure but oil and coolant? That seems unlikely, from a liability standpoint as much as anything else.
Dake is offline   Reply With Quote
Old 01-10-2019, 01:42 AM   #26
maslin
Benz Tech
I don’t work at a toyota dealership. Premium brand. We don’t make the rules, just follow them. What’s the difference if the work wasn’t done and the oil was still in the car vs removing and putting it back?
Kind of like “you can never reuse a steering wheel bolt” until it’s a recall, then it’s fine to reuse the steering wheel bolt. You’d be surprised what gets done under warrranty.
Again, not Toyota. A brand you would expect to be much more discerning.
Old 01-10-2019, 10:44 AM   #27
ka-t_240
Reuse of Engine Oil, Coolant, Hydraulic Fluids is pretty standard practice in many shops, especially under Warranty. Unless the system is contaminated by the failure, then it would be replaced as part of the warranty claim. If the fluid is near the end of its "use", then it would be replaced and billed to the customer as general maintenance, usually customer would just be billed for the fluids and not the labor.
For some minor repairs were only a smaller hose is replaced, the tech can install a vacuum system on the reservoir that aids is reducing leaks/draining, so there is only the need to top off vs drain then refill the whole or partial system.
I work in the service world on heavy equipment were fluid is measured in gallons, not quarts. 50 gallons of coolant, 60 gallons in a trans, 100gallons in hydraulics etc.
ka-t_240 is offline   Reply With Quote
Old 01-10-2019, 03:06 PM   #28
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Called my dealership. They are telling me that they have to order the parts and it will take one or two weeks.
I LIKE TIRES!
Possible recall on the 86 regarding valve spring tanner CANADA 84 11-28-2019 10:32 PM
Valve spring recall meadowz06 Issues | Warranty | Recalls / TSB 115 06-09-2019 12:38 AM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-13-2019 12:38 AM
I have the valve spring recall information. meadowz06 Issues | Warranty | Recalls / TSB 24 12-23-2018 09:44 PM
67k miles, will bring car in for valve spring recall, what else to fix down there? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 12 12-19-2018 01:59 PM
